Ask Olight tech support what is the minimum operational battery voltage for your flashlight. If 2’5+V, nothing to worry.
Store batteries where you know no moron would touch them.
Minimize battery stress keeping their no-load voltages well below the specified maximum (I’d say at or below 14/15th of this value) and, of course, not too low. Between 40-50% of SoC (state of charge) is said to be optimal for this purpose, which should correspond to around 3’77-3’85V… but heck, no need to be so anal on this, just aim at around slightly above nominal no-load voltage and you’ll do fine.
My last li-ion battery shipment tested exactly 3’8V on my multimeter.
Storing batteries on a charger is generally unwise, to my knowledge lots of them have some kind of ghost drainage which could kill unprotected batteries if kept for long enough :person_facepalming: (it could be a very looong enough, though).
As I said, there’s really no point in preventing your device battery state of charge from falling below 10%, unless you deliberately do so in order to still have some power left in case of emergency.
Device manufacturers know what they’re doing: your stuff’s battery will never get damage no matter how many times it does a forced 0% shutdown. Every bit of this I already explained above.
Keeppower has a protection circuit at the bottom so you cannot harm it by emptying it fully. Just keep on using it as you do.
That is if it is NOT an IMR battery! They do not have the protection.
Do you mean 16340 (RCR123) or 18350? I’m using the Olight 16340 in mine and didn’t think 18350 would fit… Sorry for derailing thread…
I did do one runtime test with the S1 till the protection kicked in. Was tempted to do another runtime test at another level, but then didn’t want to run the battery all the way down again.
I do not remember to have said I used just ⅓ of my battery capacity. I, generally, charge up to 60% of my maximum battery capacity so, in essence, that means I, at most, charge my device twice as much, all other conditions equal. Battery life expectancy, as said, potentially cuadruplies.
You could still benefit from a good deal of extra life expectancy (nearly 3x) by going up to about 72-74%, maybe.
With regards to the added wear on the USB jacks, I can buy a 10-pack of ’em for a buck or so (I have around 4 jacks lying somewhere on a bag, tinkerer I am). I am quite dextrous wielding my quality JBC soldering iron, and I have plenty of solder wire, cables and stuff… :cowboy_hat_face:
Hope this is adequately understood.
Could someone please present the discharge charts for the following two batteries? 1) NiMH 3 cell, 3.6 volt, 930 mAh capacity and a load of 500 mA. 2) Lithium-ion 3.7 volt cell, 800 mAh capacity and a load of 500 mA. I would like to comapre the voltage of the two batteries as they drain. Thanks
Reviewer and tech wizard HKJ may be of help here. His website, https://lygte-info.dk, hosts thousands of battery reviews. Your question is too generic, there are lots of different possible batteries meeting those scant specs. A 930mAh cell could be some Ni-MH AAA, or some rugged long life industrial Ni-MH AA. Various 14500 (AA size) cells meet 800mAh li-ion capacity spec. And there's more.
Guys for Samsung 18650 30Q when do you charge them?3.6 or lower volts?
One more question if you put them out of the flashlights and store them which is the recommended voltage for storing li ions lets say for an year?
I wouldn’t worry about self-discharge on a cell in storage or in a flashlight with no parasitic drain. I have 50+ 18650’s stored away that were at about 3.6v 5 years ago and some that I pulled last year were still around that.
If anyone wants to know how far a cell can be discharge and still perform well I recommend reading this entire thread.
I read a lot of datasheets with lots of opinion’s on the web and I have personally tested a lot of cells.
The thread above goes against everything I had read or was told. Not to say the datasheets are wrong but no data on what happens if the cell is subjected to outside of those specs. It’s a must read for battery Guru’s.
Thanks for the info HKJ. :+1:
I also still have the batteries in that thread at 10 years old now, I may do a discharge test just to see where they stand.
Anyone else still have some of these?
bluereidon, charge your batteries when you see fit. I usually do it below ≈3.6V, to always have some juice left.
Li-ion cell over-discharging is something I do not worry about. 2.5V is a frequently used and perfectly safe figure, even 2V for some chemistries. Those numbers can be found in top OEM cell datasheets.
I've recharged cells which were somewhat below 2V, from laptop packs. They can still work after this but I advice to keep them quarantined while whatching their self-discharge rate.
To me, the over-discharge thing is a busted myth, of course thanks to wisdom and discernment.
I recently purchased some 18650 cells and when I put them in the charger they were uncharged. Is this ok ? In the past, all cells that I have purchased have had partial charges when I received them.
Did you measure their voltage with a multimeter? What was their exact voltage?
If you’re reading zero volts, check both ends of the battery to see if there’s a thin clear plastic tab on it. Sometimes they put those on to prevent shorting or discharge during shipping. Obviously, they need to be removed.
If they’re protected cells, they’ll also read 0 volts if the low-voltage protection circuit has triggered. They might still be okay after activation.
If you’re reading something between 0 and 1 volt, I personally wouldn’t trust that cell. Under 2 volts, I’d still be a bit nervous of it, depending how long it has sat that low (and you don’t know how long).
The problem is not how far it works to be discharged, it’s about how far do you afford to do it.
Original Li-Ion spec is very clear: at 3.3V it is considered discharged and at 4.2 it is considered fully charged. Anything out of this interval will inevitably reduce lifetime. They do that to smartphones a lot: they overcharge to up to 4.35V.
Given the manufacturing improvements over the years, yes, the damage taken is smaller but it still happens: the cell will have less life-cycles.
So when choosing how low you want to go with a discharge, you practically establish the life of your cell.
If you want super extended lifetime for you phone battery you can stop charging at 80% and don’t discharge it all the way. In fact, most phones will try to stop you from discharging completely (have failsafes at around 15) as getting too low may not provide sufficient current for normal functionality anyway. Some battery-related applications also recommend charging only up to 80 which corresponds in most cases with the 4.2V value.My article about phone batteries here.
On the laptop side things are a little more elaborate. Laptops will not overcharge Li-ion cells as far as I’ve tested until today, but they have another problem: most models except the high end and top ones have low quality or even no charge/discharge BMSs. That will mean in time (taking a 3 cells in series battery as example) that a pair of cells will start not getting enough charge, another will remain balanced and another will overcharge, leading to 2 / 3 cell pairs starting to degrade faster and faster. That is one of the main reasons of current laptop batteries dying so fast.
In the case of laptops I only use them on battery when really needed and I don’t cycle the battery as some do because cycling does lower lifetime compared to not doing it.
