how do i memory to ON? its still OFF:)
Thank you Rolz for checking as well. I did read the BLF A6 troubleshooting thread, but could not find anything matching my problem yet.
I’ve done some searching and not found any mention. Possibly PM Toykeeper for opinion
You need to turn the flashlight on. Then tap/half click the tailcap switch 15+ times. You’ll then enter config mode as per the image below. Once ini config mode you’ll see 2 blinks in one lot and then a second time. After the second lot of 2 blinks turn off the flashlight. On restarting you should have activated memory mode.
Wasn’t it 16+ short clicks/tabs ?
Thanks for pointing this out. Just checked Toykeepers details on the firmware and it’s described as per below. So probably yes to 16 taps. I’ll update the post to suggest 15+
- Short tap rapidly a bunch of times (15+ taps, or until the light stops turning on) to enter soft config mode.
Is there a way to get it to turn on each time to turbo with just one click?
Yes, put it in mode memory = ON mode.
turn it on and put it in TURBO mode.
shut it off
when you turn it back on it should come on in the last memorized mode, which would be TURBO.
TURBO gets hot real quick so be careful.
Take care,
john.
I just recvd mine yesterday after a 37 day wait from banggood.
played with it last nite, really nice flood beam.
I really like that you can go backwards in output modes with a long press of the switch.
I did get the short tube for the other battery type, it was in a separate bubblewrap container,
not in the box with the torch.
for the programming modes I short pressed the switch 16 times
the torch will then blink twice and pause then blink twice again.
after the FIRST SET of 2-blinks shut off the torch to choose between mode
GROUP-1 which is,
moon
low
med1
med2
high1
high2
turbo.
(mine came delivered in mode group 1)
or mode GROUP-2 which is,
low
med
high
turbo.
after the SECOND SET of 2 blinks, shut off the torch to choose between,
MODE MEMORY OFF (mine came delivered in memory off mode)
or
MODE MEMORY ON.
I had to re-enter mode programming(re-do the 16 short presses).
after changing each mode.
Hope this helps someone.
It helped me! Thanks a lot. I have blinded myself sooooo many times trying to change the modes. Got it today and the number of blinds are >20 already.
This thing is bright. On Turbo it so bright and warm that it burns the skin from 5 cm when held for about 10 seconds. Awesome!
Can’t get it working with the short tube though
it in in flash sale at the moment for 25
Rolz, as you have both A6 and S1 - could you please check if the tubes are interchangeable or the threads are different in both lights? I’ve read conflicting reports but many people were sent 18350 tubes with wrong threads so this may account for the mess.
Sooo, any hints on making the short tube work? Maybe contact BG for a working one?
One thing to try is to reverse the short tube. I learned the hard way that the knurling on the body tube must face towards the HEAD of the flashlight. This is true for both the 18350 and 18650 tubes.
Hi Altonx. I just tried the S1 18350 tube on the A6 and it fits well, no thread issues. Testing with a battery it operates as expected.
Received my Astrolux S1 a few days ago and am impressed despite driver issues.
Using a brand new, freshly charged Samsung 30Q the first three modes are identical. Seems they are all Med1, so no Moonlight or Low. Med2 through Turbo seem fine (or “scary”, depending on how you look at it).
Reversing through the UI gives same incorrect modes, in reverse.
Two more anomalies:
- Hidden modes work apart from Batt Check which does not flash despite cheap DMM showing 30Q at 4.17V
- I can’t get into Config Mode despite numerous attempts at 15+ taps, although somewhere along the way I seem to have enabled Mode Memory without any blinking sign that I’d entered Config Mode. User incompetence or broken driver?
The BLF A6 troubleshooting thread reveals a few others with somewhat similar issues so I’m assuming it’s a badly soldered or defective 7135. I’m reluctant to try to open it up and fix this myself so I’m waiting to hear if Banggood will send a new head.
If further confusion were needed it arrives in the form of a $4.95 partial refund BG issued prior to shipping to compensate for an odd error that pushed up the price by that amount after I added it to the shopping cart during a recent flash sale. The order details under My Account show it as simply “Refunded” so I may have an extra hurdle there.
A long time lurker I followed the BLF A6 development from the very beginning, signed up for the GB but held back for QA issues to settle. Finally pulling the trigger has taken me long enough to disqualify me as any kind of serious flashlight enthusiast, no matter what friends may think
Wait a while longer, fingers crossed.
Update 7th June: Banggood CS responds but suggests that it could be faulty switch. I waste a minute testing with knife blade and reply that it is most definitely a faulty driver.
Update 8th June: Banggood CS agrees to send a new head
Just got mine yesterday and I am pretty impressed with this light. Only thing that i think is missing from this is the Moonlight mode on the 4 mode option, both 7 and 4 modes should have a Moon included. But i’m good, it’s not really a complaint.
I have a question about the output of the S1, what are the lumen for the 4 mode config?
Low ?? lumens
Med ?? lumens
High ?? lumens
Turbo ?? lumens
I’m using Olight 3400mAh battery.
You will probably have to search the original thread for that answer but the output does change from battery to battery whixh means there arMoonlight however is only available when using 7 modes.
Hi.
I have a Astrolux S1 and I have put in it a “20mm 15 Degree Cree XM-L LED Lens” turning it to a more throw capable light.
So I ask if there is a more narrow beam optic for the same light.
