Review - Astrolux SC Copper 14500 Flashlight
I think the whole point of the tailcap light is so you can find the light at night. You aren’t supposed to lock it out.
Always wanted a Copper Light and almost pulled the trigger on the Tool. Managed to resist, but after getting the Aluminum, I had to order this one. What a great light!
Shame it does not use Reg. AAA’s.
Thanks for the fine review.
How does this compare with the S1 in throw and flood?
Does it, or did it ever, come with the S1’s beautiful 5A, 4000K tint?
Thanks hatman. The beam of the Astrolux S1 is more flood than throw, whereas the SC has a more defined hot spot, so throws further and has a good level of spill in the beam pattern. The Outdoor shots I took look darker than reality. The SC in my mind would be a good general torch for outdoors where you can use it for shining ahead to look at the walking path or occasionally point the flashlight at some distant object. The S1 is very effective for walking where you are wanting the immediate area lit up. Both excellent flashlights. I did make a small video where I flash the SC and BLF A6 3D across a road to a wooden fence as a comparison. The Astrolux S1 and BLF A6 are almost identical. If I get some time tonight I’ll edit and load onto the review.
The tint on the Astrolux SC reviewed was a 1A which is very different to the warmer 5A.
The only way to disable the tail switch LED is via some mods. See BLF Kronos X5 mod x6 mod faq thread tailcaplight where there is some discussion re the mods that can be made.
The short answer is you need to either remove the resistor or the LED in the tail cap, the tail cap light and the drain goes away then. You could swap the switch board with one from a light that doesn’t have the lighted tail cap.
I’ve found if I’m carrying the X5 I need to charge the cell often enough from just use that the tail cap drain isn’t an issue.
Great flashlight review. Specially those images. But don't know why i don't like silver color much. I like Black color flashlight. But, I like this ecogear fx torch very much.
I have been provided a special coupon code of ef5700 for a further discount of select Astrolux flashlights on Banggood of 25%.
Astrolux S2 Astrolux S2 CREE XPL-HI 1400LM EDC LED Flashlight 18650 $34.96 after coupon ef5700
Astrolux S3 Astrolux S3 CREE XPL-HI 1400LM EDC LED Flashlight 14500 $27.96 after coupon ef5700
Also reminder that the deals on the Astrolux SC and SS end this month.
Astrolux SC $45.95 for all of April 2016
Astrolux SS Astrolux SS Stainless Steel CREE XPL-HI 1400lumens LED Flashlight 18650 $47.95 for all of April 2016
(all links above are not aff links)
Thanks Rolz for the review.
Rolz, 200+ grams is pretty weight.
Do you have any problem/inconvenience when carrying this flashlight in your pocket?
Rolz has no problem carrying this light as he is an aussie, & aussies are bred strong.
For most people it should be fine. The flashlight is much heavier than any of the same size that I know of, but as it’s quite compact it fits in the pocket nicely. With jeans on not an issue. In looser trousers it’s more noticeable and may be a little too heavy for some.
Thanks Rolz.
As patmurris’ saying, I’m trying to find reasons not to buy this flashlight :smiley:
@agogohome: your affiliate links are not welcome here.
Marked as SPAM.
I did not click on the link but the post itself looked suspicious.
And the account was made literally today. :confounded:
theyve got this on massdrop for $40 plus p&p although it shows me p&p will be $7 to the UK. which is currently cheaper than bandgood which is now $59.99 (for me anyway)
Thanks for reading the review, and also thank you for your great reviews.
It’s are really nice Flashlight, both in performance and looks. I lost interest in 14500 battery powered flashlights up until I had this one in my hands. I dont have the standard non copper version, but that would also be a great buy for those simply looking for performance. The copper version reviewed in this review is in my mind “a piece of art”.
High @Rolz.
Thanks for the comprehensive and nice review, not to mentioned the excellent beam shots.
If you don’t mind, I posted a link to this review over at my comment on Massdrop page for Astrolux S3 (aluminium) drop as many non-flashaholics there who are interested with the S3 are clueless with what this light can offer.
I’m not affiliated with Massdrop, but just want to help some lost souls over there :stuck_out_tongue:
Thanks very much for this most excellent review!
I'd read it a while ago so, while I was on BG picking up another two S1's as prezzies for my son & my daughter's BF, and I spotted the SC for just £26 I knew I had to grab it for that price. I'm not a fan of the smell copper leaves on my hands, it's one thing that bugs me about my S41's so I'll be gifting this to my daughter, it's just her style and the illuminated tail cap will be perfect for when it's in her handbag.
It arrived this morning with the two S1's and it looks fantastic with the exception of a couple of issues. The first and most obvious was the scratches at the top of the head as you can see: http://i65.tinypic.com/2cy36vr.jpg. Luckily it wasn't in the copper but the clear coat that's been applied. I've sorted it with micro-mesh, I don't know how this will affect any patina that might develop. The second issue was really rough threads in the top of the head, nothing that I can do to rectify that bar applying some silicon grease, a bit of a non-issue as I doubt it will be opened again.
The last thing that's driving me nuts is I'm having no luck at all programming medium press/reverse mode. I'm switching it off after six flashes & the buzz flash (and on the buzz flash) but no luck. I had no problem changing the mode group so I have no idea what the issue could be. Any advice from anyone would be most appreciated. :)
