After a few dozen different designs i tested for basic flashlight diffusers, ( including factory built diffuser covers, hoods, etc.) The one that seems to work the best is the ones i have built below. (this sample is a small unit to fit my Roche, Convoy, Olight S15, etc.) The principle of this design is the reflect as much light downward at the same time allowing a diffused flood beam to be directed upward, while reducing the eye-level “glare” as low as possible, in this case this diffuser below almost has no glare at all. (that can even be seen in all the photos of the lantern head below where there is even no camera lens flare.)
The first photo shows the Lantern-Head used on my warm white 3000K Roche F6, on low mode. I placed it against a white wall to show the beam emitting pattern, where it emits more light up and down at the same time, while reducing the “side glare” that is a big fault of 90 % of the factory lanterns on the market. (second inset photo shows the light output in all directions at the levels i designed this lantern head to do.)
The next photo below shows the lantern head close up, ( its built from a simple acrylic bottle with a white frosted top, and a section of ball-point pen tubing in the center as a “light carrier”.
The inset photo to the lower right shows the Roche on medium mode using the Lantern Head, here you can see how even it directs the light where its needed most. The floor areas are illuminated very evenly along with the ceiling area, while the side glare at eye level is almost non existent. I have used these Lantern Heads out on camping trips, and they work great out doors too with low glare and illuminating everything where the light is needed most.
This will be the principle design of this BLF lantern project of this topic, but in reverse. (also will be much more powerful.)
I like the idea of a bright, efficient. Warm color led. High cri
But it needs to be able to actually go camping with. It needs to be sturdy, wind rain, who knows it could get tipped. Or fall off tree branch.
When I camp I load a military large pack up and hop on my dirt bike.
All of this is difficult to make happen, especially at an affordable price.
But if you can swing it, I am interested.
Puh, thats great, need it in summertime this year, or next year, or…
Thank you!
Ahm yes, im in for one or two, depends on size and extras. Maybe one fully equipped - charger, power, mirror,… and one with the basics you told in the beginning
“Cree has announced the results of laboratory tests of a single high-power packaged LED that delivered almost 1600 lm with light quality that matches the incandescent lamp”
Mod it so it fits either the Uniquefire UF1401 (if I wor it out with Gearbest to get a working one) or a SRK with the V2 moonlight enabled driver.
Would that not make an ideal tabletop camping light?
Thanks for the suggestion. Looks like a great adapter but a little pricey. I was hoping someone like Den could design something cheap that can be attached to various flashlights around the house during an outage.
Which is why you’d be a great candidate to design an ultra cheap universal adapter for mass production. Heck you might even make a buck or two. Just be sure we forum members get a discount
Interested, depending on cost. I’ve been working on a “lid” light for a while, though much less powerful than this (two 18500s). Adafruit makes a stand alone Lith Ion/Li Poly micro USB charge board 3/4” square for 7 bucks. It’ll only push 500ma, but it’s self contained, affordable, available, and made here. Also, should it be of use to you, Nalgene 4 and 8 ounce polycarbonate straight wall jars have Mason threads on them (very close to the diameter you’re working with—2.625” thread OD and 2.52” jar ID). Stainless one piece Mason lids and silicone seals are available from Mason Lifestyle. I’m thinking that riveting a stainless lid to the base plate would be an easy and waterproof way to join the diffuser (if using the Nalgene jar) and body. Even better may be to cut mason threads in the aluminum housing itself and skip the lid, though the two may not work out diameter-wise.
This looks extremely promising. I’ll be in for at least one. If it had usb changing, it would definitely make it more appealing to the non-flash crowd and boost sales and gifting. Very cool, getrdun!!
the prototype under construction, though been over busy at work the last few weeks to do much progress on it, but i hope to get it ready by end of April.
