Test / Review: (OLD) Panasonic NCR 18650A 3100mAh batteries $11.96 Protected and $9.97 Unprotected (OLD)
187 posts / 0 new
ChibiM
ChibiM's picture
Last seen: 9 hours 37 min ago
yeah... give us some info.. I think they will be high on everyones list!  3100mAh... wow
edc
edc's picture
Last seen: 6 years 9 months ago
I peeled a cover off mine. Says ncr18650a  lion MH12210. Made in Japan.
Has
N1B
D76
CBN
on the side.
Same battery as in photo and same battery other sellers use.
http://i1193.photobucket.com/albums
Zenbaas
Last seen: 3 years 3 months ago
So what is the verdict on these....?
okwchin
okwchin's picture
Last seen: 1 year 3 months ago
Promising?
"like everyone else - I’m looking for my next “last” flashlight" -  ohnonothimagain
benckie
benckie's picture
Last seen: 9 years 4 months ago
Yeah waiting on a mAh and so on
yavi
Just received 4 batteries, I am charging them so I can't tell the results yet.
My first impression is they are really good wrapped, they have got a thick plastic that should last a lot more than many others like Trustfire flames or even Hi-MAX.
Here some pics:
edc
edc's picture
They are the same batteries sold by Kallie's customs (yes I checked the pics on both websites) so they are good.
PickNickeR
Last seen: 7 years 2 weeks ago
I've received mine this morning. They look well put together and almost identical in size to my Redilast 2900mah. They have the same type positive button too. They were resting at 3.65v and are now on charge. Will to a rundown test later compared to Redilast 2900mah.
The best light is the one you have on you when you need it.
Solarforce L2T single mode XML T5 3C 1.75A
Hikelite
Last seen: 6 days 3 hours ago
Cycle them 3 or 4 times. The capacity will increase, only very slightly, but will increase. Since your Redilast 2900 are already cycled  you should do the same with the new ones you've got.
2100
Tested sometime back the NCR18650A from HKequipment.   http://budgetlightforum.com/node/4008
yavi
Thanks 2100, knowing your review about the unprotected we can now check the differences with protected ones, such as the minimum voltage they will cut at, and the maximum amperage they will allow for high power demanding leds, but I am affraid the most powerfull I have got are the XM-L, I do not have any SST-50 nor SST-90.
robertkoa
Last seen: 1 year 9 months ago
Yeah- just got a Redilast 2900 about 10 days ago and the top is similar- a button but flatter since the cells are a bit long already.
My Redilast has a gold colored negative ( bottom ) side.
I agree the wrap looks nice and thick on these- if they are really 2850-2950mah plus   ( and are new )- a good deal.
Has any cell or brand ever  tested out to above 3000 mah ?
Edit - just read test results linked earlier in thread -over 3000 mah !
PickNickeR
I ran a protected 3100mah in the SC600 at 500l for 2h 10min. They were at 3.05v when measured a minute later. Does the SC600 feature a low voltage cut off or were the cells just dropped down below 2.5v under load? Tomorrow I try the same with Redilast 2900mah. This is just for rought capacity comparism. When I charged the 3100mah's they terminated at 3.17v. I have a good feeling about these. I think the 3100mah is fairly acurate. I don't think the Redilast lasted even 2h with this light when I last testet and given the 3100's being new...not bad. Very good package and value for money.
robertkoa
edc wrote:
took a bit over 4.15 hrs to charge at 1000 mah from 3.6 to 4.13 v.
4 hours and 8 minutes @ 1 amp = 4000 mah-Put an Ultrafire Label on it !  Just Kidding.
benckie
benckie's picture
I still would like a mAh, IR, maxium draw and a LVC test from this seller as any one can print a lable, they should go down to 2.5v going by Panisonic.
edc
edc's picture
except the xtar charge rate slows down as it reaches capacity. I don't know why people doubt these batteries. They are the same as Kallies with a different label. I seems I tore my label off for nothing. Cry It was damn hard to get off too.
from Old's review
Lets look at how the charger behaves :  Lets start with the 1A setting
I was using two batteries Bat-1 @ 3.03v and Bat-2 @ 3.4v to start ...  Both channels were doing 1A
I was monitoring the charge rate as the batteries charged , and at 3.84v the charge rate had dropped to 800mA
At 3.99v the charge rate was down to 500mA
At 4.07v it was down to 300mA
At 4.12v it was down to 140mA
And the charge terminated @ 4.14v [ tested battery voltage ]
benckie
benckie's picture
would like to make sure they are the same batteries and the IC's are good.
it seams no one has been able to mention the how many amps the pcb,s (ic's) can take before it cuts in and if the lvc works well and i have not noticed all mAh test on these cells from this seller yet.
i might be fussy but this is a new seller and things likr torches and brands have been copied before, im sure they are fine im very keen to buy a couple but just waiting for more info, i was hoping to buy some tonight.
bbb0777 wrote:
Possibly a dumb question but - compared to AW:  How are Panasonics?
All I admittedly know is CPF: AW, etc.
same stuff diffrent bucket
bbb0777
Last seen: 10 years 8 months ago
Hikelite
yavi wrote:
I ordered from this website the protected panasonic 18650*3100mAh, I will update here if you don't mind to let everyone know how good is this seller doing it.
My first impression was good, with a quick response to an email I sent them, and by the way they are much cheaper than redilast 3100 and Callie's Kustom.
What I asked them was about the protection circuit, to make sure it can manage to give 6A and they confirmed it.
benckie
benckie's picture
i had a car sales man once told me the car could do 50 mpg but it did 20 mpg
screw it ill just buy some an test them for myself
2100
Benckie, i think if i insert them fully charged into the DRY, them XM-Ls will pop!
Sanyo 2600s already went way past 5A.  BTW actually the Sanyo 2600s are able to get me higher amps than the NCR18650A.
Even SST-90 lights like Elektrolumens ST90 do 4 x 18650 in parallel to draw 2.5A.
The high current incans, well they managed to even pop the green Sony Knion (sp) IMRs.   Stuff like the 250W TK Monster.
yavi
benckie, I can tell as much as I had been told, which by the way is what the seller said.
I tried yesterday measuring the power consumption from an XM-L, but I think there is a problem with my tester, I had no more than 3A with any battery I checked it, but I had recently 5A from the Hi-Max and 4 from the trustfire flames, but now all of them are giving about 3A, so I think it is my tester's fault, I will check replacing its own batteries.
I will let you know if it imrpoves after replacing the batteries in the tester.
IF in the worst of the cases, it can only handle to give about 3A, it is not that bad for me as I have some Direct drived XM-L flashlights, wich I would not want to toast at 5-6A, the most important thing for me now is their runtime.
benckie
benckie's picture
Thanks yarvi.
Today I brought a couple protected ones to try out.
thommy
Protected arrived today.
These are really long/fat batteries.
They don't work in my TM11 and don't fit in the DRY battery carrier.
Almost the same lengt as the Xtar 18700 / 2600 mAh
benckie
benckie's picture
The website has been down for a while for me any one else ?
Has any one done any test of these from this seller yet ?
I ordered a pair of protected 3100 on the 16th of november it will be a week or two before i get them.
bugsy714
Last seen: 10 years 7 months ago
got mine today, pcb trips on my 5.6 amp dropins but not on my 4.2 amp
Hikelite
Welcome to the forum, bugsy714. I hope you will participate more in our discussions around here.
Are you sure you DMM is measuring accurately. 5.6A is a high current, the higher it is the harder to correctly measure it because the leads length, thickness and resistance. It is possible that the currents to be higher than 5.6A.
Even with with stacked AMC7135 chips the current can differ . For example they are rated 350mA per chip, but if you look at the manufacturer specs you can see they are rated 340mA to 380mA.
bugsy714
No DMM, just my 5.6 amp regulated kenji quad in a c2 with a mcclicky (the mcclicky should provide some resistance as well).  It does the same in my VIDSM copper quad 5.6amp uunit with a fettie switch
When I put them in my 6p/mcclicky 4.2amp regulated VIDSM light they run fine.  I'll be taking a walk and timing how long these can run my quad on high, an AW IMR 18650 is about 25minutes @5.6amps so I'll be hoping for a lot more runtime at 4.2amps =)
ChibiM
ChibiM's picture
Hank has told me he will release their official test reports of these batteries soon!...
bugsy714
the runtime is noticeably longer than my trustfire flames
