obviously the exterior must be coated with 1” thick titanium, how else could we be sure the sphere will resist compression forces from the zombie apocalypse
Great idea and I hope this really pans out.
May I suggest that you have some way to make the opening adjustable so that a light as small as a convoy s2 all the way to a acebeam k70 will fit.
15cm would work for small lights and lower lumens, but to use something like a SRK or a large head/High output light, the sphere should be larger. 40cm or bigger. I have seen actual integrating spheres for sale that were "designed for flashlights" and the size was about 12" in diameter, but it was for smaller flashlights. There is information about the size of the entrance port compared to the diameter of the sphere and there are some scientific rules about that. I would just have to go find the info out again.
As for the size, I will look for a bit bigger since that is being requested. But not only can I make white inserts to accommodate different sized heads, there’s the whole data point calibration. There’s no need for the data to be linear, which seems to be the fear of the small sphere with big lights.
IIRC (and I my not as I’m on my second coffee and not quite alive yet), the openings should not exceed 5% of the total inner surface area of the sphere.
Even though it is easy enough to DIY, this is a nice initiative! What is very convenient of course is that the calibration is done for you.
I can only really comment if the exact design is known, the exact design is crucial for function.
About a few concerns that are noted above:
-indeed a 15cm sphere will heat up a lot, no problem with measuring for a short period, but continuous measuring of high output lights will be a problem,
-a high hole-to-innersurfacearea (which will happen in a small sphere) will make the multiplier very dependent on the shape and reflectance of the flashlight in the entrance hole, in other words: without multiplier-correction for every measured flashlight the sphere will be more inaccurate, calibrated or not.
-with a small sphere like this you need to lower the amount of light reaching the luxmeter to get into a workable measuring range, in the sphere of the link above I did that by measuring through the wall of the sphere.
-do not bother with coatings of the inside of the sphere, I experimented with BaSO4 and I hardly saw anything change compared to sanded bare polystyrene.
-please carefully sand the inner surface of each sphere, it will help integration a great deal
I did some testing on my 12” D.I.Y. IS here and found that the biggest problem is the change in reflective area based on the size of the light placed in the entry hole. Lumen numbers seemed to be within reason if you calibrate with a light with a medium sized head. I’m not totally done tweaking my calibration yet either.
It was an easy build. I’d be scared of using the HS1010A though! I’d move up to the LX1330B. My HS1010 proved to be junk.
