I have no doubt these will be great performers again. I also have a bunch of eneloops, but these ladda’s are at a great price level and easy for me to get. For true “life or death” situations I’d trust my eneloops more, but for the rest I have no problem abusing the ladda’s.
The previous version did a great job and even outperformed eneloops with a slight margin at lower currents (I believe eneloop won at 1A and above, or maybe 2, not sure)
I don’t think I will give these the same test as I did with the previous version, so I hope HKJ will test this new version.
I will post some close up photo’s later.
Busy day, still have to get them out of their packaging.
It would be interesting to see how they perform at currents of 5 or 6 amps. My Zebralight SC5 uses that level of current on max, and I’ve found that Eneloops handle it well. If Ladas can do that as well, I might give them a try and see how they stand up to abuse (high drain, fast charge).
Picked up a few packs of the green and silver Laddas today from Ikea Springvale, I couldn’t find any AA with a date newer than 2013. The staff member I spoke with was surprised I knew anything about the new cells and chargers and said Aus should get them within a few weeks of Europe, but when he looked it up on the computer he acted kind of weird and said there was no eta.
Not sure if it has been mentioned, but the manufacturer of the green and silver cells is BYD Company Limited.
Thanks,
the very same structure of the bottom surface as Eneloop pro. Even the angles of the wrapper edges are the same. Same venting holes. Date codes at the same place. Same specifications. Japan.
The only difference I can spot is the color of the top ring and of course the wrapper text/color.
I’m ready to beleave they are really FDK made = Eneloop.
Very exciting!
Lol, I Just noticed the date code embossed on the batteries. When I read the comment I looked at the wrong numbers. Couldn’t figure a date out with them but now it explains why.
Enhanced them with a pencil.
1541-S3
1540-SX
I think 2015. week 40/41
Don’t know what S3 or SX should mean.
I’m just worried that some MAP police will stop the feast before I can buy them in my country. Eneloop is FDK’s own brand, at least there is a giant sign on the (rear of the) FDK factory with an Eneloop battery (Google Earth street view).
Edit: I must admit that it was about 3 years ago, I saw that factory with Eneloop sign, seems they have changed residence, now residences!
Just bought 4 new one’s in the same Ikea location as the OP. They all came in at exactly 1.32 V. Currently testing, results tomorrow.
First run, charge 1A, discharge 0.5A, discharge capacity: 2670 2631 2611 2590 mAh.
Second run 2646 2650 2673 2730 mAh.
Resting voltage 1.38 V.
Very high capacity, hope they last and keep voltage.
I stop running now and start cycling, so this is it for the time being.
