I have a question about the STAR momentary firmware offered as an option on the mountain electronics FET+1 7135 driver. I have not gotten to the point of modifying FW code, so this is just a question about what I would get from mountain electronics.
I’m interested in having a very low moonlight. Am I correct in thinking that the moonlight mode and low modes will use just the 7135 chip? If I was to do the custom mode levels, at which PWM % level would the output switch to just 7135 output?
I’m trying to understand the user interface. This is my understanding from what I’ve read.
From off:
short click turns on to lowest mode
long click turns on to highest mode
From on:
short click moves to next higher mode
double click moves to next lower mode
long click turns off?
Important Note on this parasitic drain issue - it's being discussed in the 25/45/85 thread here, and they are mentioning the diode, besides the resistors, we use adds to the parasitic drain as well.
I did the tests. First removed the diode, bridged the pad with solder, and saw absolutely no difference in the parasitic drain at all - zero, nothing. Still doing in the 0.30 to 0.32 mA range.
Then I pulled the 22K resistor. The light acted kind of weird, because I didn't re-burn the MCU with firmware not supporting LVP. Anyway, it would settle down, and go into its sleep state. There I measured in the 0.16 mA range, which is about exactly what I expected - it went to half the draw, as calculated from the resistor values.
The DQG Tiny 4, reviewed here (https://budgetlightforum.com/t/-/36824), has no room to swap drivers. The LED is mounted on the driver itself to save space. Unless you know a method of doing so, I sure don't know how it would be done. These super compact lights make modding/upgrading difficult, to say the least.
Firelight2 already dit it with the tiny 3 DQG tiny 3 mod
Since the triple carclo optic is shorter, there is a few mm to play with.
The tiny 4 unscrews really easy, just might need to machine some parts out of the head.
It’s not going to be easy, but I’d like to attempt it.
I already modded a few P60 dropins and a thrunite TI with the 10DD driver from RMM with the XPL Hi. This is a nice step up No guts, no glory.
Since the heatsinking will be “marginal” at best, learning to flash and adjust the settings would be a nice extra skill to learn.
I’ve got all the parts inbound, but can’t find out about the BLF driver and momentary switch options… :question:
Interesting… I haven’t tried re-flashing a BLF A6 driver from BG, but as long as they didn’t lock it, which I’m pretty sure they didn’t do, I would think it could be re-flashed with STAR momentary just fine.
Firelight2’s thread doesn’t have much detailed pics, but he mentions the switch is side mounted and has 2 tiny wires - one goes to pin #2, the other must go to ground (batt-).
As far as mounting the driver, he describes a bit after the 1st pic, and has one pic - partially drills it out, and uses the remainder to mount the replacement driver.
Thank you for the answer Tom E! The mod Firelight 2 did, does look really nice indeed. I’m hoping I can pull it off with the BLF driver. Very nice STAR firmware, hope I get it working!
I’m think’n this mod is a bit beyond my comfort zone. The copper work and mounting of the driver and MCPCB based on what you have to work with is a challenge for me. The results are rewarding though - a triple compact e-switch with a big cell (18650) is a rare combo.
I haven’t tested it yet, but I think there are a few methods left to reduce power. A big one is to turn off the ADC in sleep mode, and basically turn off everything except WDT and/or pin change interrupt. This will require a bit of extra code on sleep and wake, to disable/re-enable things, but the longer standby time is probably worth it. I especially want to get power draw as low as possible for the “smart” tailcap mods, so it can be both fancy and efficient.
In theory, the voltage divider values can be increased as long as their relative values are still proportional. Multiplying each by, say, 10X, should reduce standby current. I think. So instead of 19.1k and 4.7k, maybe 191k and 47k?
No prob! I’m a mess with this - I got things posted between 3-4 threads. Did a bit more testing, and it’s looking real good so far. Love the 0.016 mA draw from an 85. Only got bout 10 resistors with the 10X values, so I’ll be limited initially, but plan on updating a bunch of my e-switch lights running Narsil with the indicator LED’s. Modded Narsil this eve to have a quick way to toggle the locator LED functionality: quick click followed by click&hold, the let go as soon as the main LED goes OFF. Maybe sounds a little complicated but takes less than a 1/2 sec.
I just don’t think we gave e-switch support much attention, and that’s why these things haven’t been explored - one line of code cut parasitic drain by half, then the resistors cut it by 90%.
I got it for the 25 posted up on my google drive share w/mode changing that works like luxdrv (short cycle). Not sure if I got a version for the 13A, think I do, but not sure it’s posted - @work now so might not have access.
Thanks, been a change of direction though. I'm updating a light I built for somebody a long time ago and it had phase-correct luxdrv on it, no ramping mode, with strobe & battcheck. Turns out it's the strobe he doesn't use, and I guess hacking luxdrv's battcheck into STAR would be impractical. He's OK with the way it was before, I'll just give it a fast PWM version of luxdrv and call it done.
Ahh - luxdrv was my baseline driver code for years, tweaked to each individual's mode choices. I kind of abandoned it now in favor of STAR offtime, then tweaked my flavor of STAR offtime with some unique features, but then went on to the 25/45/85 stuff. Sorry - it's impossible for me to keep all these variations/tweaks in my head - my heads spinning from just typing bout it .
I have a version of STAR with a strobe I can link when I get home tonight, but is there a reason you don’t want to use TK’s blf-a6 firmware? It has strobe functionality built-in and you can just disable all of the other bells and whistles that you don’t want (that’s what I do)
