PM replied.
Hello Rey,
Any ideas on when the Ti Flashlights will ship out to us? I am chomping at the Bit to Tryout this Awesome Flashlight.
I feel like a Kid about to turn 9 just waiting to open my Birthday Present …
Thanks in advance for your Help and Hard work on this Awesome Flashlight…
Hi,
It is shipped. I will get the tracking and send it to you later today.
Hey, are these still available? I’d love to buy option #2 with blue tritium if possible
I would be in for 1 with option 3 please, Paypal sent!
- with Blue
- with Green, Ice Blue & Yellow
Thanks Rey!
I just received mine ( funny ,2 days between Beijing-Amsterdam and 5 days for 1,1 km between collecting point and me.Yay ,PostNL ).
Quick impressions :
indeed the engraving on the button is not centered and i like this , it’s personal ;
-threads perfect after some grease
With apologies for the flashlight market i will not buy another one for the next 5 years ,i see no reason . For the price i payed i consider it a gift from Rey.
Now i am collecting money for 11 trits ,not because i am a big fan but i respect Rey’s design&vision ,and this one deserve trits….after i anodize it blue and some tumbling.
Thank you,Rey.
I got mine. Measured CCT 4940 K and a CRI of 84 and CRI (R9) of 27.
Only some of my 30Q’s fit and they are very tight. Have to push them in. Also my flat tops won’t work without a magnetic button top. Efest 18350’s fit fine, but also need an additional magnetic button.
How’s the output on your lights? Mine only produces similar lumens to an Astrolux S1. With a 30Q 1250 lumens at startup. 1080 lumens with an efest 18350. At 30 seconds about 900 on both. I thought it was supposed to reach 2000 lumens.
Tailcap button is wonky. I have to press it right in the middle for it to push down. Doesn’t feel nice at all. The engraving is well centered enough.
25R flat top no problem ; with it the output is slightly better than a nitecore rated for 1000 lumens with the same battery.
le: play with the 2 threaded rings,one outside and the one from inside ,you can adjust it .
PM replied.
And not to sound too negative, the tint is absolutely fabulous and the beam smooth and floody. Perfect.
Although the high pitched and loud whine is quite annoying on low and medium…
Some graphs. Fantastic!
I’m pretty sure that Rey did not measure the output of the light as-sold. First it is still not completely which led he used, he said 219B, then 219C, and now in the OP the 219C is not mentioned anymore, but you mention 84CRI, which does suggest 219+C. The numbers he got from me (2700lm at start-up, 2000 at 30 seconds) were from my triple 219+C mod, and it has bypassed springs and the ledboard soldered to the pill (makes just a little difference). If the light that he sells has 219+B+ high CRI leds, the output will be nowhere near that.
Which is all too well btw, I think I damaged the leds in mine by running it too long too hot, the output at startup is now under 2000lm. In an aluminium light I can easily feel on the outside when it is time to step the output down, in this titanium light the leds can cook before you notice much on the outside. even at the 1000 lumen output that you get you have to be very careful not to run the light at the higest setting for more than say 30 seconds. (it is not mentioned, but does Rey use a Noctigon in this light?) edit: the pictures show the use of a Noctigon alright
Sorry to hear about your unit.
On my unit, the flat top 30Q, NCR-GA and LG MJ1 all can work.
Swapping to 18350 tube, the AW IMR button-top and Keeppower flat top both can work, so most probably your issue is due to samples’ variation.
Regarding the tint, I compared the beam with my Sinner Triple 219B, and I notice the beam on my Reylight is whiter and slightly brighter than my Sinner, so I just takes the word frm Rey that the emitters are 219C.
I can hear the whine on low and medium modes, but it dissappears on Turbo
is there any visual difference between 219B and 219C?
Mine seems to heat up very quickly. Is this pretty common with this light?
Hi, can I still join this? Would like one option #3 if possible!
The heat is normal.
PM coming.
I’m interested in Option #3 w/9 ice blue/green trits alternating + green trit in tail.
Is this 219B?
Are issues all worked out?
What is the turn around time?
Thanks.
