I've been using the DX silicone oil I linked to for several months on anodized and unanodized threads and I'm quite happy with it. Of course, I use it sparingly. Even so, I've learned to not touch the lubricated threads when I drop the battery in my hand.
Another lubricant that worked fine for me, although somewhat thicker, was a silicone grease that scuba divers use. My son pointed me to that one, as it's standard among divers, but I would have to drive to the city to buy it, whereas DX delivers to my doorstep.
Nextorch "SL6" silicone grease, makes non-anodized threads "gritty" and produces grey/black crap that gets everywhere. Not recommended for bare threads. Works well for anodized threads tho...
Bare aluminum is inherently "dirty" so you are going to see some grey residue no matter what, your choice of lubricant can increase or reduce this however. Anodized threads are king since they are naturally much "cleaner". Deoxit is decent, does not produce "crap" nearly as fast as silicone oil and especially silicone grease.
I've used anything and everything ...having heard petroleum based oil isn't good for o-rings I opted for vegetable oil ,lip balm(bees wax) ,hand lotion,bear grease ,and finally silicone lube that I stumbled across in the garage . interesting to hear people don't like it very much ..my feelings on it are mixed as well . Next i'm going to try machine oil like Don ..if my o-rings only last 12 years I'm ok with that too ..
It would attack natural rubber O rings but should have no effect at all on silicone rubber rings. Most engine seals these days would be silicone rubber. Natural rubber is not cheap stuff, silicone rubbers are. It is possible that there could be some solvent effect with some lubricants and some O rings but I've never seen it. The only unwise lubricant I've used was heatsink goo (AKA cutting paste). Though I'd not recommend highly flammable ones or WD40.
I use the same bottle to oil the hinges of the horror film squeaky door just outside my office which gets opened hundreds of times a day as it leads to the wards.
Thinking that the o-ring was probably silicone anyway, I lubed the spindle of a top-leaking water tap with common petroleum grease, as that was the thickest I had and I didn't have a proper replacement o-ring on hand. The effect was that in a few days the o-ring swelled (natural rubber, evidently) and the leak stopped, but I don't expect it to last.
Ole WD40 isn't as flammable as it used to be. It used to be a good starting fluid for small engines and propellant for potato guns until they changed the formula.
Still isn't a good lube (beyond short term) since it evaporates so quick.
okay so summing up most of the stuff , its up to me,what to use?
does anybody have some experience with stuff from any of the HK based sellers? with link? (except the silicone stuff that people think is no good).. is there anything that Everybody likes?
This is my observation with my small collection of lights. Silicon grease works well generally for anodized threads & o-rings. Do not use it on bare aluminium though. Even without any lube/grease, black powdery particles can be seen with a simple finger wipe, that's how soft the alloy are. That's the gunk normally mentioned when silicone lube is used. There are reasons why at one end of the threads are not anodized and the reason chiefly being that its not meant to be open & close frequently, use the anodized end instead. If both ends of your light are anodized, its a big bonus and if both ends are not, there are other lubes that will work instead of silicone grease, SuperLube for instance.
I tried silicon grease. Now I use waterproof lubricant that came with a tap washer repair kit. Works fine. I have tried oil that is meant for lubing up fishing reels. It worked ok too.
I've used many products and they all seem to work fine. (all the different oils and lubes mentioned above however my ultimate favourite is paste wax (also known as generic furniture wax). It helps provide a seal that is not greasy or sticky. I wax it maybe once every 2 to 3 months. Everytime I change out the battery I give it a quick buffing and it's back to new.
I've even used the those toilet wax rings on my torches once or twice before (although it's generally used to help me lubricate 3 inch screws to drive into wood).
Use just a TINY BIT. It will stain your clothes & hands if you get it on you, but it is electrically conductive, so joints like flashlight end caps & heads stay in good electrical (grounding) contact with the bodies.
