I haven’t messed with my blue S2+ again. I’m really very happy with it as-is, although the drain through the tailcap is a bit high. Still, it would take about a month to drain the battery just sitting on the shelf and I find that acceptable. And yes, I used the smaller board in there. It looks like this stacked up on top of the original switch:
I did start on my red S2+, however. Same bleeder resistor on the driver and it works great. I made a silly mistake though - I assumed the LEDs that look red when powered off would also look red when powered on. They don’t…
No, if they’re working at all it’s fine. I probably put that line too close to the edge. The “2” channel has a trace closest to the center on the bottom, but obviously it’s working fine.
One reason for that is it is rarely a drop-in upgrade. Many times it requires fiddling with the driver or at least fiddling with the tailcap stack to get the light working again. So it’s usually much better to work on a complete light than just sell the tailcap parts. Shipping a light back and forth adds at least $10 to a mod.
The second reason is that I don’t have the time to build as many as I think there would be demand for, and I don’t feel right saying yes to some people and no to other people.
But like I said in the OP, I’m sure someone would do it for you for the right price.
Well crap! I have an S2+ that is my EDC and I decided to try out one of the new washer replacement tailcap boards. Got it build, it ohmed out well and all of the leds lit on my bench supply. So, I took the 2 led switch out of my S2+ and replaced it with this…
It lit up and worked well, for a while.
Then I lost mode switching! If I very quickly lock out and lock in the tailcap it will switch modes. But, if I half press the reverse clicky it will not switch modes to save it soul now.
What the hell? My meter sees an open on a half press with it mounted in the tailcap. I used 4.7k resistors, so now it would be seen as 3*4.7k in parallel?
Well, after spending more time with this… the 4*7135 in this light does not like this board even though it is currently working with a 2 blue led board. But, this board works fine in my JAX C8 Mini with an 8*7135 board. These things could lead to drinking on a bad night! It also did not work properly in the BLF X5, mode changes were wonky.
I finally got boards built for all of my colored S2+ lights.
All are the 14mm v5.1 ring boards used in place of the metal washer that was in there. Looks like this all mounted up:
All of them are using color-matched 0805 emitters, obviously. Resistor value varies greatly between them, from 5.9Kohm for the blue down to 1.5 Kohm for the red. Yes that means the red isn’t very efficient, but I didn’t build them for practicality. They’re fun! All of them have MtnElectronics 105C drivers with varying numbers of 7135s depending on the emitter in the light, and all flashed with GuppyDrv. They all work as expected after I got the bleeder resistor value worked out, 220 ohms in my case. I connected that bleeder resistor directly from V+ to GND right here:
Since I had to remove the original black rubber piece that provides all the waterproofing in the tailcap of this light, I added some nylon rubber I cut from a disposable glove. I put it directly under the switch assembly, like this:
I haven’t tested it yet so I have no idea if that works or not, but it looks…reasonable. Would probably be better without the crease in there but they all did that when I screwed them down.
I’ve shared this before elsewhere but here’s a bonus shot of the other end of these lights.
This is fun! Thanks PD and everyone else involved in this project!
Thanks, the blue one is nicer than it looks in the photo. It slightly overexposed here because its really still the brightest of the bunch, but I’m kinda tired of tearing it down and swapping those resistors. They’re not exactly in an easy spot to get to on those boards. Maybe I’ll increase those another step or two one day when I’ve got nothing else to do. But for now I’m very satisfied with how they turned out.
I need some help… I have rev. 3 board and for some reason I can’t get 2 lights to work on the board. I can only seem to get only one of the leds to light up. Below is a picture of the switch side of the board. Any insight would be appreciated.
