I did come across that thread when searching for previous similar attempts. And no, I did not laugh. I actually tried something similar with good old transistors about 10 years ago, trying to put a touch sensitive switch on a project. But I’m getting off topic now so I’ll spare you the details of that failure.
My first build failed. Nada, nothing, zip. I have a short across a couple of components due to not having proper sized smaller parts. Will punt later. Today has been a grandpa day, 1st time for everything I suppose. They don’t know it yet, but I sprinkled some small resistors and XP-E2 emitters in the diaper bad, see if anything grows there…
Though I admit that I am week at circuit level electronics, this isn’t an FET from a typical budget flashlight that overheats if you take its series resistor out. It is bigger than the LED and, properly cooled, it should be able to absorb a comparable amount of power. I didn’t get this out of the blue. I don’t remember which thread but the EE who suggested a gate resistor said it could absorb power. If the gate resistance of the FET is high enough, then probably a gate resistor is better, using the FET’s gate capacitance.
I have tested it with the big beefy TO-252 Vishay 70N02 and it gets hot enough to burn you. FET hasn't died yet, but what kind of a reduction in lifespan would be acceptable to you, to get something that can be had by other means that doesn't cause components to fail?
I’m real happy with using PWM level of 2 on the single 7135 of a FET+1 driver. I can now set the moon mode PWM value via the UI from 1 to 7 in my latest Narsil version, and 2 has been working well so far, even on a low cell. It’s soo nice now to set the PWM level of moon via clicks to see the differences easily, in the the light.
Nice. I always end up having to add a bunch of moon modes then test them in a light box to figure out which one works best, then remove all but that one. I can get it reasonably close just by shining it next to a reference light, but the light box is still necessary to make the final choice.
A value of 3 seems the best for the lowest, stable value for a 350 mA 7135 and that’s what I’ve been using lately, and I’ve found you have to raise to maybe 5 for a 380 mA 7135, so I’ve been using 350’s now exclusively. What value to use for moon mode has been bugging me for a long time, so best to make it configurable, just wish it was easier in the UI to adjust. Right now it’s in the configuration settings, but would love to be able to tweak it while in moon mode. Sometimes I like it super low (2), other times 3, or higher at 6 or 7 is nice to have. Should treat moon mode as a separate state with it’s own button actions.
My configuration settings are now stored in 3 bytes to cover the 10 different setting values.
It also depends on the exact 7135 chip and the emitter, and even how many. Some 350mA chips work better at PWM=2, others work better at PWM=3, and the 32x7135 SRK driver lights up even at fast PWM=0. Older emitters require a higher PWM level than newer ones, usually. The highest I’ve seen was an old XM-L which needed PWM=9.
If I have an e-switch I don’t bother with specific modes. I just use a smooth ramp from moon to maximum. On a single-channel driver (or tiny25/45/85 FET+1 with a slightly different pin setup), the low end can have extra-fine adjustment by using PWM+PFM, so you can get lots of precision in the moon range instead of just a couple levels. I haven’t actually seen a driver set up with two channels on independent PWM counters though, and now I kind of want one.
Some happiness arrived in the mail yesterday. Those 0805 SMD pads look soooo tiny.
I’m ok with learning to reflow the one sided boards but how do you reflow a two sided board and not lose all the parts off of the other side?
Is it time to add a hot pencil to my soldering station ?
Surface tension of the solder is greater than gravity. They stay floating in place on their pads just fine. Unless you bump it while the solder is still liquid. A big heavy part with small pads can sometimes fall off, but that's why you do the side with heavy parts last (or hand-solder them afterwards).
The other less sophisticated method that I am considering is to place the populated boards on a solid bar of copper and heat from below with a torch. Then again, maybe the copper bar would only work good to reflow LEDs.
Spend the ~$50 for a hot air station. Search Amazon for '858D'.
Hot air is so much more versatile than an oven. You can heat just one area and pluck off one component without disturbing anything else or re-melting all of the solder on the whole board. It's also easier to control the total heat input - time can be just as critical as temperature. With the board right out in the open in front of you, you can watch the paste flash over and then remove the heat right away. Hard to do that when it's inside an oven.
About fifteen years ago I bought a Weller WSR1002 Rework Station. I never purchased the hot air pencil for it. It’s dis-continued model now so I don’t know if I can find hot air pencil that will work with it. The 858D looks like a lot of tool for the money so that’s my backup plan.
I’m not personally familiar with the industry, but I believe that mass produced boards are sometimes done using two different temp solders. Neat-o.
Personally I do my reflows using a large 1500W heat gun - mine is the MHT3300. Those run about $40 and are good for other types of project. They are definitely not as flexible for soldering work as the little stations. I do own a hot air station, but never learned to get the proper use out of it. Since I’m space constrained it’s in storage, unlike most of my other soldering gear.
At the end of the day hobby reflow will probably still require skilled soldering touchup - especially as you learn the ins and outs of reflow. It’s quite possible to solder the entire boards by hand, take a look at my videos here: Nanjg stripping and A17DD-SO8 building videos
Any idea if it would run on a 15A 120V circuit which is already at ~30% capacity? Some reviews suggest it may need its own dedicated circuit or even a 20A circuit. Pretty big change from my weak little 40W soldering iron.
1500 W = ~12.5 A and the fan motor may also create an additional inrush current at start.
So a 15 A circuit may give you nuisance trips, especially if there are other stuff on the same circuit. You are also not supposed to load a breaker above 80% of its rating. That said, I use a 12.5 A generic to shrink sleeving and flow the occasional emitter, no issues on a 15 A circuit.
Sorry, been way behind on this, so just ordered my first set of v032 boards. I took a close look at MCU pin#3 and looks like it’s connected to a pad covered over by the solder mask, but that’s fine - easy enough to scrape off, and I no longer would have to solder a wire direct to the MCU pin.
Somewhere above it was mentioned to use R1/R2 as 10x the values — this would be great to cut down parasitic drain, which is a problem I’m trying to address. How would this work exactly in the voltage divider, and the values to use in the firmware? Anyone try this or should it work ok?
Depends a lot on the type of circuit breaker or fuse. Some large 15A breakers will easily supply 20-25A forever. The slimmer type, especially if next to another loaded circuit, may not fare as well. I used to have a microwave pulling 19A (official rating was 1500W…) on a 15A circuit together with about 2-3A of lighting. The lights would dim when using the microwave… but the breaker never tripped. The only sure way to find out is to try it.
