I propose that first a “C4” C=Camping (or CL) Camping Lantern, 4 = 4x18650 is taken from proof of concept to “production”
Then we can / should go to a smaller
C8 C=Camping (or CL) Camping Lantern 8 8xAA/814500 version
Yes a big cut the glare is very high on the list, maybe we can even get a nice big “awning top” (don’t know the proper name) because lets face it for the vast majority of use it will be popped down on the table with us and so from that level our eyes need to be protected from direct line of sight.
I think we are in great hands and I know the brain trust has forgotten more about lanterns then I will even know but I wanted to put the .02 lumens worth in the pot.
No attack intended but please skip the frills. Once we go to “real” emitters, (built in) solar panels just cant keep up.
Crank winding - same argument (do you know how much cranking you need to do to charge 4x2600 mah cells?)
and as for built in charging please remember the ACEBEAM debacle.
If we are on an extended trip such that packing 1-4 extra cells is an issue then we can plan on packing a separate solar panel and bring a proper charger (check out GoalZero et al)
KISS!!! If we want a power bank or a power source for our cell phone (how much are we really gong to talk on a remote trip?) See GOALZERO and others of there ilk for solutions.
What about PWM, do you intend to avoid flicker or are you not worried about this aspect? For me it would be an absolute deal breaker regardless of anything else although I do realise it’s not that important for the majority of people.
The plan is for this lantern to be newly produced, not buying SRK and scavenging it for the battery carrier. Of course there has to be enough interest and have hundreds of reservations before this can happen.
Using linear driver with XM-L/XP-L at 0.7A is very bad idea.
You will have 3.0-3.1v voltage drop through led and 0.7-1.0v voltage drop through 7135s. This means 2.1W to led, 0.5-0.7W to driver heat. Driver efficiency lower than 80%.
Interested depending on the final specs. I’m looking for a good lantern for a while now, so I’m curious about this project. For me a lantern requiring 18650 batteries would be first preference.
Thanks, DBSAR, for sharing this exciting idea.
I have thought about building a lantern before, and in my design I was not planning a driver at all, it had a rotary switch with several postions,for every position another resistor was switched in series of the led, to get the modes.
I post this just to be aware that this option exists, not because I think it is a better idea.
