One guy built spot welder with A123 26650 cells,which are safer,have much longer cycle life,and they are rated for 30C (70Amps),but they were dead after very short amount of time.
I’m thinking how to provide good connection that will not break circuit while the battery is melting and catching fire I’m mostly worried about Swedish regulations (yes there is a rule for everything).
I found some videos where a trustfire went thermal runaway after a brief short circuit which apparenty caused internal damage. So it is not impossible that a brief short circuit leads to undesired chain of events.
@led4power - can you provide a link? It’s difficult to google out because I’m only getting welders that weld lion batteries, can’t filter for welders which are powerd by liion batteries.
Yep, if you damage it internally you will have a time bomb ticking. Exactly why we are saying this is a bad idea, and not to be anywhere near the cells if you entertain bad ideas.
hehe I’ve been electrocuted more than once Still can’t get enough of it.
I find this idea very intriguing - the problem is that I would use this welder a lot, and then I feel I would have a 10pack of VTC5A cells sitting in my room, being short circuited for hundreds if not thousands of times over a year or two. And only one internal short circuit could be potentially catastrophic, like having a ticking bomb.
Still I’m intrigued to somehow test this premise. I could build it and then torture test it, set it in an infinite loop with pulsed short circuits to test if something bad would happen. I live in a flat so I don’t have a safe way of doing it.
Just buy some D-cell-size Maxwell supercaps. They’re damn impressive. And they won’t explode and kill you.
You don’t need to get all fancy with the control side, either. Just a momentary foot switch that applies power to a FET’s gate and there’s your spot welds.
yeah I will feel better with caps and not shorting VTC’s. When I was a kid I had tons of fun with some 0.2F caps, Now I can afford much more capacity
I already ordered FET’s, I plan to control them with attiny85, but I think I need a gate driver to avoid ringing/spikes. I don’t yet know how to make gate driver, or which integrated gate driver to use.
This is not a test result for an actual battery, but a test specification with criteria for “test passed”.
Note that “does not vent” or “does not spew electrolyte” or “cell performance still meets specifications after test” are NOT listed as pass criteria.
That is, a cell passes this test even if it vents and spews out electrolyte and is dead afterwards. It must just not ignite and not explode or pop. Controlled venting and terminal damage is allowed.
A high-current cell without PTC (like the VTC5A) will usually vent on an extended low-ohmic short (if the shorting wire can take the current and doesn’t melt after a second). At the very least, the cell is damaged afterwards.
Ohm’s law: 200A current requires max. 20mOhms total resistance for a fully charged cell. That is, internal resistance plus contact and wiring resistance plus welding point resistance. So it could be possible to get the required current out of a VTC5A for a fraction of a second, but maybe not very wise to do this repeatedly. And if the welder fails to end the current pulse (FET shorted or the like), you can only hope that some other component will melt faster than it takes your cell array to start venting.
Edit:
Actually, this is a requirement specification for an “over current protective circuit” (7.2.4.3), not a performance specification of the cell.
I can completely relate on both counts separately, and on the statement as a whole.
Stick a VTC5 in a dead short contraption until failure to get a baseline for worst case scenario, then build the thing if you aren’t scared off by the results of the first test.
Oh an Youtube results (of at least the first test) please.
if you really need to use “batteries” for a spot welder, then only a automotive lead-acid battery than safely provide that momentary high current needed. A larger good quality cranking battery can provide 1000+ amps of current, as they are designed to do. One problem is weight & size.
As for the Li-ion, if you are really determined to use cylindrical cells you could use some of A123 systems’ 26650s. They are rated for 70 amps continuous, and just get a massive sub ohm power resistor to keep the current under the 100 amp pulse maximum.
Remember that supercaps aren’t your grandad’s caps. They will behave as a dead short for a shockingly long while when you start to charge them so plan your charging circuit appropriately.
i don’t think he will (or should be) be “spot-welding” in a house in the first place. Common sense should be in play here, also its unlikely that one is going to make the spot welder “on” the battery, cables would be used with the battery many feet away. Welding along side ANY battery with a plastic shell sealed or not would be just stupid.
Why not just use the transformer out of a microwave oven like the rest of us nutjobs that build a spot welder? Granted I only use mine to weld (mostly) vehicle body panels but some tinkering can get you to the amps you need for battery tabs.
It makes no real sense to use batteries, but I wonder about all the fear…?
The approach seems to be ok(short burst+high current+a lot parallel cell) so everything in spec and safe.
Like others said the transformer from an old microwave would cost next to nothing and works, so this seems to be the best lowcost variant.
