SAiK SA-305
It came today! - 14 days from there to here. Not bad time really, normal amount of time for Hong Kong orders.
Here's some Specs and Info:
Brand: SAiK
Model: SA-305
Casing Color: Black
Emitter Brand/Type: Cree
Emitter BIN: Q2 WC
Color BIN: White
Total Emitters: 1
Battery Configurations: 3 x AA battery (not included)
Voltage Input: 0.9~4.5V, 4.5V Max.
Switch Type: Clicky/Clickie
Switch Location: Tail-cap
Modes: 3
Mode Memory: - No
Mode Arrangement: Hi > Lo > Fast Strobe
Circuitry: Digital Regulated 700mA Current Output
Brightness: 140 lumens maximum brightness (manufacturer rated)
Runtime: 35 minutes (manufacturer rated)
Lens: Plastic Lens
Reflector: Aluminum Smooth/SMO Reflector (It is Plastic!)
Carrying Strap: No
Dimensions: 5.16 in x 2.09 in x 2.09 in (13.1 cm x 5.3 cm x 5.3 cm)
Weight: 8.89 oz (252 g)
Here are some Dimensions:
OAL- 130mm
Body OD- 41.5mm
Head OD- 53mm
Body Length- 70mm
Head Length- 47.5mm (with bezel)
Head Length- 41mm (w/o bezel)
Lens OD- 46mm
Lens opening in bezel- 48mm
Reflector OD- 46mm (ID 40mm)
Reflector Length- 31mm
Head major ID- 43mm
Head minor ID- 31mm (threaded for body end)
Head depth from reflector lip to step for inner (to body) threads- 24.5mm
Head depth (length of threaded ID) - 31mm (these are the body attachment threads)
Head Inner Height from reflector lip to face of pill (with body screwed on) - 25.5mm
Tail cap threaded ID- 31mm
Tail cap length- 21mm
Here is a VIDEO!! It's the very first one I ever made, so Be Nice! ;-)
So you know what I want from this build. I want an XM-L T6 light when I get done with it.
Here's what I see already:
NEEDS
A glass lens
An Aluminum Reflector
A big Heat sink
A different regulator board
T6 emitter
WANTS
Remake the battery holder with all copper
Remake the Clicky with all copper, or replace the switch
Fill the 1/4x20 hole in the body
Smooth all the threads
Replace "O" rings
Paint with a special paint I want to try out
Add a FatBoy Logo
Issues I see right now:
I ordered stuff before I had good measurements, so the new reflector will have to have a ring made for it, to fit tightly in the head ID.
The heat sink I have is a piece of Aluminum rod stock in 1-5/8", so it will have to be "made to fit" with a sleeve, so the fit to head ID is tight.
The difference between the step in the head and the height of the pill, when screwed together, is 2mm, so I will have to figure out the gap from my Heat sink, to the pill (which will still hold the new regulator board & positive spring contact). I am figuring now that I will remove the threads from the pill and attach it to the bottom of the Heat sink I make, so it's all one piece.
Other than that, the rest is fairly straight forward.
I will post again, as I work on this mod and I may do more videos along the way.
