Not bad? It got 4526mAh from the first cycle and it actually surpassed their rated capacity of 4000mAh @ 1A. Most of the 18650 cannot surpass their rated capacity, even when they do, it's 20mA, So the King Kong got with 13% more than rated, and the NCR18650A with 0.6% more than rated. And I doubt all NCR18650A will exceed their rated capacity.
I wonder what capacity will the King Kong give at 4A (1C).
Mitro said that his MNKE 26650 got over 4000mAh even @ 3A discharge, and since they are IMR, probably delivering high currents is not a problem.
I mean not bad comparing their sizes against the Panasonic NCR18650A.
Let's see their volume differences.
Where the 18650 is roughly like this:
V= 3.14x81x65= 16532.1mm³
And the 26650 would be:
V=3.14x169x65=34492.9mm³
So,
3100--------16532.1
x------------34492.9
This gives us the 26650 should be 6467mAh which is much more than 4525mAh, so that is why I said it is not bad for a battery which is not as standard as a 18650 made by a company with a bigger R&D dept.
I am talking about the money spent vs what you get. Discussing the volume is something theoretical and you have to choose the best from what you are being offered now.
The 2600 Sanyo ( 2400+mah reality) seems to be the standard not the 3100 from Panasonic. Let's say that 2500mah is ordinary and the King Kong are ordinary 26650.
The price relationship is quite good, and I got 26650s from MNKE and I am happy with them,but my point was just regarding their sizes nothing else than that.
I would love there were a model from panasonic with the same Watts per volume in a 26650 version, so I cannot compare equal to equal, just the best I know of each model.
Did you also check how many amps can they handle with?
And the last thing, I am also interested on the Palight protected ones ( http://www.goodluckbuy.com/palight-battery-26650-rechargeable-li-ion-battery-4000mah.html ) but to tell the truth I do not know much about them, I am not sure how good they are.
They aren’t. My question is: what exactly are these? The wrapper say INR. Supposedly that is Lithium Nickel Cobalt Aluminium Oxide (or Dioxide - not sure). I know nothing about the claimed level of safety (or safe discharge/charge rates) of this chemistry.
So... I'll just go ahead and order a few for testing. I'm such a sucker for new cells. :p
They are quite more expensive than the MNKE on the same shop, and I see a line crossing the battery from + to -, but I can't tell you wether it is the protection or not.
On the second picture on the link, if you check, you can see like a strip underneath the plastic packaging, just over the text on the label.
That’s funny, because I don’t see any sign of one. You realize that’s the positive end in the Int’l picture, right? Not to mention that every protected cell they sell they also offer unprotected. There is no option on the page for a protected/unprotected KK 26650.
I went through my old results and I have to correct my lousy memory. I apologize. Here's what I got at 3A:
MKNE 3900 - 4000mAh (only discharged them once - sold them with a light)
Batteryspace: 3600mAh - 3850mAh (with a few cycles)
Bestinone.net: 3300mAh - 3400mAh (and trending up with each cycle)
I hooked up the test rig tonight and hope to be doing some new tests and can't wait to get these!
