I have voted.
I have voted
Voted for function.
A real lego-light. One tail-piece plus two tubes (1 short 18350 and 1 long 26650 with 18650 en 3*AA inserts) plus three “bezels” (for throw, flood and a triple) in a custom-made box.
Voted for function.
I have voted
I have voted
I’ve voted for the function.
I have voted
Forget flashing and SOS mode.
Let moonlight mode and mode memory!
12 more to 200 posts :smiling_imp:
Multiple tube segments allowing for a variety of batteries. For example 2x 26700, 2x 18650, 3x3p aa, 3s d-cell, 3x4p aaa, etc.
A light which can be used as a typical straight light or with a 90 degree segment that can be attached between the head and tube for a use like the old angle-head military style lights.
Solid copper led shelf/cooling segment that threads to reflector ring/housing and battery tube. Titanium reflector segments for reflector, side switch, and batteries.
A light using a high cri yuji emitter.
Dual-emitter headlamp.
A swivel-head hinge, you mean.
I was referring to the Fulton MX991/U but a metal light with a swivel head similar to the newer military issue streamlights is another option.
high cri
Sir I perceive you are a prophet
High CRI is a must. Nichia is preferred but high power with 80+ CRI is also nice. perhaps one of the neutral high CRI XHP50s.
Light with accessory heads allowing it to be used for zoom, flood, or throw.
