question-do you give on optik also o ring?
No I didn’t.
so i bought one…anyway-the fet driver,i used from astrolux did this-after maybe 30 seconds it dropped from fourth-turbo mode to the lowest……i fought,it will drop to mid or high…is it normal? also -do you think,that the heatsink has sense? except the thing,that there you need something for the free space-under the star….
While I’m not sure about that exact driver, my triple does drop from 100% down to 25% brightness after 30 seconds.
And it does not sense temperature.
well,i will test it again and again.anyway-i bought two triple stars xpl from KD…neutral and cool…and-they are almost the same colour…unlike the astrolux 1A and 3D xpls…they are pretty different.this not…sadly.resume is,that i think,convoy s2 is better host for this legendary mod,than BLF A6 host.next week i will try another host…will see.anyway,my far most beloved edc now.LOVEE IT
https://www.fasttech.com/products/0/10002463/1311101-convoy-s4-diy-edc-led-flashlight-host
this could be also good adept for triple xpl modding?anyone tried?i think,this is better cooling…
please,can anyone,who has this spacer send details? parameters…thank you very very much
What parameters? The dimensions are listed on the page. Also, the S4 is not a great candidate for a triple because of the slots in the head
aha.ok…i need to know how deep is the part inside the flashlite…the tinner part of it.how deep is it…
ok…s4 i will forget…
question-imr or unprotected…what is better for flashlightes like these?
IMR is a chemistry. Unprotected means no protection circuit. IMR cells are usually unprotected, but they don't have to be.
yes i know.but,what i better for flashlightes like triple xpl?for one cell
Depends on the LEDs, but for everyday use I typically like to use the 10A rated cells like the NCR18650GA or LG MH1/MJ1 because they have more capacity and the triples have a very low vF so they still run good. If you want all the power you can get in short bursts, then use one of the super-high-drain batteries like the HE4/25R/30Q/HG2/etc.
well.my first triple xpl in BLF A6 gets problems…first-it started to smoke after few seconds in turbo…i dont know why….second-the wires disabled from the pcb…we used two kinds of the tin,used also soldering flux… but…is it posisble because the heat??:cry:
dont you have problems with your triple friends? btw-i bought the triple on board from kaidomain…not noctigon and i use aluminium spacer as a heatsink:)) its not from Richards website…could be this also the problem??
The smoke is the flux starting to burn. This means that the MCPCB is getting way too hot. When the wires desoldered from the PCB that means that you got it up to extreme temperatures. Your heatsinking is very poor.
Buy a triple noctigon ASAP …
Once you get it in your hands , you will understand the difference .
Also , did you use thermal paste between the parts ?
Noctigon is a must for a triple.
Same as everyone else is saying: the aluminum board from kaidomain is not suited for high amps. Maybe swap in a different driver.
yes i used thermal paste…but probably very cheap:) heatsink is alluminium….the same as many people use here.and maybe,the KD triple board is also the problem….cos i see,many people have this legendary triple and no problem…so something must the the error….thanks for all your kind advices friends:)
ok.people,now i understand…sadly,too late.could be using dedomed xpl making this project more throw? or-is there any other optic,which can make the triple more throw than the carclo we use?:)thanks
