Yes, please take pictures of the mods, I have a ton of things to learn and pictures always help
Also, any chance you could make some before / after beamshots? With such a big increase of amp draw, turbo should show some difference… Although I suppose it will hard to know what’s from this mod and what’s from the shave.
Well I already potted the driver, so I can’t really get good pictures if it anymore, but I can maybe draw a picture of what to do, it’s very simple.
I only have the original beamshots I took of the stock light. I can take the modded light to the same place and do a new beamshot, but we don’t have snow anymore so that will skew it.
Sorry, before/after stuff didn’t cross my mind because I don’t normally do beamshots at all.
What and how did you pot driver? Did you heat sink the FETs? Glop some thermal epoxy on? Inquiring minds need to know, how the pro’s heat sink buck driver’s?
Whatever you think of my modding ability, I am the opposite of a pro at potting, mostly because I almost never do it. The only other times I’ve ever done it was for long-term physical durability, not heat.
I just know that buck drivers get very hot at high amperages, and I know that almost anything is better at moving heat than air. So I stuffed it full of Duct Seal. It’s probably terrible for this application, but still better than nothing.
is there a way to mod this light in a slightly less aggressive manner? I mean no blobbing all the resistors together creating a huge hot rod but to exchange them for higher output but still descent battery time? Mine is on the way and I am already thinking of tuning it.
Thanks!
Try using the light first. Even in stock form it is very very bright. I would have also liked to de-tune it a bit from where I have it now, but I didn’t have any low value resistors.
Ramping up for my first two reviews
The S50 and S70
Pics on the details done but too rainy for beam shots
The S50 lit up a nice part of the field next to us will try S70 after dark, can’t wait!
The S50 has a pill that is very easy to remove since there is no side switch.
If someone does not want a (second) side switch the S50 is easier to mod.
Is there a FET driver that will fit in the S70? Looks to me like they’re all too small and you’d need to make up some kind of contact board with the existing driver.
With the stock driver modded doing 9A+ I don’t think a FET would come to play, but what you can do is get a blank board and pot a smaller FET driver on top, it works the same.
Anyone know the max cell length that can be run in the S70 ?
I note from another forum a poster saying that 67.7mm cells are a tight fit which would rule a lot of cells out ?
Thanks The Miller & pilotdog, I will get cells no more than 69mm long then, probably unprotected button/semi button top.
Just got to dig through the minefield of 26650 cell specs & claims
Thanks again.
BTW I haven”t got mine yet but am looking forward to it arriving greatly.
Got a pair of Thorfire C8s” & I am very impressed with the build & finish of them so hopefully the S70 will be equally as good.
I like it, workng on a review.
Made the beamshots yesterday.
Cool thing, at 800 meter is the castle.
yesterday night I looked at the tower after they shut down the show lights.
I looked through a monocular in the direction of the towers, since I could not see it in the dark.
S70 on Turbo and bam there they were! Very cool.
When the weather permits will test the S50 tonight, to see if it can do the same.
