Done that the same as before & dosen”t work.
Have tried transferring the pics from dropbox to tinypic & tinypic says invalid code ?
The other forums I use putting up pics is simple this one is always a struggle.
Well it”s just over 2 dollars cheaper but where is it :person_facepalming:
BTW have you read the FAQ”s in the ad for yours ?
Says if you buy more than 5 pieces you get 95% discount !
Also, in my limited experience, Dropbox absolutely sucks for sharing files in an open, public way. Maybe it’s just me, but when I tried to link the cute 404 pic above to the URL you provided (Quote this message for details) I get:
503 Service Unavailable
No server is available to handle this request.
But clicking it again seems to work. Or not, if I test it (in Preview) again. ??? Not-so-much negging, but Dropbox seems to be another of those shaky Google hive-mind hacks that never seems to get “finished”.
So what URL do you get from TinyPic or Imgur?
Do you use the Simple Post Editor? The orange-brown “Insert Image” button only needs a valid URL. The width and mouseclick boxes don’t technically need to be filled, just the Uniform Resource Locator of the image file itself.
I’ve never used anything but dropbox my whole time on BLF and love it. However bella seems to have broken it, I can’t even log into dropbox.com! That’s a first!
This is the same sort of BS that has given our PhotoBucket fans worlds of grief. If the Host insists on processing your image (even if it looks like a valid URL), you’re not going to like what you have to go through to make this work.
The Host has to stay out of the way. I don’t get the feeling Google does that for anybody.
Here’s a tip that might help:
Get the URL of the image without parameters (the ‘?’ and whatever follows it), so that the URL string ends with the filename.jpg Use ONLY that, from “http” to “jpg” and nothing else. Get that string of characters into your clipboard & try to “Paste and Go” (if you’re using FireFox) or whatever your browser needs for you to directly input a URL & browse to it. If that works, the Insert Image URL box should work, and if not, post it anyway with a note & I’ll Quote your post & work it out for you.
This is the image code I get from tinypic
I use dropbox (with no problems I may add) for 2 reasons.
It automatically uploads any pics taken with my phone to my laptop almost immediatel, no plugging in cables & downloading pics.
The other main forum I use, a fishing forum, changed it”s server platform & when it did, photobucket which I had been using previously would not work with it but it was suggested to me to use dropbox which works perfectly with it.
It also works fine with the Koi forum I use & also the football forum I am on.
