Is it true. I have this driver on a XML and when battery is low, it starts blinking.
On the newer version of this driver the 105c it kicks down to The lowest mode when the battery gets low. I am not sure if it starts to flash eventually but when mine kicks to low for the second or third time I change it out. I don't like to push my batteries and I always carry a spare battery so it might start flashing in low but I am not sure.
Changed this to a Manafont XM-L dropin, very pleased. PWM is non-existent, takes solid 2,78A on High.
On med, quite loud whining but thats not a problem for me. Low is weak enough.
Hi guys i have a 105c i would like to make it a 3 mode, so by bridging star #2 from the right should be ok if ive read correct, im not a fan of flashy modes.
Yes second star from right to left, 3 modes no strobe.
The first star is also strobe-less, 2 modes.
awsome thanks.
what modes is the first star high low i would guess i have read the thread but i must of missed it
first- 2 modes (100%-20%)
second - 3 modes (100%-35%-4%)
The percentages are according to the OP.
However I've seen several taobao sellers saying,
100%-10%
100%-30%-5%
They could be referring to the older 105A. Pretty close specs anyway.
Is anyone selling these? KD links always seem to give me errors and i cant seem to find it myself.
It's available at Shiningbeam, KD, Intl-Outdoor, Lightmalls.
100%-10%
100%-30%-5%
Thank you, two modes sounds even better to me
Hikelite:first- 2 modes (100%-20%)
100%-10%
100%-30%-5%
Glad to help. Same here, two modes appreciated, especially with that percentage difference.
Yepppers. It could just be me but some mid modes are to high and some low modes are just to low and i just don't get eppo modes (strobe or s.o.s). I should of brought more 105c's to play with but two modes sound great to me.
Thanks for your time.
Where are these available nowadays?
http://www.intl-outdoor.com/torch-components-drivers-and-regulators-c-57_88.html
CheapThrills:Where are these available nowadays?
Thanks!
benckie: Hikelite:first- 2 modes (100%-20%)
100%-10%
100%-30%-5%
I screwed up some where I ended up with a 2 amp one mode lol I'm very happy with it still as its bright no strobe or s.o.s and I know it was my mistake
The two mode, "100% - 20%", is it normal it to draw 2.8A on High AND 0.27A on LOW ? :|
Yep it's OK. Some Taobao sellers actually say 100-10%, not 100%-20%. 10% of 2.8A is 0.28A Probably depends on batches or one description is older than the other.
CheapThrills:The two mode, "100% - 20%", is it normal it to draw 2.8A on High AND 0.27A on LOW ? :|
Ok, actually I think it is a good amperage for my uses, 20% could be just a bit too high...
But there are drivers, that also have 20% low?
The only 10% low is on the two modes, the other lows are 5% on the 105C.
I wonder if there are 105C that have 20% on low. The tested Nanjg in this review is 105A.
The Nanjg 105C has two resistor on the left of the MCU compared to the 105A.
