I would be also very interested in a 18650 battery tube for the T01, like a thrower version of the U11. Not sure why Manker hasn’t released such light.
2xAA sounds good too.
Will, I am pretty sure the T01 is a uni-body design so you can’t take the head off from the body, we can only use 14mm diameter batteries…
I would buy one and the tube, how is that for motivation!!
Manker is not good to make extension tubes, we must remember the BLF A6
After you try them, if they work I want one or two
Oops… totally forgot that part
Voted before I scrolled to the mock-up image, whoops. Canceled ‘not sure’ and changed to ‘yes’.
2*AA option would make me seriously consider purchasing the light, as it would fill another niche in the ’collection.
No. Completely changes the pocketability for my uses.
I’ve never seen the point of this light, the big head places it in 18650 category, so why not carry an 18650 torch? The Olight S15 plus extension tube is unbeatable in terms of output and efficiency, and is compact.
This is a good point….
Review of Quark AA2 and Caveman show at least equal efficiency and output, but S15 is more compact.
But they are tail only switch, much less friendly for me. S15 solid bargain.
It’s an extremely throwy AA/14500 flashlight with exceptionally high output on both AA or 14500.
The S15 is barely half the output and 1/7 the throw.
Very good!
Manker replied, unfortunately it’s not going to work
“Thanks for your great interest on Manker high quality product.
After checked with our engineer,sorry to let you know T01 is not wide voltage drive flashlight, it didn’t support 2AA batteries to drive.
Thanks for your valuable email, we will consider to support wide voltage drive on future new product.
Best regards
Richard”
T01 is mine.
we have a solution now.
Does your solution work with existing T01s?
Ill bet it doesn’t
Hope is a great one, can’t wait to hear it! :sunglasses:
Ooooooh, this is interesting now with the manufacturer getting in on it…
Maybe T01v2?
yes yes yes. i want an extension tube
for want of an idea, instead of an extension tube…
maybe Manker can copy the battery compartment of Nitecore EC4SW
instead of series, maybe the batteries can be wired in parallel.
im thinking that there should be enough juice in the combined battery to power the XP-L HIGH for some more minutes
