About the “Mark read” button, I’m almost positive that it was never able to mark just a single category as read. It was all or nothing.
The “edited” stamp was removed because it was getting changed as a result of the new email notification system. I think I might have worked around it now, and I re-enabled the “edited” stamp. But please let me know if you see posts marked as “edited” by a user that didn’t start the thread.
FYI, I used the the "Mark read" button in the previous BLF incarnation ever since I joined (April'2014), & I assure you it Only marked a "single category"/subforum as read. VERY Useful!!
Re the a thread's OP "edited" stamp, I shall keep an eye on the threads, & report any issue(s) I notice.
Can we fix the signature looking like part of the post problem, i forget how it was done before but now signatures don’t have a clear psychological separation from posts (was it just more spaces before?)
FWIW, this is relatively simple with a few lines of CSS. Here’s what I’m using:
/* signature at the end of each post */
div.clear {
/* display: none; */ /* in case you want no signatures at all */
margin: 6px 0 0 0 !important;
padding: 0 !important;
font-size: 80%; /* make the text smaller by default */
border-top: 1px solid #555 !important;
div.clear div:not([class]) { /* get rid of '--' divider at top of signature */
display: none;
Also, what do you think of adding TLF (TaschenLampen Forum) to the Related Sites links? I come across them quite often when doing google searches for various flashlights: http://www.taschenlampen-forum.de/
Thanks very much ToyKeeper! Looks great. I just implemented this style. Now, is there any way to convince Bort to remove the huge blank vertical space at the end of his signature?
I kinda wondered if that 255 character problem was going to resolved on your end, bringing back what was there before.
I’ve also considered if there had not been software upgrade i would have stuck with what i had, yet i have other ideas
Way too much contemplation for a signature, probably.
BTW could we add 2 or 3 spaces before the new signature separation line
Edit, i just noticed we no longer have re-input the password to change signatures, very happy, we can now test changes much more quickly
I managed to kludge together this functionality for individual forum categories. I put the button on the right side when it’s a single forum category, and on the left side for the /forum overview page so they can be easily distinguished at a glance.
Thanks for letting me know, it’s blocked now. And just a small disclaimer: I don’t control which ads Google does serve up, I can only block specific URLs so they don’t get served. And plus the ads are highly variable from one user to another based on a million factors, so I have no idea what sort of Google ads other users are receiving.
The the line delineating signatures is appearing as a fine dotted line. Can that be avoided? :-/
I have to say it’s bothering my eyes, by a surprising amount. :-(( I keep unintentionally trying to focus it clearer but the dots are really just too small to be clear on my screen.
BTW, the “!important” keywords in the CSS I posted are probably not needed if the CSS comes directly from BLF. It’s often needed in external theme overrides, but not usually in the original CSS.
The part about removing the “—” div is probably not needed either, if you can make the site simply not send that part to begin with. I don’t know how hard it is to change the html output though. IIRC BLF used to use a <div class=“signature”>, but now it uses <div class=“clear”><div>—</div> at the beginning of the signature. It’s harder to match without potential side effects.
However, the new version of BLF seems to have better markup for a variety of other things. It used to be that half the divs were called “block” of some sort. So I had to use totally opaque matching rules like “div#block-block-1.block.block-block”.
