[WIP] 17mm DD+single-7135 driver / single sided / Dual-PWM
505 posts / 0 new
DavidEF
DavidEF's picture
Last seen: 2 hours 28 min ago
Tom E wrote:
Alex – didn’t look carefully at your v030 til now. Wow, impressive all that fits! Ohhh – is that a MCU pin #3 pad connected, but covered up? I’m really not lik’n soldering a thin wire to pin #3 directly on the v009’s for a locator /LVP LED. Looks like I could just scrape off the covering of the pad?
Edit: Debating whether I should order these 030’s now or wait til some testing is done. Not sure I followed everything, but have you been able to breadboard/proto/test this out somehow?
See post #352 above.
- The YKK Philosophy
ToyKeeper
ToyKeeper's picture
Last seen: 1 week 2 days ago
FWIW, Dale has parts for a few v030s on the way and we’re going to try to experiment to figure out what value resistors and such work best. I assume the OTC resistor, at least, will need some tweaking. Maybe other parts too.
However, feel free to do your own experimenting. It’ll probably be faster if you do it since the hardware and software parts of your brain don’t have to use email to talk to each other. Smile
Tom E
Tom E's picture
Last seen: 1 hour 6 min ago
Hhmmmm. I can probably get most parts from here @work, but not sure yet. I looked more carefully at Alex's tests in port #352 (thanks David, my bad!).
K, I'm a little confused, got some Q's:
  • this should handle high PWM rates, like 15K?
  • looks like there's ringing on the (2) line. Is that because of long LED wires or something else? Is that a bad thing or good/ok?
I'll just go ahead and order boards - $2.20 is no problem at all - feel like I'm ripping them off anyways... I'll be testing on an 85 and not interesting in OTC.
wight
Last seen: 1 year 4 months ago
Tom E wrote:
Hhmmmm. I can probably get most parts from here @work, but not sure yet. I looked more carefully at Alex’s tests in port #352 (thanks David, my bad!).
K, I’m a little confused, got some Q’s:
  • looks like there’s ringing on the (2) line. Is that because of long LED wires or something else? Is that a bad thing or good/ok?
I’ll just go ahead and order boards – $2.20 is no problem at all – feel like I’m ripping them off anyways… I’ll be testing on an 85 and not interesting in OTC.
Oops, sorry I didn’t reply Tom E – I saw your post earlier and meant to. Oops
  • As far as PWM, this is no different from earlier revisions. Were there any particular changes or comments that brought on the question?
  • The ringing is on BAT+. I suppose that it’s due to inductance in the battery/LED wires?
  • I agree, every time I order a 17mm or less board I feel like I’m getting a steal from OSH Park. Hopefully we serve some useful function for them! Wink
wight wrote:
My test LED was an old XP-G, probably with some damage, which only pulled around 2.5A from a high-drain cell. […] I need to swap the LED out for something which will pull more current and use a bit heavier LED wiring.
OK, apparently what I have on hand isn’t that powerful! I hooked up the only triple PCB I have, which is a triple XP-G2. I used it with the highest drain cell I have, a heavily used Samsung INR18650-15M. This setup was only good for 10.3 amps as measured with a clamp meter.
That said, I produced a couple of scope images and played around a bit. These shots are in a low mode, I failed to take pictures of medium modes. (My heatsink setup was such that I was afraid I’d melt the retention setup on anything other than low.)
This is the same driver build from post #352 but with some wiring changes (in addition to the LED change):
  1. I changed the battery wiring to ~200mm total of 18awg.
  2. I changed the LED wiring to the 22awg included with the triple.
  3. I soldered on new test points for the scope probes.
Channel order is
  1. BAT+ from spring side of driver.
  2. MCU VCC measured at C1.
  3. FET Gate measured at gate pin.
We can see that MCU VCC reached a safe-for-the-MCU 5v which is nonetheless very high considering that it’s attached to a 4.3v zener with no load resistor! I speculate that the Zener may die an early death like this. We’ll have to try and figure out the peak and average current it’s seeing. Gate looks pretty clean to me, with a bit of badness on the turn-off that we can probably clear up with the pulldown resistor. BAT+ reaches crazy high voltages. The second shot is on a 2v/div scale and shows a crazy high B+ spike of 8v from a single cell! This spike did get a volt or two worse in medium modes.
I’ll see about adding a gate pulldown resistor and testing with that.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
ToyKeeper
ToyKeeper's picture
When I’ve done realtime voltage monitoring on a FET-only board (Ferrero Rocher), I’ve gotten pretty big variability on voltage depending on the exact timing of the ADC reading. For a realtime display it’s actually not such a bad thing, since it makes the indicator flicker at a varying rate according to voltage. So, it actually provides more of a fine-grained indicator due to the spikes being out of phase with the measurements.
This also affects LVP, but it’s not usually an issue because LVP uses a heavy lowpass filter and because the spikes aren’t very big at low voltage.
For non-realtime displays it works well to shut off the emitter, wait a short while, then take and average some measurements.
I think the only worrisome impact of the spikes is whether it might damage or reset driver components. The MCU actually does pretty well dealing with the spikes as long as they’re not high enough to cause a reset.
If we go with Halo’s idea to eliminate the voltage measurement pin (and voltage divider parts) in favor of the VCC/Vref method, the VCC spikes may become more meaningful to the MCU. I give it only a 50/50 chance of mattering though, for the same reasons the non-fatal spikes don’t matter much on current designs.
The BAT+ spike looks a little scary. I wonder if that could damage the emitters over time. Dale has mentioned that some of his lights don’t measure up to their original performance any more, and this might explain why.
wight
While the B+ spikes may certainly be doing something bad to the LED, I’d say that other factors probably weigh in more heavily. Dale’s shown that things such as batteries, bypasses, clean lenses, etc can have big effects. With all that ruled out my vote is on the heavy currents put into the LED: the LED has thermal resistance between the die and the thermal pad and there’s no getting away from it. More heat will result in an elevated die temp which I suspect will degrade the LED much more quickly than at Cree’s maximum currents. That said, I certainly don’t know. I’d love to eliminate as much bad behavior as possible, including the voltage spike on B+.
This PCB (v030) is not compatible with Halo’s idea. Click through and take a close look at the first graph since it’s easier to read. Each division is 1 volt and zero is 1 division above the bottom (where the little yellow/orange tags are). In post #365 the MCU trace is aqua colored. Note that Halo’s idea is to determine MCU VCC, but as we can see MCU VCC is never similar to B+ voltage. Instead, VCC starts at ~4v and then bounces up to 5v and tapers back off.
I’m impressed with DEL’s results from post #648 here and plan to try out an RC snubber.
wight
I implemented an RC snubber using 10nF and 4.7ohms and got similar results to those DEL showed: ringing was removed but the peak voltage on B+ remained pretty similar.
Maybe try a freewheeling diode next?
comfychair
comfychair's picture
Last seen: 5 years 2 months ago
Try the two-10uF setup, one before & one after D1. That helps with the bounce at B+, and also allows a tiny bit of boosting at Vcc (but with B+ flatter, the boosting is kept below critical levels).
wight
Tom E wrote:
wight wrote:
Thanks Tom E. * So that’s a 12k pulldown resistor on the gate? (EG the resistor is connected to the “gate” pin and to “GND”?)
Yes – 12K pulldown – it’s what I had available and seems to work well.
Well, I built a v009 today to install into a light I need to get rid of… and sure enough I ran into the “bright flash” issue you’ve been talking about Tom E. I didn’t do any measurements – I just installed a 0803 12k resistor as a gate pulldown (as you suggested). Problem solved. Thanks!
ToyKeeper
ToyKeeper's picture
Yes, it’s just an idea for potential future use. It might be nice to get rid of the need for the voltage divider, assuming the idea would work as intended. It would only work on 1-cell lights, and only on tiny25/45/85, but if those limitations are okay it might free up a little board space for other things.
wight
Gotcha, just wanted to make sure we were on the same page.
wight
DB Custom wrote:
Thinking of getting some V030 boards and building a few with ATTiny25 MCU’s, shall I? Tired of the issues I’m seeing on my triples and quads.
DB Custom wrote:
Ordered stencils as well, time to double check parts inventory… Smile
wight wrote:
I think they are functional enough for an advanced builder like you to make something out of them. As I mentioned above, my first test was a crappy one! You know the drill… no guarantees… you’re the official test pilot! Big Smile Big Smile Big Smile
(quoted a bit out of order Wink ) Bad news! I think that v030 should be usable for myself / DB Custom / Tom E… but I did make a mistake and forget about it when those two asked whether the boards were usable. I forgot to hook the 7135 up to LED-.
I reflashed my own built-up v030 board several times before the problem occurred to me. I just couldn’t get moon to light up at all…. of course not, it was on the 7135! I bridged the connection with a small piece of solid wire from a component lead and it works fine. The good news is that the stencils won’t change for v031, no pads have moved. Smile
Here is v031: https://oshpark.com/shared_projects/sDDHhEZk
Other topic: I do plan to revamp the spring side again. The current spring pads don’t seem to be a good match for the springs I’ve got. I’m open to input on spring sizes! Scraping’s always an option, but I’d like to accommodate 2-3 common sizes. My initial thought is [Nanjg-105 size], [common medium springs like the gold plated ones from MTN/Intl-Outdoor & the cheap Phosphor Bronze ones from Simon/etc], [big size? Like the ones djozz had made?].
DB Custom
DB Custom's picture
Last seen: 1 hour 30 min ago
And R1/R2 are still labeled in reverse?
wight
Crap, yes.
wight
Sharpie wrote:
Wight, I like the way you are taking this. Smile
Here are some suggestions for small tweaks to the layout:
1) Z1 could also be stacked on top of C1, if space is tight, maybe the layout could be shuffled a bit to make room for it alongside, with correct footprint.
2) Value of Z1 = 4V3 sounds a bit low to me. With a high voltage cell it could be conducting. Suggest 4V7 instead.
3) Footprint for 7135 could be re-done to include correct pad beneath tab, e.g. see the SOT089 footprint drawing at http://www.infineon.com/cms/packages/SMD_-_Surface_Mounted_Devices/SOT/S...
This would help improve thermal management. This part dissipates 646 mW with led Vf 2.5 volts, 380 mA, 4.2V cell. With a zener mod, running at 8.4V, and e.g. two LEDs in series, this could increase to 1.3 watts, which is a LOT.
It would also improve reflow soldering as the part could “swim” properly in the solder and align itself better.
4) The hole in the middle for spring bypass is nice, but I see that there is nowhere on the top of the PCB to attach the LED positive lead, if a bypass is not used. Also the only tracks connecting to it are narrow, not suitable for carrying such current.
I would like to use a solid brass post, rather than a spring, so it would be very awkward to attach the LED +V wire.
Suggest expand copper around the centre hole as much as possible, to provide some area that could be used for soldering a wire onto the top, with hole in solder resist to define this point.
5) Also add some more vias to connect this enlarged area of copper to the +V contact on the bottom, instead of just relying on the plating through the hole. Make at least one big enough to solder the LED +V wire through it, if desired, for lowest resistance. Maybe near the top left corner of R4.
6) Also consider adding a through-hole in the middle of the LED -V wire pad, so the wire could be soldered all the way through. This would require an isolated area on the bottom layer. Maybe keep it covered with solder resist (which could be scraped off) to avoid shorting against large springs, or the plated hole could be drilled out to isolate, if required.
7) If these two holes were available they could also be used to fit a large leaded Schottky flywheel wheel diode across the LED, if this turns out to be a good idea.
Regards,
Sharpie.
PS: I think, if the Zener plus C1, plus R3 work as I hope, that C1 = 100 nF decoupler would be sufficient, in fact better than 1 uF. R3 should not be shorted, some resistance here will reduce the current into C1 and Zener caused by the spike, reducing “pump-up” of C1. I.e. the combination will form a filtered supply rail for the MCU.
PPS: I’d suggest a starting point for the “semi defined” OTC might be 10 uF, with R5 at 100K.
I think it should be possible to increase the values of R1 and R2 to reduce parasitic drain, maybe from about 140 uA at present to maybe one tenth or even less. Just multiply the values by ten, or even more.
Thanks Sharpie!
  1. It could, but I’m trying to avoid stacking. (I definitely don’t see any space savings from setting them side by side.)
  2. Correct, I see in retrospect that I wasn’t clear – those were simply the parts I had available. Having so many wrong-size parts made it very difficult to assemble, but they were available and I didn’t have the right stuff. I didn’t purchase any new components for this build. My intention was to use something more common like 5.1v, although I was concerned once I saw how high the 4.3v Zener was able to spike. Maybe the load resistor will help – there wasn’t really enough physical space to install a load resistor in that build and test it out (due to the 0805 and SOD-123 stuff).
  3. Yes, I agree about parts of this suggestion. A fresh component footprint would help with locating the part while soldering, but that’s about it. Locating the part better while soldering is definitely worthwhile and a new footprint is on my list. The full footprint won’t help a bit with the rest, but that’s OK…
  4. I suspect that this PCB is quite a bit tighter than you may realize. Sorry that I have not posted pictures of the build and I’ve moved the only driver I built into a light now. Considering that the intention is to operate at high currents a small solder pad won’t really do the trick. My current recommendation for using a brass post is to drop your wire down and solder it onto the top of the brass post, exposed through the large 3mm via. I don’t see why this wouldn’t work fine. Since I also sometimes use brass posts I’ll try and give it a try. With that said, let’s put a pin in the topic of LED+ solder pad’ for the moment. If you’ll look at my other layouts you’ll see that I always strive to include good solder pads where possible. Unfortunately due to the nature of these tiny boards we just can’t have everything all at once. Once this board is tuned up maybe a different one will support a decent pad. Or maybe we’ll save enough space to do it here in the end. It’s at the bottom of the list for the moment though. Flat Stare
  5. Soldering the LED+ wire into a via is not the way to get the lowest resistance (that’s why we have a bypass hole!). A wire with 2mm jacket won’t fit in the suggested location and would block popular Pomona clip.
  6. I’m afraid that this will interfere with larger B+ springs. (Take a look at the Gerbers from OSH Park if you haven’t – you’ll see what I mean.) We can check measurements to confirm that, but for LED- wiring at least I don’t see an advantage to through-hole. As far as drilling out to isolate… I’ve often suggested a lot of scraping for various niche applications (or even some more common ones Sad – lesson learned) – if there’s no good reason to add drilling I’ll do my best to avoid it. Wink
  7. That’s a topic I’ve been trying to get a handle on. I’d love some insight into choosing the freewheeling diode. I read and understood your post about it needing to be located at the driver in order to operate properly (at all!), but as far as component selection I’m pretty far out at sea. Could you suggest some likely candidates and explain why they are good choices? Or link to some good reading material which isn’t too high-level?
RE:PS: That sounds interesting. I was planning on trying 100nF, but not because I understood what would make it better. Sad Could you help me understand why reducing C1 from 1uF to 100nF would be beneficial?
As far as not shorting R3 – I agree. Personally my plan was to put a value of 10R in place and then measure voltage drop with the scope to get an idea of what was going on in terms of current. Clearly it’s going to be a really spiky…
RE:PPS: OK, sounds like a plan to me. Can you think of any disadvantage of increasing the values of the voltage divider by 10x or more? Frankly I’m currently focused on the other stuff and may not jump on that part right away. Hopefully some other members will start playing before I do.
DB Custom
DB Custom's picture
I have solder paste masks and boards should be here tomorrow or the next day.
For sake of the argument, I re-built my Jax X6 Hunter tonight with a new MT-G2 on a 25mm MaxToch copper mcpcb. With brand new Basen 26650’s (came in today) it pulls 11.50A at the tail and makes a whopping 4571 lumens from the big die! And the hot spot is surprisingly tight, probably the tightest yet from an MT-G2 and I’ve got 12 now. (the BTU Shocker only counts as one, although it has triple 9V MT-G2 emitters, worthy of note due to it’s single A17DD-S08 Zener modified driver making 10,000 lumens. My other BTU Shocker uses a like driver to triple XHP-70’s for up to 20,000 lumens in one brief test. So yes, the large via for through board direct positive can be a HUGE deal!)
18 Ga Turnigy leads, I had to use extension tabs off the 25mm mcpcb to allow the reflector to sit flat down on the surface, this after having previously cut the reflector’s aperture square to encompass the big substrate.
Using an older 2 sided driver, big Vishay 07N02 FET piggybacked onto the original 22mm stripped driver board. Power, it’s all about Power!
Tom E
Tom E's picture
Oh No! Went to check my order status for the v030's, and there was none - forgot to order them cry. Good news is I can order the v031's, or should I wait on v032's?
Dale (off topic a bit) - how do you like the Basen cells? At first, I saw them beat the EFEST 4200's, but since then, measured in different lights and see the EFEST's beat'n the Basen's, but still head to head in 1-2 lights... It's all very confusing, then again, I'm only looking at tail amps via a clamp meter and not comparing @start and @30 secs lumens measurements, and we know slight amps differences don't mean the same for output.
Still love the Basen cells. My measured all 4500-4600 capacity at 1A discharge, but read someone else posted bout 4100 mAh tested.
Best cell I ever tested in a single cell DD FET setup? Ok, believe it or not, a TrustFire! Well, the TF 32650 that I stripped off it's PCB board of - got 0.5A more then the closest EFEST 4200 in a modded BLF SD10 (Lumintop) - incredible, to say the least...
That Shocker mods sound fantastic! My super high output light candidate will be the 16X XM-L2 bought here: http://www.ebay.ca/itm/121641867876, paid $94 shipped w/XM-L2 CW's. Did a pathetic 4K lumens stock, got it up to 6.8K now with resistor modding and heavier LED wires, spring bypass's. Plan is LDO 20mm FET+1 driver running an 85 w/Narsil, adding SMD LED's for LoBatt/Locator functions. Mainly went with this light for lots of LED's, 6 18650 cells (perfect for Sam 30Q BT's) for 8.4v, and a bighead diameter (99 mm) for better heat sinking and spacing to lay out and fit 16mm Noctigons. Will have to get a custom copper LED shelf built though. It's the same light as this: fasttech-SkyRay-S88 but with XM-L2's. Hoping for 15K to 20K lumens, with maybe a few mins runtime smile.
DB Custom
DB Custom's picture
SIR800DP yields best overall results, especially when the cell is low.
PSMN0R9-30YLD is close, but falls short with a low cell. PSMN3R0 can’t compete, at least not where max output is a factor.
ToyKeeper
ToyKeeper's picture
This would be a different driver design, but I was wondering if we could make C1 as large as possible and use one of the MCU pins as a battery sensor (interrupt on disconnect). The idea is to see if the MCU can continue running for a few seconds after the tail switch disconnects power. In the absolute lowest-power mode it might be able to last a few seconds with the biggest capacitor, assuming it can somehow prevent that power from draining out to the main emitter.
The benefit is potentially removing the need for the OTC. But I’m estimating a minimum power of like 5-10uA at a few volts, so it might need like 60uF worth of capacitor in order to last even two seconds. The largest I’m aware of in that size is 22uF, and I don’t even know if the MCU can go to sleep fast enough or turn off the FET fast enough to make the idea feasible.
Sharpie suggested it originally, I think, and it initially seemed impossible, but with everything completely min-maxxed it might be marginally feasible. If I did the math right.
wight
Tom E wrote:
Oh No! Went to check my order status for the v030’s, and there was none – forgot to order them cry. Good news is I can order the v031’s, or should I wait on v032’s?
Lucky, eh? I guess v032: https://oshpark.com/shared_projects/N0qhFri4
  • Corrected R1/R2 silkscreen.
Sharpie wrote:
I would like to see a lot more copper around the 7135, to spread the considerable heat into the PCB, and through it to the backside as well. The datasheet explains this. Using the standard footprint would help a little, but really you want more. I think that Manker/Banggood did this on their BLF drivers, ISTR when I looked at mine I noticed they had used all the surrounding area as one piece of copper. They are back inside the torches now, so I may have mis-remembered.
In this case practical experience is driving my decisions. A datasheet’s recommendation isn’t golden. In this case we’ve got a driver which will be clamped into a metal retaining area. We’ve also got a 7135 with a thick slab of metal on the bottom which is doing much more than a 1oz trace ever will. It’s simply not going to help. Whoever modified the v013 layout attempted to follow the datasheet for no good reason in this case – it’s as simple as that. They also didn’t even get close to what the datasheet recommends FWIW
Additional info:
  • 7135s behave very well when overheated. Even with the driver air-wired inside a big light I would not expect issues.
  • Current firmwares, AFAIK, generally run the 7135 at a very low duty cycle. It doesn’t really matter for the reasons I stated above, but I thought it was worthwhile to point out nonetheless.
Again, practical experience is what’s guiding me here. Take a look at the Nanjg-105 for another example where this is not a problem.
Sharpie wrote:
I want to use solid copper wires to the LED […] potting
There are several issues here. #1 is that this driver is not intended for your application. Certainly another layout can be done, but this one is simply not ideal. Square peg, round hole.
There is no sane place on top to solder a 1.5mm solid wire and not rip off traces. IMO a good match would be plated-through-holes sized for the 1.5mm solid wire.
I’m not certain what your overall goal for that project is, but this is a hotrod driver. The v030+ purposefully skips current-carrying BAT+ vias and depends on a spring bypass. Anything which defeats the spring bypass is outside the scope of the v030+ layout currently under consideration.
IMO DD/FET drivers may be poor design choices for the sort of light you are thinking of (potting etc generally indicates something which is not a hotrod). We wouldn’t use a hot-rod engine in a police interceptor car.
As far as not trusting the bypass wire… feel free not to trust it. It’s necessary if springs are used. Folks here are using it. The big 3mm via is specifically intended to make it easier for less-skilled folks to do a bypass which holds up better and longer… (while also allowing Dale to use 18awg }:-) )
Once we hammer the details out I’m sure that a layout for non-bypass applications will happen at some point. If nothing else we’d simply replace that center via with a pad and put many smaller vias on the board as I’ve done with other layouts.
Sharpie wrote:
I did look at your Gerbers, but I’m still having problems loading the drill file. I’m using GC Prevue. Could you suggest another free viewer ? (I don’t want a full layout tool (yet).
I use and recommend this free product: gerbv – A Free/Open Source Gerber Viewer It works quite well and handles the drill files properly.
Sharpie wrote:
Basically the flywheel diode needs to be peak rated for the same current as the LED could take. When the FET turns off, the inductive energy in the leads etc. can circulate through the diode and the energy dissipate in the LED (more light). The maximum inductive voltage spike would be limited to the Schottky diode forward voltage, i.e. well under one volt.
Initially I plan to try some that I have raided from a broken computer PSU.
I suppose that there are also leakage specs that should be considered?
Sharpie wrote:
Adding the LED bleed resistor has made this much worse in the current design. But in this new design we have the opportunity to use C1=10uF again, but now it is isolated from the bleeder by D1, so could provide substantial holdup.
Also consider that the clicky switch contacts may be expected to bounce on closing, for quite a long time (milliseconds or longer). And get worse with age..
I guess we will have to try 0.1, 1 and 10 and see what works best.
I suspect that 100nF will work. We’ll see. The bounce is a good point.
Sharpie wrote:
I think R3 is key. It needs to be high enough to limit the peak Zener current to a level it can still handle, and regulate MCU power supply to <5.5 V. It doesn’t matter at-all what happens to the spike the other side of it, there are only a couple of resistors there.
There isn’t a lot of current needed to supply the MCU. The dominant power in operation is driving the FET gate capacitance. The MCU pin s rated to drive 30 mA ISTR, so 10R sounds a good start, it would only be dropping 0.3V at this sort of current, which would mostly be coming from the decoupler anyway. And even say a 20V spike would be clamped by the Zener, with a peak current of 1.5 A
Come to think of it, if C1 was e.g. 1 or 10 uF it could be relied on to source the current to drive the FET gate edges. R3 could then be increased greatly. Maybe 100 ohms or more.
One thing to consider is that while the MCU pin may be rated for XX mA, the FET gate could easily get much much more current than this during the turn on. I suppose that it’s kind of a moot point since we’ve got C1 though…. hmm.
Sharpie wrote:
I still think, if we are lucky, D1 C1 R3 may “pump up” to the zener voltage, then stabilise (as long as the FET is being PWMed a tiny bit), resulting in a steady approx. 5V supply to the MCU, even at low battery voltages. With the great advantage that this would let it drive the FET gate well past threshold voltage, into full saturation.
Two points here:
  1. We really only need full saturation while we are at 100% duty cycle. Anywhere else who cares? 100% duty cycle is where we get no boost at all. If we were having a problem getting the gate voltage high enough during 100% duty cycle I suppose we could drop it to 254/255 but then again… if this was a problem we’d have noticed hot MOSFETs by now. Wink
  2. FWIW the SiR800DP kind of makes this a moot point too. That thing is ridiculous.
Sharpie wrote:
As we know, the input resistance of pin 7, when configured as an analogue input is very high, so you should be able to get a good voltage measurement with quite high values in the voltage divider. The actual impedance of the divider is R1//R2.
Mike C mentioned in the Attiny25/45/85 FW Development Thread that “The voltage divider resistors are much higher than “regular” ones” in his design, perhaps he could advise ?
PS: I like Mike C’s choice of NXP PSMN3R0-30YLD FET very much.
Good point, Mike C would be a good person to ask. I selected PSMN3R0-30YLD myself back when I released the A17DD-SO8, but better FETs have been found for our applications – See DB Custom’s post #381 on the topic. FWIW I believe that Rufusbduck picked out the PSMN0R9-30YLD and comfychair picked out the SiR800DP. My testing earlier in this thread was done with the PSMN3R0-30YLD because that’s what I had – it’s not bad.
I’ll take a closer look at the WP article, thanks. I see that it touches on the important design considerations.
We can look into a design for that, but I think it would be worthwhile to just airwire it for now. That might give us a better idea of feasibility & etc. Once a more concrete range is known for the C1 value we can attempt a fresh layout with an SMD larger than 0805.
comfychair
Did I? I don't remember, but I only have a bookmark for the SiR404DP. Did anybody ever try that one?
DB Custom
DB Custom's picture
I think it was me that found the SIR800DP initially, based on what Wight told me to look for in the spreadsheets. Then Richard looked at it and tried it, found it to be spot on, and it became the de facto standard for some of us.
I used 16 ga for the first time tonight. Wink
This is actually an MTN 17mm driver with the positive contact in the middle.
wight
comfychair wrote:
Did I? I don’t remember, but I only have a bookmark for the SiR404DP. Did anybody ever try that one?
Hmm… so you did.. I see that we had a PM conversation covering that topic called ":-) retaliatory try this! :-)" back in October 2014.
So… in that case who identified the SiR800DP? Eh, apparently me heh… at the time I found it I must have recalled that PM conversation and thought that SiR800DP was the one you showed me. (FWIW note that I later realized that the SiS414DN which I mention in that post uses a different package / eg is unsuitable.)
I’m certain that I have examined SiR404DP at some point, but I couldn’t tell you a thing about it right now. :-/
EDIT: And DB Custom (then DBCstm) must have done the leg work! I certainly wasn’t shelling out $2 for an FET at the time. Wink
DB Custom
DB Custom's picture
I bought my first 5 SIR800DP from Mouser on Dec 15, 2014 for $1.83 each. Wink
With one left in my kit, I have used 114 of the SIR800DP since that first purchase. Wink
Used a lot of PSMN0R9 and 3R0 as well, and a few Toshiba thrown in for good measure. Wink
wight
Where’s the smiley with the big, wide, and alarmed eyes when you need it? Good stuff DB Custom.
I vaguely remember the Toshiba ones.. they had a unique package with more metal involved. And maybe they cost around $3/ea? I dunno.
I bet that you’ve assembled more drivers in one day than I have total. Wink
DB Custom
DB Custom's picture
The Toshiba had a second metal plate on the top, not to be used for current but to be connected to a thermal mass.
I just did 25 in 2 panels the other day. Love doing em on a panel, looks so cool! Richard, now, is really REALLY making some drivers!
Sometimes I just do one, I have a small piece of sheet copper that I clamp in short straight stats and hold that in my vice, apply the soldering iron underneath. Occasionally I’ll reflow an emitter that way as well, if just doing something simple and quick.
Edit: Might be worthy to note that when I was just starting to populate those 25 boards it was storming and our lights went out. I used the 10,000 lumen BTU Shocker with triple 9V MT-G2s doing a ceiling bounce to be able to see to populate em. Later, when we got electricity back, I re-flowed them simultaneously on the stove top. Wink Yet another light with a AW driver in it. :bigsmile:
DB Custom
DB Custom's picture
For the record, the tiny 10mm FET’s with MMU and crazy small MOSFET’s are a PITA! The MMU has to be re-flowed onto a programming chip board, then taken off and put on the driver. All 7 components, virtually the same as our normal drivers, fit on a 10mm board. Those can drive ya bonkers!
comfychair
Hey Dale, since you're up for seemingly absolutely anything, try the SiR404DP. It's got only about 2/3rds the resistance of the 800DP!
I'm just not sure about the gate charge/capacitance specs and whether it'll play nice when driven by a dinky little MCU.
DB Custom
DB Custom's picture
On the way, should be here Thurs or maybe Fri.
Edit: ie, SIR404DP
Mike C
Mike C's picture
Last seen: 5 hours 16 min ago
comfychair wrote:
Hey Dale, since you’re up for seemingly absolutely anything, try the SiR404DP. It’s got only about 2/3rds the resistance of the 800DP!
I’m just not sure about the gate charge/capacitance specs and whether it’ll play nice when driven by a dinky little MCU.
Yet another FET that isn’t available where I buy components. Any thoughts on the SIRA00DP? I can get that one, and it appears to have pretty low resistance too.
