Test/Review of Blitzwolf 4 port QC2 car charger BW-C5
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 36 min ago
DSC_3360
Official specifications:
  • Input: DC 12-24V (Max)
  • QC 2.0 Output: 5V/2A, 9V/2A, 12V/1.5A (Max)
  • USB Port Output: 3*5V/2.4A
  • Power: 54W
  • Size: 86.7mm*45mm*21mm(3.41*1.77*0.83in)
  • Brand: BlitzWolf®
I got it from Banggood
DSC_3356
Blitzwolf uses a brown cardboard box without much text on the outside.
DSC_3357
The box contained the charger and a note.
DSC_3361
DSC_3364
DSC_3365 DSC_3363
The QC output is the green usb connector.
DSC_3362
Measurements
  • Power consumption when idle is 0.06 watt at 12V and 0.12 watt at 24V
  • The usb 3 outputs are in parallel.
  • The 3 usb outputs are auto coding with Apple 2.5A as maximum.
  • The QC output is also auto coding in addition to QC
  • No individual port overload protection.
  • The QC output is turned off shortly when dropping down to 5 volt.
  • There is a blue led hidden between the middle two usb ports.
Load%20sweep%2011.6V%20%234
Load%20sweep%2014.6V%20%234
Load%20sweep%2024.0V%20%234
There is not much difference with varying input voltage, except 24V has lower efficiency. There is no individual port protection.
Running all 3 outputs in parallel there is a common overload protection at 8.5A, the lower efficiency for 24V disappears at higher load.
Load%20sweep%2011.6V%20QC5V
Load%20sweep%2014.6V%20QC5V
Load%20sweep%2024.0V%20QC5V
The QC output has protection, but at a fairly high level for a single port.
Load%20sweep%2011.6V%20QC12V
Load%20sweep%2014.6V%20QC12V
Load%20sweep%2024.0V%20QC12V
The QC 12V output is supposed to deliver 1.5A, it can easily do that and a lot more. At around 2.75A it drops out of 12V quick charge.
Voltage%20sweep%207.2A%20input%20current
With 7A output it needs about 1.5A at 24V and 3A at 12V.
Output voltage is very stable with changing input voltage.
No%20load%20voltage%20sweep
Idle current is about 6mA.
Load%20test%207.2A
Temp2884
M1: 66,1°C, M2: 66,1°C, M3: 52,6°C, HS1: 67,4°C
Temp2885
M1: 60,4°C, M2: 47,1°C, HS1: 61,9°C
10ohm
At 0.5A with 12V input the noise is 5mV rms and 140mVpp.
5ohm
At 1A with 12V input the noise is 5mV rms and 130mVpp.
2ohm
At 2.5A with 12V input the noise is 4mV rms and 104mVpp.
0.7ohm
At 7A with 12V input the noise is 5mV rms and 94mVpp.
2ohmqc
At 2.5A quick charge with 12V input the noise is 5mV rms and 117mVpp.
10ohmqc12V
At 1A with 12V input the noise is 7mV rms and 79mVpp.
Tear down
DSC_3410
The top and bottom could be removed, the circuit board had a little bit of glue I had to break before I could remove it.
DSC_3411
As expected there is two inductors: One for the 3 normal usb output and one for the quick charge output. The chip partial hidden under the metal is the QC2 controller (F75299).
DSC_3419
There is hidden a dual buck controller (TPS51220) under the capacitor and a transistor under the inductor.
DSC_3412
There is not much interesting stuff on this side of the circuit board. A 0.01 ohm resistor (R010), this must be current sense.
Notice the circuit board trace where the wire is connected, the squiggle is supposed to be a fuse.
DSC_3413
DSC_3414
DSC_3415
DSC_3416
DSC_3417
Notice the led between the usb connectors.
DSC_3418
U2 is one of the auto coding chips.
DSC_3420
Here a corner of the other auto coding chip can be seen.
Being a 12/24V device there is no need to test with high voltages.
Conclusion
This is a car charger with four high power usb ports that will charger just about any usb device as fast as possible. With one port supporting QuickCharge it can charge some pads and phones extra fast. The only negative detail is that all ports are in parallel without any individual protection.
I will call it a good charger (If each output had been limited to about 3A I would have called it very good).
Notes
The usb charger was supplied by Banggood for a review.
Read more about how I test USB power supplies/charger
Jinx
Jinx's picture
Last seen: 4 months 1 week ago
Great review as usual. I can’t recall if many of these car chargers usually accept 24v, if not then this one will be popular with the truckers out there.
Also handy for use as a mobile charger off of a small battery bank/solar setup as the adaptors on small fly leads cost next to nothing.
Grieflar
Grieflar's picture
Last seen: 1 year 3 weeks ago
Thanks a lot fellow Scandinavian. Been interested in how these really perform for a while Smile
Gotta love the Swedish postal service – $9 added to every package from China…
agent80
Last seen: 1 hour 59 min ago
Great review as always!
HKJ
HKJ's picture
It looks like many do support 24V, but not all. This one is good for anyone having multiple devices in the car.
lagman
lagman's picture
Thanks, however something is clearly wrong with the wattage curves.
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
HKJ
HKJ's picture
What? It is power loss in the charger (Look at the labelling below the charts).
will34
will34's picture
Last seen: 11 hours 26 min ago
Interesting, it works most efficiently at lowest and highest input voltages… Edit: the other way around…
HKJ
HKJ's picture
There is a couple of factors that give looses, the question is how they balance out:
High current will give looses due to ohmic resistance.
Larger voltage conversion will give larger looses.
Internal power supply will have a minimum power usage, this will always give low efficiency at low loads.
Internal power supply will often loose efficiency at higher input voltage
lagman
lagman's picture
Oh ok. I didn’t see the labelling and thought this watt curve must have been the power delivered to the load.
My mistake.
