I received my order from HengSheng today (ordered on 3/30/2016):
![](http://i278.photobucket.com/albums/kk107/golfrt1/IMG_3074%202%202448%20x%201836.jpg)
Gerber 342, 65mm blade, 3cr13mov steel, steel handle, quick opening, frame lock
Kershaw 1730ss, 76mm blade, 8cr17mov steel, bead blast steel handle, SpeedSafe assist, frame lock
Kershaw 3800 Shuffle, 53mm blade, 3cr13 steel, nylon fiber handle, liner lock
Comments:
Gerber 342: http://www.sh0142-hk.com/gerber-342-steel-shank-quick-opening-match-color-box-p-589.html
Nice, pocketable folding knife. Spring-assisted opening. Sharp, shaved the hairs off the back of my hand when I tested it. Frame lock took a bit of effort on my part to close, somewhat stiff - but manageable with one hand.
Kershaw 1730ss: http://www.sh0142-hk.com/kershaw-1730ss-8cr17mov-allsteel-titanize-oem-p-822.html
Very nice, 76mm blade hits my sweet spot. I like knives 75 to 80mm. Spring-assisted opening, well-balanced, fits my hand well. It came sharp (I lost enough hairs testing my Gerber, so I didn’t repeat that test). Good looking knife, I like it a lot. Negatives: pocket clip is “vise-grips tight” and almost impossible to use. And the frame lock is extraordinarily difficult to open with one hand. Even with two hands, it takes a bit of effort to pry open.
Kershaw 3800 Shuffle: http://www.sh0142-hk.com/kershaw-3800-3cr13-gray-titanium-nylon-fiber-white-box-p-823.html
A small knife with only a 53mm blade, light-weight, very EDC-able. Delivered equally sharp as the others. But I cannot recommend it because it doesn’t lock. The liner lock mechanism is a hair too long (maybe as little as 1 mil too long) to lock in the blade. I’ll have to disassemble the knife and file down the liner lock to get it to work right.
EDIT: Filed down the liner lock, just took a hair off the inside edge of the lock. The Kershaw 3800 Shuffle now works perfectly. Easy, one-hand action to open and close.
