S5 bin looks nice!
Also notice the forward voltage is lower… so slightly more efficient… not XP-L or Nichia efficient… but any gain is good.
S5 bin looks nice!
Yep, datasheet stated forward voltage of 2.99 vs 3.1 at 1.5 amps. 3.06v at 2A at 85C. Nice.
Hmm, yeah, the viewing angle is the same as the XP-L… :person_facepalming:
If I need a flooder, then I would still go with XP-L by the look of it… can be driven harder, and also more efficient…
XP-G3 is looking less promising now… A “cheap version” XP-L?
XP-G3…
Cree got new cook and I really don’t like it…
Probably nothing will change with G3… It can be only worse like this one
Joehoe!!
More lm/W is always very interesting. I like also that it says to have 90CRI versions in all colour temperatures, that alone makes this a great led IMO.
From the provided picture: almost all leading led manufacturers now use this way of applying the phosfor: after the assembling of the led. This could mean trouble for dedoming But who knows Cree comes out with a HI version of the XP-G3 soon, not the throw of a real dedomed led, but at least the next best thing.
Who ’s getting one for me to test?
80 CRI minimum at the S3 bin and at higher color temperatures looks like a big improvement. 80 CRI min S3 down to 4200k as well.
Well it looks alot like the old XTE emitters, if it performs like that its definately not desinged for flashlights, yet i could be wrong, we`ll see soon enough
I’d wager that you’re definitely wrong unless it doesn’t work with all of the existing optics designed for the XP platform.
Different specs compared to xp-g2:
Current 2A vs. 1.5A,
Thermal resistance 3 vs. 4C/W,
Viewing angle 125 vs 115 deg
Forward voltage 2.89 vs 3.00V @1A
There is no doubt, die size has been increased,so another fake “improvement” from cree.
But if the die size is increased why not just call it an XP-L which is an XM die on an XP footprint??
Waiting to see which one of us tries out the new ‘toy’ first
Phil
The press release does make the claim of improved lumen density, which is a key ingredient to throw, though.
And off of that… If there is an improvement to lumen density, then it’s a better thrower. An increase in die size couldn’t hurt anything, so it becomes a non-issue.
I compared dimensions of both the XP-G2 and XP-G3 from cree data sheets and their dimensions are identical. However, die size itself is not mentioned anywhere.
http://www.cree.com/~/media/Files/Cree/LED-Components-and-Modules/XLamp/Data-and-Binning/XLampXPG2.pdf
http://www.cree.com/~/media/Files/Cree/LED-Components-and-Modules/XLamp/Data-and-Binning/dsXPG3.pdf
This is important.
Please someone send them to Djozz…
Lumens/package size ,not chip-die lm/mm^2.
Because 3rd generation sounds better than new led which has slightly bigger chip and same of even slightly worse lm/W/mm^2 performance compared to 2nd generation (XP-G2).
Somehow, I doubt they’d go to the trouble of releasing a product that had nothing new/better to offer to the world. They do plan on selling these, right? Their existing XP-G2 customers are the target audience, hence the naming convention. If it weren’t an improvement to XP-G2, they would be stupid to call it XP-G3, since those customers will presumably be smart enough to read the datasheets of the two and compare the specs. before spending the money to upgrade.
Yes, but the new version might not be aimed at the flashlight market…
CREE love the streetlight market atm…
Hint Iphone or Samsung Galaxy ?
