heheh just thinking about it also adding the feature of powerbank might be hard to do.
Maybe not hard, but in terms of costs.
The convoy/dipper system is there, it works and looks good, well balanced with the small micro usb connector on the clipon thing…
Please check this review for the charging system
Making it charge other devices means adding a bigger USB out port to the clipon charging thing.
Internally more components are needed.
Using th BLF Premium on site with a powerbank means having something to charge a phone/tablet, so you would be able to distract the zombies with Flappy bird anyway
If we go this route than we can make the clear insulator between the pieces of te button a battery indicator.
But charging 4 18650s in parallel is going to take a loooonggg time.
I rather have a lower price than the ability to charge the cells inside the light.
Just my €0.02
Yes agree!
It would be cool if charging could be done and keep the pricing.
Same with the tripod nut.
Always good to have something to give a party one is negotiating with.
I’d prefer no internal charging, spend budget on better quality/driver/emitters. Internal charging I wouldn’t use, it can cause issues (was it supfire that had major issues?) and adds to cost. Power bank is a better idea but not much, keep it simple, just a great flashlight
Definitely an interesting idea.
But the xhp35 and xhp50 are higher voltage LEDs so in order to get it to work the batteries needs te be in series instead of parallel.
And most guys don’t like a 4s setup.
Also don’t forget it will probably increase price.
Count me in, but if we have advantage of 3-4 batteries then i prefer having something like mt-g2 or 6*219c. I also prefer neutral colored leds instead of xp-l
my chinesee srk clone uses 3*xm-l2 in parallel and 4*18650 in parallel
roche m170 uses 3*xm-l2 in series and 4*18650 in parallel (LD35 -stock driver from roche m170 designed for 3*XM-L2 in series ~$10 in GB store.)
from cree site:
XM-L2 - Typical Forward Voltage 2.85 V @ 700 mA
XP-L Typical Forward Voltage 2.95 V @ 1.05 A
XHP35 Typical Forward Voltage 11.3 V @ 350 mA
XHP50 Typical Forward Voltage 5.75 V White @ 1400 mA (6 V) or 11.5 V White @ 700 mA (12 V)
I ’m not sure about the original idea but if we are to use 4*xp-l in series (i.e. forward voltage 2.95 * 4 = 11.8V) it is almost the same as if we use 3 * xhp35 in parallel.
to put all in a nutshell - we can use “s” or “p” for 18650 . all depends on driver
All true, but going to a non-standard series cell arrangement is probably more $$$. If a boost driver is needed, than the high amps is not going to be easy or cheap.
Really hope we stay on course here - 4 regular 3-4v LED’s (219C, XP-L, XM-L2, etc.), 4 parallel cells: simply, a few LED options, up to 5+K lumens, maybe up to 3.5-4K using 219C’s.
Of course doing the math on the high voltage LED costs probably rules them out from the start. Qty 4 LED’s on copper per light, goal of the light being $40 shipped.
Didn’t know that the m170 has a boost driver.
But still, if the driver puts out 3A (which is pretty high for a boost driver) then its only 1A per led using 3 xhp35 in parallel.
If you use 4 18650 in series and use a buck driver you might get 9A in total or 3A per led.
That is really a big difference.
