X3, it was your post… I had the 5D ready for this light, a nice halogen yellow color… I have a 7A3 XPL, but not XML… I thought about the 3000K XPL HI too…
i must be getting really bored waiting for toys to arrive from china, lol.
i had spent a couple dollars on a clearance china-tastic zoomie at BIG LOTS. 3xAA zoomie, and a little bit thicker and longer body than i am used to seeing in a low budget zoomie. My several 1504’s are the only 26650 zoomies i own until the china boat gets here, so…
i am looking at the thicer than normal tube, and its a little longer than it needs to be,… opened it up.
aluminum pill thank god, hollow no doubt but i didnt check. the driver has the LONGEST SPRING i have EVER seen on anything. really long… they made the light longer, then filled the space up between driver and 3xAA battery carrier with this long spring. Its SO long? it had a little plastic insert to keep the long spring from going catty-wumpus and missing the top of the + of the battery carrier. Hmmmm.
the plastic insert is sandwiched between 2 circlips riding grooves above and below the plastic tube insert… got them out, and now had more than enough room to put in a spare 26650 for long runtimes on the 630ma cheap driver. It works with the 26650 now, and i can bang it around it stays okay. for now anyways. Taking out the circlips allowed the plastic spacer to move forwards giving room for the 26650 to easily fit into it.
i have to make a little plastic tube and drill it out for the long spring to go thru it and hold it so it cant slip off the 26650, and, so i dont have to “know” how to put the battery in, i can just slap the 26650 in and go.
emitter looks like a little CREE with 3 bars on it… wonder what driver would be appropriate for it…i guess it looks like it might be an XP-E…
I have a copper S1 coming in the mail (thanks, X3), and am copying his mod soon, ordered a XM-L2 T4 7A3 for it, Simon has the led for cheap! Using a XM-L2 over XP-L (hi) saves you solving centering problems and beam artifacts.
7A3 with copper is the warm way to go
I plan to mod my new SRmini II with these little fellas too :innocent: , gotta be a nice ambient lamp in the living room !
Thorfire S70 came yesterday just before dark. It was making 3657 lumens out of the box. Tried a couple of different cells, at 4.18V and 4.22V, really nice output but, well, you know.
So I cracked her open. Dropped an R070 on top of the 2 R091’s. Added a 18 ga spring bypass to the driver spring, 20ga through pcb on the switch.
WOW! Not having time after midnight to fully recharge the cells I’d used earlier in the evening I did manage to see 5700+ lumens… on cells at ~4.12V.
Over 2000 lumens increase! Stock sense resistance was 0.045, it is now 0.027. Fresh cells will show me over 6000 lumens on this big heavy deeply finned light. But the regulation was far better straight out of the box, only dropping 21 lumens in 30 seconds. With it resistor modded the hit is much bigger as it runs, dropping numbers very fast on the light box. Gotta charge up cells today and give it another look…
So all of us who thought it looked like more than 3000 lumens were right. good to know! What kind of tailcap readings do you get? I wonder how many lumens I’m getting with the resistor bank completely bridged.
Awesome! You have some pictures of those spring bypasses? (Still in the learning stage)
Also you sure the stock sense resistors where r091’s? Thought they where r901’s, stupid enough I didn’t look close enough when I had mine open.
I’ve ordered some 0.2ohm sense resistor to play with, but looks like they are on the high side.
I got the Basen’s charged up and ran 9.05A at the tail for 5971.95 lumens. BUT it dropped 545 lumens in 30 seconds to 5426.85.
Stock, right out of the box, it only suffered a 21 lumen drop in 30 seconds. Obviously the heat sink and/or the cells can’t handle the bump all that well. In the few seconds of testing the cells went down to 4.11V. These are new Basen’s, only ran the few minutes of testing in this and another light.
Wonder if the Efest 4200’s will break that 6000 mark? Hmmmm……
Edit: Am I sure about the R091? Well I was til you said that! Yeah, I’m pretty sure, because I ran the parallel resistor calculator on em last night to figure if I wanted to run the R070 or R068 that I had on hand.
To be honest, one said R091 and they put the other one on upside down, ugh. So no, I didn’t remove it to make absolutely certain that the second one had the same value.
I have hit over 10amps on my Basens, so I’m probably pulling just over 6000 then (for a short time). I did shave my dome though, so maybe I lost some there.
I re-did the short tube for my A6. The “old version” did not quite fit on the tail side even after modding. Since now I had three shot tubes from BG, that were all wrong I went full retard - removed anodizing and used dremel cut disk on the threads :smiling_imp: Also added lighted tail tailcap. It draws 0.2mA right now, but it’s still a bit too bright. I might redo it later on
Any good hints where I can get a raw copper S1 with ss bezel for a good price?
In the process of pulling the S70 back down some. The calculator says adding 4 1ohm resistors will give me .0385 in place of the stock .0455 so I’m going with that and keeping it within it’s abilities. About to double check that the mcpcb is DTP….
Edit: Mcpcb is indeed direct thermal path…
With the 4 1 ohm resistors in place I get 5.03A on the Basen’s for 4264.2 lumens at start, 4153.8 at 30 seconds. More reasonable losses I’d say.
While I was back in it I put 16ga Turnigy wire on the driver, removed the mcpcb and cleaned up the thermal paste to get a look at the shelf, it’s machined decently but has lines from the bit fairly pronounced. Used Arctic Alumina Thermal Paste putting it back in.
