13 apr 1
Will You Be Interested In Groupbuy For Prince?
Yes, I Will Be In A Copper/Brass/SS
Your Reasonable Price Bid For Prince in Groupbuy ?
Well 40 would be somehing I can justify for a gem like this.
Your Question for Prince ?
I like the brass the most because the color woven in the tube matches, why not produce matching colors for the other two as well?
- Will You Be Interested In Groupbuy For Prince?
Yes, I would be in for a brass (mainly because of the matching weave in the carbon). If there was a copper weave (lighting strike CF) I would be in for a copper. Although the one picture does show the copper with matching weave.
- Your Reasonable Price Bid For Prince in Groupbuy ?
I’d think around $40 like others have mentioned.
- Your Question for Prince ?
No questions at this time
Around USD 40 would be a number I can live with.
Like the members earlier did, and I will try to explain it to you.
- this light has four major components: the tube, the clip, the bezel and the tailcap.
- the clip only matches the SS bezel and tailcap
the tube only matches the brass bezel and tailcap.
If you want to position the Prince in an up-market niche, you will have to give some attention to that.
Maybe a matching (PVD) coating on the clip?
BTW: maybe I overlooked it but is the copper raw or coated?
- Will You Be Interested In Groupbuy For Prince? Yes, I Will Be In A Copper/Brass/SS
- Your Reasonable Price Bid For Prince in Groupbuy ? $30
- Your Question for Prince ? Are we gonna party like it's 1999?
- Your Question for Prince ? Why did you want to be known as this?
- Your Question for Prince ? Will you be coming back to the Coachella Music Festival?
No, as it does not use a high CRI LED
$40
Why it does not use a high CRI LED?
