Interesting, I’d be keen but I’ve seen these type bars come and go on here, none very successful so far…
$350 is out of my price range… I have really wanted to build one like this too, but dont have the resources for the housing. If it was closer to 200-250 I would be in for sure.
$350 is at the top of my price range… I would like to make it for 200 really, if I take out a couple LEDs, use a smaller elliptical optic and thus a shorter housing will help.
I really find using XHP 50s and 70s are the way to go, for a DIYer, you can’t beat the price/watt, when you factor optic costs into the equation.
Interesting project… I used taskled drivers before in maglite mods so I think this could be useful:
For the 4 XHP50s in the middle I would say the Taskled HBFlex would be optimal for the application, its a boost driver with 7-24V input and drives up to 48V at 3A. With proper heat sinking it can run for as long as you wish.
For the two outer XHP70s… H6Flex comes to mind (buck driver < 25V in > 7V out at 6.6A) but the output might be limited due to the small input-output voltage difference when the Vf raises. A DC-DC step up converter can be used here to supply 24V to the driver, also decreasing the required current draw required to supply full power to both leds.
http://www.taskled.com/h6flex.shtml
You could also use 2x H6Flex to power the middle and outer LEDs separately, each with it’s own DC-DC 12v-24v boost circuit which are pretty cheap: http://www.ebay.com/itm/DC12V-Step-Up-to-24V-240W-10A-Car-Power-Converter-Regulator-Adaptor-/201503964400?hash=item2eea927cf0:g:Sl4AAOSwLN5Wk17p
But this is a very expensive setup, that’s almost $100 in drivers alone.
Are voltage spikes still an issue in modern vehicles? I was under the impression that providing you use good quality accessories and don’t do anything like disconnect the battery with the engine running they were quite uncommon unless you have a major component failure, in which case one would worry more about the various ECUs than a lightbar.
I dont know but it comes up often when this topic arises.
Wait, were you talking about normal voltage fluctuations of ~15v or +100v spikes?
You know, the more I think about the TaskLED drivers, the more I don’t want to use them, at least for now. The price for just the drivers is ridiculous, more than the LEDs themselves. I am gonna go with the Russian sourced units, I like how they set them up for modes, good price too. Sure, it would be very nice to have thermal shutdown safety built into the driver, but I can live without it for now. Everything will be interchangeable, so I can see in the future I will upgrade that part.
Voltage spikes shouldn’t be an issue, no. If you are worried, there are ways to stabilize the power, for both the electrical noise and voltage fluctuations.
Here are the optics that have come, the smaller elliptical TIR is a Carlco 30mm. The large lense is the 67mm Gaggione LLC56N, the one next to it is the 45mm LLC49E. The headlamp is an Armytek Wizard Pro V2, for size reference. Can’t wait to light those babies up with some xhp monsters.
I have purchased 2 of those drivers from Russia 2 days ago, one 3 amp model with 4 switch modes, and a 2.4 amp model with 4 modes as well. It might be a few weeks before I get them so hang in there. LEDs I was expecting this week, nothing yet.
If anyone is interested in possibly going in on this project, let me know. The more the better.
What’s this mean? I might be interested.
Well, the more people who would buy at the same time, the cheaper the light bar will be, down to a point of diminishing savings… I think after about 5 or 6 light bars made the savings difference would be negligible. The CNC machining of the housing/case is the part that will make it cheaper with volume, this is what I am referring to. Also, I suppose the shipping costs for all the others part to be ordered will be reduced with volume as well.
Here is another pic, I made the elliptical lense, well, elliptical (horizontal lines on the lense face)… only it is 90 degrees the wrong tilt, I tried turning it in CAD, it allowed me to do it, but it just didn’t visually change. Not sure about that?
Might be interested, are the parts being machined in Canada?
Okay. Yes, the housing will be machined locally here in my home town. I am hoping he can machine the pieces for $150 each.
Possibly interested in this, pending the price. I've thought about the one I've wanted to build several times, and what seemed most appealing was XHP70s on the outside for flood, and XP-L HIs in the middle for some throw.
I love the beam pattern from the Ledil BOOM-wide (for the MC-E emitter), but I would probably go with the medium reflector for an automotive application so it's not just lighting up everything within 10'.
I would have to say 4000k would be my preference for automotive use, as well, possibly even warmer.
I missed your post here Prince. Price will be up in the $350 CAD at least.
I have been playing…I mean experimenting with the optics and the XHP-50 and 70’s and have come to the conclusion that the light bar will be exclusively XHP-50 candles. The spot on the 70 is too large and just wastes light (12 Degree FWHM), the 50 has a slightly more intense beam, plus it is a better 9 Degree FWHM, just right IMO. The drivers for the 50 can also power TWO 50 LEDs, the driver for the 70, only ONE LED.
Anyways, I will also be using the smaller Carclo 30mm Elliptical optic for near field flood.
Pretty settled on the specs me thinks:
8 XHP-50 J4 - 3x @ 100% drive current with 4 brightness levels (3A, 1.4A, 0.7A, 0.4A) 20,000 LED Lumens Total
4 spot optics: 9 Degree Beam, 90,000 Cd Peak beam intensity each = 360,000 Cd Total
4 Elliptical 30mm Carclo optics, 43 Degree x 19 Degree, 6800 Cd Peak beam intensity = 27,000 Cd Total… plenty for near/mid field zone
Just a little update, project far from dead, and specs MIGHT still change as it is far from done. Waiting for Cutter to bring in some J4 5000k 50s, and trying to get a hold of Conrad Heatsinks. I just ordered 4 30mm Carclo’s and 4 Gaggione 67mm spots. Will post some pics.
Just found this thread and I am interested. I’ve got a few light bars from rigid industries but this looks pretty awesome so far!
Looks great. I think I’m interested too. One thing that might be cool is a remote wireless switch, so control cables don’t have to be drilled through the firewall of the vehicle. I’ve seen lightbars like this, where all you have to do is connect to the battery, and done.
The Ford F150 has a spot made for this light
I think the XHP-50s are a good choice over the 70s. I’m not sure why I overlooked them previously.
Looks interesting. I would also prefer 4000k or warmer.
Most light bars have excellent spill (which is needed) but lack a strong long range hot spot.
If this becomes available in warm emitters and can accomplish both spill and hot spot, I’m interested.
