I managed to kludge together this functionality for individual forum categories. I put the button on the right side when it’s a single forum category, and on the left side for the /forum overview page so they can be easily distinguished at a glance.
Thanks for letting me know, it’s blocked now. And just a small disclaimer: I don’t control which ads Google does serve up, I can only block specific URLs so they don’t get served. And plus the ads are highly variable from one user to another based on a million factors, so I have no idea what sort of Google ads other users are receiving.
The the line delineating signatures is appearing as a fine dotted line. Can that be avoided? :-/
I have to say it’s bothering my eyes, by a surprising amount. :-(( I keep unintentionally trying to focus it clearer but the dots are really just too small to be clear on my screen.
BTW, the “!important” keywords in the CSS I posted are probably not needed if the CSS comes directly from BLF. It’s often needed in external theme overrides, but not usually in the original CSS.
The part about removing the “—” div is probably not needed either, if you can make the site simply not send that part to begin with. I don’t know how hard it is to change the html output though. IIRC BLF used to use a <div class=“signature”>, but now it uses <div class=“clear”><div>—</div> at the beginning of the signature. It’s harder to match without potential side effects.
However, the new version of BLF seems to have better markup for a variety of other things. It used to be that half the divs were called “block” of some sort. So I had to use totally opaque matching rules like “div#block-block-1.block.block-block”.
In BLF's previous incarnation, we could select in Settings whether we wanted to use the Advanced Post Editor or the Simple Post Editor by default when posting.
Any chance of bringing this setting back? As right now there is no choice, & the default is the Simple Post Editor.
Thank you Very Much for all you are doing for us. GREATLY Appreciated.
