Well doing a triple always adds cost and a bit of time. I think you can get plenty of flood from a single optic, and if you want better color rendition you could always just swap the emitter for a single Nichia.
I won’t keep trying to talk you out of a triple, it just don’t think you’ll gain anything from going that route except for maybe some “cool factor”
Yes, but in this case a single-mode driver shouldn’t have any trouble at all
Thanks again for all of the advice, much appreciated!
I’m liking the size of the 18350 version S2+ for this application in blue, but it appears only the gray and black come with the rubber tailcap. So, to lego something together in blue I’m looking at the following items for the host:
For the LED driver, it would be nice to get a flood with one low light mode (like 10-15 lumens or less). I’m looking at a Nanjg driver with one 7135 chip (380mAh output) programmed with guppydrv which can be set to one mode at 100%.
LED/Driver/Optic =
LED - re-use XM-L2 that comes in gray S2+ host Optic - 60 Degree Flood Nanjg Driver w/ guppydrv firmware and (2) 7135 chips removed
I don’t know if you can flash drivers, but if so, you could use ontime-based firmware which wouldn’t require a bleeder resistor and would thus give you higher efficiency and runtime while the light is on.
I’m not aware of a way to make guppydrv run with only one mode if you want that mode to be lower than 100. A single 7135 chip at 100 will make like 140 lumens, not 10-15 lumens. However, a couple simple changes to STAR_1mode could make it run at ~12 lumens instead of full power. (Basically, comment out “MODE_TURBO”, uncomment “MODE_LOW”, and set it to like 20. Maybe set LVP_MIN a bit lower too.)
Thanks for the tips - sounds like not too many people want/need a nicer tail lit light with only one low low mode :).
I’ve done some programming and similar work, abut never flashed flashlight drivers. That said, I’ve looked into it a little and I believe I could give that a go if there is not an “off-the-shelf” firmware solution that will achieve the desired results.
I follow your code comments above and found the referenced file in your linked repository - thanks for your contributions to flashlight firmware! One part that lost me above was the term “ontime-based firmware,” can you explain or point me in the direction to what this means? Is Star_1mode ontime based?
Oh, ontime-based means it decides on how to change modes based on how long the light was on, rather than how long it was off.
It’s easier to understand offtime-based lights. You turn the light on, it comes on. Tap the button quickly and it goes to the next mode. Turn the light off for a long time and next time it’ll come on in the first mode again (unless you have memory enabled, which will make it come on in the same mode as last time).
With ontime lights, it doesn’t know how long it was off, so it does something else. If the light was activated within the past second or so, another button tap will advance it to the next mode. After a second passes, it “locks in” and the next press will make it go back to the first mode (or use memory).
This matters because the lighted tailcap tends to interfere with the offtime measurement. The tail pulls current through the driver even while it’s off, which prevents the components from discharging normally. So we add a bleeder resistor to let this current pass without affecting the rest of the driver. That works, but it has the side effect of reducing efficiency while the light is on.
With an ontime-based UI, the bleeder is unnecessary because the driver doesn’t care how long it was “off”. You can use a lighted tailcap with no bleeder and it won’t break the interface. The main consideration there is that it might have higher resistance while using the whole driver as a “bleeder”, so the tailcap resistor values might need to be tweaked differently.
Anyway, it just means, since you only want one mode, you can get higher efficiency by not using a bleeder. But it requires using firmware that doesn’t care about measuring “off” time.
Got it - thanks for explaining, that makes perfect sense.
It’s about time I learned something new, so I’ll set myself up with the SOIC8 clip and programmer to flash the chip. I’d like to go with an ontime based UI and avoid the bleed resistor, I skimmed the code of Star1_mode, but nothing jumped out at me - is this firmware ontime based or can you point me towards a suitable (one low mode) firmware that is?
Not that you need ontime or offtime for a 1-mode light. It’s just the only 1-mode firmware I’m aware of. Someone wanted to modify STAR for this sort of thing a while back, and the changes ended up being somewhat non-trivial, so I made it available as a separate project. It could definitely be, um, smaller, though. Not much logic needed for a single mode, so a lot of the code in it is unnecessary.
It defaults to only using turbo, with a turbo step-down or ramp-down, but that’s not hard to change. It also has low-voltage protection, which is probably a good thing to leave enabled.
Great, much appreciate all of the detailed information. I’ll plan to use a STAR_1mode slightly modified firmware and forego the bleeder resistor.
I’m looking forward to this little project as well as learning the flashing process for these Atmel chips. I’ve studied up and downloaded all the relevant software - I appreciate the code and guides you and others have provided over the years, there’s a wealth of information out there!
I’ve got the programmer, clip, and all of the flashlight/tail parts pieces on order. I’ll keep this thread posted :).
Someone suggested leds like these way back in this thread and I found some at tme-eu, but without documentation what they actually +do+. Hoping for that slow fading rainbow effect, I just made the lighted ring. Well, I just found out what the effect is, so far for the slow fading , I'm not sure if this one is going to make it into a flashlight
I wonder how obnoxious the fancy “smart” tailcap is, with the defaults on the code I made for it. It, um, spins. But it only spins for a short while before it picks a color and goes into beacon mode.
I haven’t checked out this thread in a while because I didn’t have anything to add.
First, let me say that I love the three matching colored S2+ tails!
Second, is a bit of news. I asked Simon if he could have the internal seals changed from the existing black rubber to clear.
He is instructing the factory to do just that.
If I’m not mistaken this will allow you to have your seal and light it too!
I used pictures posted in the SS switch thread to explain what I was talking about to Simon. I told him that the black inner seal or seals had to be made of a clear or translucent material. I see the one main seal in the first picture below but is there a second? Can you guys have a look at what I sent and let me know if you think those two pictures cover it?
Edit: The sooner I get confirmation on this the sooner I can get this in motion…
Thanks jdub, and that’s good news! There’s only one seal. That upper black bit is just an oring and it’s not exposed when it’s all put together. No reason to change it. I’ve been replacing my gasket with some bits of disposable painter’s glove. It works pretty well, but it can’t be nearly as resilient as a solid, thicker gasket would be.
It’s still very early in the process but I already asked Simon to make some extras if he can work out the “clear” seals. I don’t know if it would be just extra seals made available or new switch assemblies but the seed has been planted on behalf of this lighted tailcap effort. There is also a new black stainless switch sample in the works that should incorporate the clear seal from the start. That’s just moving past the conceptual phase though so some time will be required to work out the details.
It is in my EDC now for checking out how annoying it actually is, and that is a confirmative 8-|
But the brightness is regulated by a 50K Ohm pot easily adjustable through the tail spring, so I could make it very dim and that pot also has a position which turns the tail leds off.
The leds came from tme.eu and have a inbuilt alternating slow and fast party-sequence. The six leds start synchronised, but within a minute it is this random psycho-stuff
