if the light is ON while you loosen the tailcap it memorizes that mode
i was on high (near 4A) when i unscrewed the tailcap to connect my 400mA fused DMM
brzzzzzzz
clear now?
brzzzzzzz
clear now?
Forget it - I’ll never understand. I’ll try replacing the driver anyway, just have to figure out how to rig up the vertical switch board.
Sorry if this has been answered already.
Is there pwm on any of the modes?
How resistant is it to switching on in your pocket. Not using lockout.
Is there anyway to get to high quickly?
Do they come with the clips as per the first pics in the review?
Definitely not an A6 driver as described. Seems rather a let down and too pricey even on a gb to be worth buying just to totally strip and rebuild.
@ Tom:
imagine the light in a living room
turn the dimmer switch to full brightness
unscrew the bulb
reconnect
-> it starts as high as it was before
better?
@Chicken:
i look tomorrow for PWM - but did not notice (but didnt pay attention)
will not switch on from walking , but when you sit on it it might switch on
nope - double clicks go to disco modes
yes
true
So what? As long as you can use the switch and turn it off, them measure.
i have to get a new fuse for the DMM first
Ohhh! I got a Fluke DMM I was using - didn’t realize the fuse can get blown for exceeding the max amps rating. Pretty sure I exceeded it’s max - the display went blank or dashed, hhmmm…
I ordered E02 today. 8% blf coupon. …had I known you might have a coupon later I would have waited. Thanks for the review.
Hi guys, I can’t resist ,…I must add some pics of this little fatty light, Nice design!!
Can you measure glass and reflector size?
Has BG advertised other lights as coming with the BLF A6 driver?
The removed the BLF A6 driver from the product description once someone told them to do but it’s still used for advertisement.
I’m not aware of other use of it for ad purposes
i pointed Neal to that
btw:
i hope you all did see the sale in the groupbuy thread?
ML -> Low is too big step for my taste, it’s a shame because the design is great
Agreed!
I can close 1 eye on the no low voltage protection and non-regulated driver, but the jump from ML to Low is too steep for my liking.
Hi,
here is an animated gif with the 4 modes of the E02 (without control shot!).
Regards
Kenjii
Once again.
Can anyone measure glass lens and reflector size?
kiriba-ru:Can you measure glass and reflector size?
Once again.
Trevi_lux measured the reflector size… I assume the glass is the same diameter as the reflector.
Seems to be 20mm x 11mm.
Blog de reviews de linternas LED
I can confirm glass is about 20.5-21 mm diameter.
