UltraFire RL-168 HA-III OSRAM 3 mode
14 posts / 0 new
old4570
  • Brand: UltraFire
  • Model: RL-168
  • Color BIN: White
  • Emitters: LUW-W5AM
  • Battery Configurations: 1 x AA/1 x 14500 Ii-on battery(not included)
  • Switch Type: Clicky (Clickie)
  • Switch Location: Tailcap
  • Modes: 3
  • Mode Memory: Circuitry Features Mode Memory
  • Mode Arrangement: Hi > Middle > Low
  • Runtime: 50 minutes (manufactuer rated)
  • Lumen: 150 lumens maximum brightness (manufactuer rated)
  • Lens: Coated Glass Lens
  • Reflector: Aluminum Smooth/SMO Reflector
  • Carrying Clip: Clip Included
I just received the Ultrafire RL - 168 in the post .  I have been interested in one of these ever since seeing one on ****** , and the opportunity to buy a 3 mode [ Hi - med - lo ] version came and I just didnt hesitate to spend the $25 USD to have it shipped to me . Got mine here .
  Now its rated for AA and 14500 , so let me get to the AA first . If you dont use a fresh cell  the light just about wont work , basically once the battery is used a little and the voltage drops , the RL-168 , just does not utilize all of the battery , in fact mine was shutting down @ 1.4v and then some , so dont expect much in the way of run time with AA's , not if this one is typical of the breed .
 Moving onto the 14500 , and this little light comes alive , the beam is a little ringy with a very small hotspot , but still has good spill , in fact I'm not sure this light should be anything but a 14500 light . I dare say that I have found another battery vampire , this little sucker draws up to some 1.5A current on high , and only returns a little over 200Lumen output for the current drawn . Lets have a look at the performance figures , and see how we are going ...
AA PERFORMANCE [ or lack there of ]
AA Alkaline 1.54v  = Low / 0.12A - 4Lumen  ,  Medium / 0.59A - 18Lumen  ,  High / 2A - 64Lumen
14500 PERFORMANCE
Low / 0.09A - 14Lumen  ,  Medium / 0.41A - 72Lumen  , High / 1.5A - 220Lumen  and sagged to about 205 after 1 minute
Besides being a bit of a battery vampire , I have no real complaints , in fact this little light was surprisingly good , Nice threads , nice anodizing , good solid clicky , and the clip is like alligator jaws , very firm and solid  . The light does appear to be better than your usual Ultrafires , and as long as you dont want to run AA's , is a very nice little light . I took it for a walk and the clip really did the job well [ hanging onto my belt ] , and never gave me the slightest hint of being anything but securely attached . I was hopping for AA compatibility , unfortunately AA's are just going to be a waste in this light , and one really needs to break out the 14500's to do the light any justice at all ...
Beamshots tonight !
Some beamshots !!!
First we will go with Low mode ...
Next medium mode ....
And then high mode ......
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: old4570 on 09/29/2010 - 05:58
FlashPilot
FlashPilot's picture
Last seen: 1 hour 6 min ago
Thank you for the review. Ive had my eye on this one for about a year or so. It is a handsome light. Have you gotten around to seeing how difficult an emitter and driver transplant would be?
old4570
Emitter might be ab easy swap , driver ??   ,  Im thinking , maybe a Cree Q5 ...  But I can live with it , the way it is ..... [ For how long ? ]
agenthex
agenthex's picture
Last seen: 9 years 1 month ago
Whoa, driver efficiency is abysmal if true. Have you tested w/ nimh?
Reading this makes you smarter: http://lesswrong.com/
how2
KD are selling this light with a Q5 for $29.11, save yourself the time.
http://www.kaidomain.com/ProductDetails.aspx?ProductId=10933
old4570
The driver seems to have at least a voltage issue ...  with 1.5v batteries , I tried a rechargeable , but it only ran about 10 seconds then turned off
But yeah ... Disappointing .. Might be better on a Lithium , but there expensive ...  Id call it a 14500 light ...
Hrvoje
Last seen: 1 year 1 month ago
KD sells RL-198 II (which accept 18650 ), this one is AA version. I have an old Osram version, modded with XP-G R4 neutral white and 2 mode driver. Very nice and quality made flashlight.
Hrvoje
sb56637
sb56637's picture
Last seen: 8 min 26 sec ago
Hi there Matt,
Thanks for the review, you saved me $25 on this light. Looks great, has some nice features, but I can't accept that NiMH performance. I wonder if it's defective?
old4570
Seems to be running fine on the 14500 though , I thought maybe a faulty driver ?  But Im not buying any more , so , unless some one else can verify ?
Though I do like it as is with the 14500 , I was looking for AA compatibility , which this does not really offer , not realistically .
Perhaps in the future a driver swap ...
old4570
I put in a SSC P4 emitter , and the beam is much nicer now , I just couldn't stand the ringy beam with the osram emitter ..
Output is down , but so is current draw , the beam is so smooth now ...
sb56637
sb56637's picture
Huh, that surprises me. I would have blamed the ringy beam on an alignment or reflector issue.
old4570
I messed around with the reflector , and nothing helped , so I popped in a SSC P4 , very nice ...
Havent fully  checked it yet , but seems to run better on AA's now ??? I will have to check that more fully ...
how2
You could have waited and got the big brother for the same price?
That's got XP-G R5
http://www.manafont.com/product_info.php/ultrafire-rl198-r5-3mode-memory...
old4570
Darn it !!!!!!!!!    Another light he needs to buy now !!!!!    Looks real nice with the XP-G R5 .....  Damn , goes on the must have list .....
Naaaa , Love the 168 , especially as its SSC P4 now , its a fantastic little 14500 light , not much chop on AA's , but just fantastic on 14500 ..
It is a viable option to CR123A powered lights ...   I think I need to buy some more 14500's [ batteries ] , as I dont have enough to go around .
