Did you have that cold one?. Was it a beer, &/or wine, &/or coffee, &/or root beer, &/or whatever else you fancy?
Yes, AFAIK I was the one that first reported the ?problem. And then you shifted it to only the forum's "root" page.
But in the past you had a <Mark Read> button at the top right of each subforum which ONLY marked as read the current sub-forum (& Not its own sub-forums Nor ANY other sub-forums).
May be the new button could be called something like <Mark All Topics Read> Or <Mark this Forum Read> Or?
Right now, once I have read the threads/posts I find interesting, I have to:
1). Go to bottom of page
2). Click on "Forum Tools" menu
3). Select "Mark All Topics Read"
Instead of just clicking a <Mark All Topics Read> button at the webpage's top right, as was able to do in BLF's previous incarnation.
Thank you Very Much for all your Greatly Appreciated work,
I suspect that the issue has more to do with the monospace font that your system uses. For reference, here’s what mine looks like with the “Ubuntu” monospace font specified in my system settings:
I noticed that the "Edited on date, time" line at the bottom of a thread's OP which appeared if it had been edited, has now gone missing (was present until a ~2-3 days ago).
That entry was Very useful, as it allowed us to check when a thread's OP was last edited. Particularly as often a thread is marked as updated, But there is no "View xx new" link.
Any chance of getting it back?
And any comment(s) on my response to your reply re the <Mark Read> button?
About the “Mark read” button, I’m almost positive that it was never able to mark just a single category as read. It was all or nothing.
The “edited” stamp was removed because it was getting changed as a result of the new email notification system. I think I might have worked around it now, and I re-enabled the “edited” stamp. But please let me know if you see posts marked as “edited” by a user that didn’t start the thread.
FYI, I used the the "Mark read" button in the previous BLF incarnation ever since I joined (April'2014), & I assure you it Only marked a "single category"/subforum as read. VERY Useful!!
Re the a thread's OP "edited" stamp, I shall keep an eye on the threads, & report any issue(s) I notice.
Can we fix the signature looking like part of the post problem, i forget how it was done before but now signatures don’t have a clear psychological separation from posts (was it just more spaces before?)
FWIW, this is relatively simple with a few lines of CSS. Here’s what I’m using:
/* signature at the end of each post */
div.clear {
/* display: none; */ /* in case you want no signatures at all */
margin: 6px 0 0 0 !important;
padding: 0 !important;
font-size: 80%; /* make the text smaller by default */
border-top: 1px solid #555 !important;
div.clear div:not([class]) { /* get rid of '--' divider at top of signature */
display: none;
Also, what do you think of adding TLF (TaschenLampen Forum) to the Related Sites links? I come across them quite often when doing google searches for various flashlights: http://www.taschenlampen-forum.de/
Thanks very much ToyKeeper! Looks great. I just implemented this style. Now, is there any way to convince Bort to remove the huge blank vertical space at the end of his signature?
I kinda wondered if that 255 character problem was going to resolved on your end, bringing back what was there before.
I’ve also considered if there had not been software upgrade i would have stuck with what i had, yet i have other ideas
Way too much contemplation for a signature, probably.
BTW could we add 2 or 3 spaces before the new signature separation line
Edit, i just noticed we no longer have re-input the password to change signatures, very happy, we can now test changes much more quickly
I managed to kludge together this functionality for individual forum categories. I put the button on the right side when it’s a single forum category, and on the left side for the /forum overview page so they can be easily distinguished at a glance.
