No its not just you!
I can only just see the illumination at night and even then only on the low output setting.
It’s a pity as its otherwise a great flashlight at a great price with the discount code.
It would have been good to have a clear indication of the battery state though.
It seems that the original first batch of lights came with the clear side switch cover then & the second, re-stocked batch, have come with a grey cover.
I had my light from the original first batch so have a clear cover, I wonder if Thorfire can supply clear covers separately ?
I wonder if “freeme” could ask them as he organised the group buy ?
BTW I love my S70
Someone can put a detailed photo? Thanks.
It’s not just you, even in complete darkness I struggle to see any illumination from the switch.
I’m surprised that the colour was changed to grey as that’s the purpose of the translucent button, to let the light pass through it.
A massive change to the original design where the battery condition can be seen in the daylight obviously before you go out in the dark.
anyone know what kind of tool to use to open the retaining ring of the switch cap?
it was so small i can’t get my snap on plier to work
I have the same question
Used a small screwdriver and carefully turn is, giving force at one hole first, not too uch, then switch holes.
again, with a little more force in the two holes, upped the force until it came loose, no scratches!
tough job for butter-finger like me :person_facepalming:
You could see a faint illumination of the green led through the grey switch cover. Amber or red status could be slightly more visible.
That’s exactly how my S70 looks.
I’ll run it down later to get a look at amber and red.
Well the ‘T’ is easier to read on the gray! (that’s about the only positive thing I have to say)
I’m glad I spotted this thread as I received my S70 today and was disappointed to find the voltage indicator had been ditched in this batch. Now I know the circuitry is at least still there and maybe fixable with a replacement opaque cap, well, at least I hope so as it’s pretty much impossible to see through the grey rubber even on low mode.
I ran the batteries down last night.
Amber indication has about the same visibility as green , but flashing red is a little bit more noticeable.
Wow, that’s just horrible.
Try as I might, I can’t understand how they didn’t realize, this is no good.
I, too, was disappointed by the gray switch cover.
I could not distinguish any light at all coming from the battery level indicator under the switch cover, even with the S70 turned on in the low mode and in a totally dark room.
I sent a PM to Thorfire asking whether they can send us replacement covers. No response yet.
Thanks for asking them.
I’ll await a response.
Yesterday i got my S70. And i have same troubles with grey button.
Where can i get it?
