Yes, the light functions normally besides stepping down in ALL modes after 9 seconds.
Retaining rings are tight. Smacking/shaking the light causes no issues. I tried the tailcap from the copper X5 clone and got the same results. I looked at the driver again and it has the same 4.7k and 22k SMD resistors as the copper light.
While attempting to set a new thermal protection value, the light seemed dim and did not get warm after 2 minutes.
I pulled the cell and it’s at 2.8V. It was at 3.6V two days ago. :person_facepalming: I hadn’t touched the light since then.
Remember, I had removed the bleeder resistor from the driver before verifying that this light worked properly. I’m suspicious that I may have caused this issue, but I don’t see a bridge at the bleeder resistor’s pads and my DMM shows no continuity between them.
I’ll swap in a Mountain Electronics driver with Bistro UI when my latest order arrives, and get photos of the questionable driver when I remove it.
Thank you both for your suggestions. I’ll report back in a few days.
Tried to remove the driver retaining ring on my X6 yesterday, I can get it loose and it freely rotates 2/3 times before it binds up and won’t undo any further.
Do I have to remove anything else in order to get driver retaining ring out? :question:
I have the stepdown in all modes too, in at least two of my Kronos lights. Why would a wrong stepdown temperature cause stepdown in all modes instead of just turbo??
I solved it by just un-engaging the turbo-timer. It was not my favorite feature anyway.
Just got mine after waiting two months! Most notable is the fact I didn’t get a BLF-X5 but a Astrolux S3 instead. Not sure how I feel about that but I think the Astrolux is supposed to be a slight improvement so maybe it’s my lucky day?
Would a tiny bit of WD40 help? I’ve been using some fairly fine needle-nose pliers, I think something else is going to fail before the ring is free :/. Going to invest in some Circlip pliers, might even make an adjustable retaining ring wrench by drilling holes and fitting pins into the sides of an adjustable wrench…
The ring may be below the end of the threads and failing to engage — try holding it ‘upside down’ and trying to pull the ring a bit while turning it, if you can.
i ordered 3c lights early in the GB, then much later agreed to accept astrolux 3c lights, and they sent me astrolux 1a anyway. lotta problems with seller and maker in the last 2 GBs.
Not trying to call you out personally, ZozzV6. But, I think this needs to be said. This group buy has been over for a very long time. Before that, it was in process for a very long time, then in production for a while, then in purchase/ship mode for quite a while, then in public code mode to finish off the remaining stock. What I’m getting at is that anyone expecting to get a deal at this point has more than missed the boat. They’ve missed the whole planet. At this point, the pricing is set by normal everyday business practices.
Sorry for misunderstanding, and I missed the dates too! Maybe the planet I not registered here very long ago but I got here often by my google flashlight searches.
I dont want to complain just saw that I can’t find this price written anywhere. I really appreciate and thanks for those who made it possible these lights! This price is also really really the best for what you can get it. I have a BLF D80 as my first BLF light and I want more. Just can’t decide between the X6 Al or the SS version. I like more the look of the SS but I don’t want to have any scratch on it by use. But I can’t afford both of them
And sorry for my english. It’s not the best.
Cheers! And have a nice day for everyone in here!
I haven’t had the best of luck with the X6 and X5 family of lights…
First I received an Astrolux SC (copper X5 clone) that acted strangely due to a bridged connection on the driver. Removing the bridge fixed the problem.
Next I got an Astrolux S3 (aluminum X5 clone) that stepped down in all modes. I swapped in a 17mm driver from Mountain Electronics.
Today my aluminum X6 finally arrived… DOA. The threads weren’t cut far enough and the driver retaining ring falls past them. I added some solder blobs to thicken the driver and the light powered on but stepped down in all modes. Swapped in a Mountain Electronics 17mm driver running Bistro UI, after adding some solder blobs to it.
I’m still waiting on an Astrolux S2 (aluminum X6 clone) for a friend. Maybe it will work out of the box?
I added an XM-L2 emitter inside, and it worked great! Got a higher amp reading too. It focuses perfectly. The hotspot is between the size of the BLF X6 and the stock Kronos X6.
I’m sure the answer is in this thread, but search as I might, it is alluding me. The question is, “Is there a way to disable or toggle the tail switch light?”
Don’t get me wrong, I love the idea, but I’m afraid constant on will drain the battery. The only solution I’ve found is to remove the battery, very undesirable.
