Mini Review & Teardown - Manker U11 (Pic heavy)
Got this light from a giveaway hosted by freeme here. He currently has a GB on the light in his GB thread. There are several good reviews already done on this light. Such as these here on BLF (In order of OP date:
So I will just kind of fill in some the gaps.
Initial impression after using just a couple days:
Really like the light. Very compact. At first I thought it might be a AA light. The finish and look are first class. Very high quality all the way around. The the brightest stock single cell (can use 2 cells, but I only used it with a 18650), single emitter I have ever come across. I would prefer if one could reverse through the modes, but the UI has some nice features that make that not a big deal. Initially, I was not going to tear down the light because I like it so much. I, however, became concerned with how slow the light heated up considering it's output.
Arrives in a nice box that would be good for gifting. Love the AR coated lens and reflector.
Tear Down:
After removing Bezel, Lens, Reflector, and Pill Retaining ring (See ReManG's Review Thread linked above). The pill just slides out and this is the only concern I have with the way my light was assembled. The pill fit may seem tight when you first remove it. In my case it just had some burs. Once I got it out, the burs had smoothed and the pill slid freely. I recommend adding some thermal paste between the pill and the body of the light. You don't have to completely remove the light engine. Just slide it up enough to have access to the sides of the pill. You don't have to remove the side switch cover to pull out the pill.
Innards:
I didn't need to remove the switch cover.
The driver got hung up once it got to the threads. Back lighting helped me see it was the USB port housing that was catching. Used an Exacto knife to remove some of the thread peaks. Then, a thin pick to help guide the driver out. Pushed from below with a hollowed out plastic ball point pin tube. Took some finagling. The driver needs to come out straight and level. Pushing down lightly on the vertical switch board while using a pick on the USB housing kept it level while pushing the driver out.
Inside of head:
Driver in head. 22mm with slight filing will fit.
Bottom and inside views of pill:
Has to be a buck driver since it can take 2 cells. Looks pretty complicated. Wouldn't mind replacing it with a DD +7135 loaded with Tom E's Narsil. Would probably beef up the pill to body thermal path if I ever do that. Voltage sense resistor is under the Red LED Lead. It's labled R010. So .01 ohms. Not much room for increasing current there. Some pics:
Inner spring was not soldered to its pad on my light. Outer spring was not centered and barely touched 2 of it's pads. The board is really glued in. So will need to fix while in the cap.
Conclusion:
I'm a big fan of this light. I would recommend that thermal paste be added between the pill and body. It's easy to do and does not require any soldering. While in there, why not throw in a DTP emitter base? That will require unsoldering and soldering 2 wires.
Some of my favorite features:
  • Size and shape of light.
  • Output
  • Finish
  • AR lens
  • "Breathing" light switch
  • Tail stands.
Sunava…. Never thought to just pull on the assembly… Great breakdown and review. I too have been impressed with this light and now you have opened up many more mod potentials here. Moppydrv would be nice, but how to keep the internal charger as well….
Keep us updated on your mods and perhaps one of the driver gurus will poke in here and let us know how to keep the charging circuit…
Interesting, it seems like some of the driver components are in the e-switch board?
^It does seem to. You reminded me that I forgot to include a picture showing the interface between the two boards.
Wonder if a new switch board designed that would convert the light to DD. That way the horizontal board could be kept with the USB charger. Would probably need to disconnect or pull a couple components from the horizontal board. This driver would take some studying to sort out the USB charger from the buck driver. Not something I have to knowledge or time to sort out. Would be cool though if one of our driver geniuses figured out a way to make the UI customizable and the light DD. The light deserves it.
Since the light has pretty good output already and the UI is interesting to me. I think I will just bypass the voltage sensor, swap the emitter, and slightly improve the thermal path and electrical resistance.
I was comparing this light to the SolarForce L2M. They are nearly identical in size except one runs on 18350’s and of course the other on 18650’s. Just for fun facts the bezels are close but not interchangeable. Low battery blinker kicks in at 3.18 Volts.
Wow, I never noticed that the pill slides out either. I’ve had mine apart and swapped emitters in it several times, but that pill has never budged and I never considered pulling on it. Then again mine doesn’t seem to heat up slowly. In fact it gets quite hot, quite quickly. So maybe mine’s just tighter to start with. Mine’s also a couple of months older and has the notched lens retaining ring, too, so it could be different in other ways as well.
Either way, I also really like this light and appreciate the full teardown. The factory UI is…okay, workable, but its not my favorite. Now that we know how to get to the driver it may be worth swapping it, or at least trying something different. Thanks!
^ Thanks. In your and ReManG's defense, it was tricky to figure out. Sounds like your version is built to tighter tolerances. If I had your light instead of mine, I might not have figured it out. Regarding the UI, It would seem that one of the board wizards could design a DD driver that has a vertical board the momentary switch. The top of the sliding pill supports the top part of the vertical board. Seems like it would be worth sacrificing in light USB charging. The USB port could be turned into a light tube and make water tight.
EDIT: Since the voltage sense resister is of such a low value, I tried straight up shorting the pads.
I only had a xpl2 XM-L2 handy to connect it to. Using a fully charged INR18650-30Q and keeping the stock 24 gauge leads, I got something like the following currents:
1 Moon - Still very low. Don't remember the current but you could still look at the emitter directly while on
2 1 amp (I think, It was late and I didn't take notes
3 4.5 amps
4 4.6 amps
5 4.6 amps
So it looks like 4.6 amps is about the max (might be slightly higher with the xpl) with just a resister mod. Next step will be to find a resistance value that give 4.6 amps in Mode 5, but still offers good mode separation.
This will be interesting, please let us know what you find…
How did you pulled the pill out? Beating smth soft from battery side?
Nice work ImA4Wheelr.
Thank you kindly MRsDNF :slight_smile:
Not knowing what was going on below the pill, I slowly walked it out from above by gently prying, pulling, jiggling, tapping, cursing, etc. Once I had it all apart I cursed one more time because I could have done just what you suggest in your question. I think the cursing is the most important part to the whole process.
Once it was taken out once, no pressure was needed to slide it anymore. There were just a couple burs holding it down.
Nice tear down. This indeed is a great light in terms of both build and performance. Much better and noticeably brighter than my Nitenumen NE01. They’re roughly similarly priced but the U11 is in a completely different quality category. It’s become my favourite 18650 EDC. And thanks to the tear down it’s good to know the quality of the innards are commensurate with the exterior. I’m going to pay more attention to other Manker lights.
Having said that, the lens on my U11 is loose. When I shake the light the lens rattles. I wonder if anyone else has this problem? Is there supposed to be an O-ring over or under the lens? How do you remove the front bezel? I suppose you’d need some sticky rubber to twist it off.
Mine rattled I used a rubber pad used for opening jars. I then placed an extra O-ring in the bezel’s recess over the lens.
Thanks texas. I doubt if I have an o-ring this size. Guess I could contact Manker for one.
This 27mm glow-in-the-dark o-ring fits great in the U11, if GITD is something you’d be interested in.
Cool. They’re blue too! Thanks!
Nice review buddy,planning to buy NW one. :slight_smile:
Appreciate your nice review. Manker seem to be pushing the boundaries a bit. Interesting to watch and maybe buy at some point.
Thank you for the nice comments.
Nice tip.
i like it but
it is too big and heavy
my other EDC is a DQG tiny 18650, which has a completely opposite UI - hard to switch between the 2 lights
moonlight mode is too low
would like more evenly spaced [logarithmically] lumen levels
the charger is nice
the LED color is nice
the side blue LED ‘dragon mode’ is fun for about 10 minutes
this is hard to explain, but usually the reason for wider and longer heads is to get a more focused throwy beam
this is not throwy, it is semi-flood at best {which is fine for a pattern BUT…}
they could have made the light smaller if they were going to have that beam pattern
the DQG uses a very short TIR to focus the beam - and it makes the light about 10mm shorter, which is a LOT
these guys made a wide and long head but then orange-peeled it, wasting the focus and size
a lot of the other features [blinky modes, “super turbo”, light level programming] don;t really seem that useful after you see what they actually do
the light levels for instance, yes you can change them, but the levels you can use are not really what i want
also the turbo mode and super turbo are not very different from plain old ‘high mode’ with the batteries i use [cheap or laptop recycles]
i am not going to buy $20 batteries just to get 40% more light for a few minutes
wle
