Also, in my limited experience, Dropbox absolutely sucks for sharing files in an open, public way. Maybe it’s just me, but when I tried to link the cute 404 pic above to the URL you provided (Quote this message for details) I get:
503 Service Unavailable
No server is available to handle this request.
But clicking it again seems to work. Or not, if I test it (in Preview) again. ??? Not-so-much negging, but Dropbox seems to be another of those shaky Google hive-mind hacks that never seems to get “finished”.
So what URL do you get from TinyPic or Imgur?
Do you use the Simple Post Editor? The orange-brown “Insert Image” button only needs a valid URL. The width and mouseclick boxes don’t technically need to be filled, just the Uniform Resource Locator of the image file itself.
I’ve never used anything but dropbox my whole time on BLF and love it. However bella seems to have broken it, I can’t even log into dropbox.com! That’s a first!
This is the same sort of BS that has given our PhotoBucket fans worlds of grief. If the Host insists on processing your image (even if it looks like a valid URL), you’re not going to like what you have to go through to make this work.
The Host has to stay out of the way. I don’t get the feeling Google does that for anybody.
Here’s a tip that might help:
Get the URL of the image without parameters (the ‘?’ and whatever follows it), so that the URL string ends with the filename.jpg Use ONLY that, from “http” to “jpg” and nothing else. Get that string of characters into your clipboard & try to “Paste and Go” (if you’re using FireFox) or whatever your browser needs for you to directly input a URL & browse to it. If that works, the Insert Image URL box should work, and if not, post it anyway with a note & I’ll Quote your post & work it out for you.
This is the image code I get from tinypic
I use dropbox (with no problems I may add) for 2 reasons.
It automatically uploads any pics taken with my phone to my laptop almost immediatel, no plugging in cables & downloading pics.
The other main forum I use, a fishing forum, changed it”s server platform & when it did, photobucket which I had been using previously would not work with it but it was suggested to me to use dropbox which works perfectly with it.
It also works fine with the Koi forum I use & also the football forum I am on.
I agree it seems dumb to default it to false. But if you think about it, it probably costs far less to run their server farm if they don’t send the whole image every time someone views a post. Some of these BLF posts get 3000 views. If the BLF user posts a link, maybe 100 requests burden the server at dropbox.com. If the image is loaded into every page view, that’s a burden of 3000 images. And I’m only talking one photo for one user. Dropbox has 300 MILLION users and billions? of photos.
Us old farts used to use ftp (File Transfer Protocol) for this bonehead-simple function. When “brain-dead AOL-ers” (Weird Al) wanted to send huge pictures attached to E-mail bodies, we’d have to show them how to simply paste links to ftp: sites into E-mails & preserve the sanity of Mail Admins around the world. That seems to be basically how the “Insert Image” function works here.
And as always, if a User can break the system with just a mouse, that’s canonical proof the system isn’t finished yet.
Any suggestions to my earlier questions please
“Now can anybody suggest a light meter app for an Android phone as I would like to reference it against something.
I will use a light with a known ANSI rating first to judge how accurate both the light meter & app are.
Oh & can somebody point me to good thread (or explain) on how best to use the meter & interpret the results please.”
I just DLd a Light Meter app, called (ironically enough) “Light Meter”, but I can’t recommend it until someone (like you ) tests it against a calibrated meter. It’s cute and free, but YMMV depending on how accurate it is.
Ok I will download it when I have a chance then post up some results from the app & meter using an ANSI rated light for accuracy reference.
I still need somebody to tell me the most accurate/easiest way (I do not have an ILS) to obtain readings both using the meter & the phone app.
Probably won”t get any results up till next week as I am busy this evening & all weekend but will check this thread for suggestions.
Thanks for every ones help
The accuracy of this type app is all about pairing the app to the camera. Every Android device is different, the app probably only works correctly on the exact model phone the programmer had.
Not picking on you, but that reminded me of an old bit of wisdom:
That Light Meter app shows the LUX and the CCT (on mine — that may be settable in Prefs) with a cute analog VU-style gauge + numeric data. It also translates what it “sees” into keywords like “SUNLIGHT” etc. for DigiCam users. I’m away from my Droid right now so I can’t confirm any details.
THAT!!! Is the Secret Superpower of BLF!!!
Please take as much time as you need, and THANK YOU for it!
I specifically filtered for that. The one I linked lets you Calibrate it, although the standard question of “Against What” keeps me from using it “for score”.
The meter probably is not in yet
Joshk, I thought the lux meter apps use the lightsensor.
I could not install them on a simple android phone that has a front and back cam but no light sensor (used for dimming screen when talking and turning back on when you are not holding it to your ear or auto brightness setting)
It says device not compatible (I usually find apps on desktop PC and have a drop down menu with all phones I have not logged out on)
