Shoot I have a slightly older Convoy C8 than the current version… If the Convoy currently being produced (V3) has the “modified square” thread profile (10° included angle) like the Thorfire C8S, the C8 platform will be abandoned and I’ll make the heads for the S2+. If the Convoy C8 V3 has a truncated triangular thread profile (60° thread with the tips cut off) then we’re all good.
I chose the C8 platform because I like the beefier body over the S2+, but it’s a shame the design has changed so many times.
It’ll look good no matter what.
Just in the planning stage right now. I’ll post up some CAD models in the not too distance future.
Bigger copper means it will cost more money and will be less pocketable, but I could offer a bigger one, sure. The current plan is to make the head from 1.375” copper bar, which will be slightly larger than the finned section on the stock C8. The fins will be a little deeper but fins don’t do anything on small flashlights, you know.
Edit: The metal distributor I normally use only has 1.25” bar and 1.5”, no 1.375” bar, so I will have to get quotes on metal from a different local distributor. The price may need to go up slightly, especially if I make it form 1.5” bar.
It would take more work and would cost more money. Sure I could start selling somewhat expensive full copper S2+ style hosts if anyone’s interested.
If I make a full host I think I’d abandon existing “formats” since they are prone to changes and tolerances which are beyond my control. I’d use an acme thread profile.
Driver: I’d go with a FET driver of some sort for some WOW turbo action. Choose a battery to pull the right amount of amps to whatever LED’s you choose.
Emitters: Cutter quad stars are going to be available from a few retailers soon with various LED’s on them, I’d imagine.
No retaining ring necessary with the socket head cap screw system.
I see that the final design may be undecided as of yet, but I’m very interested as well. I’ve got an older Convoy, the one with the removable pill, but I could buy a new host if needed. I’ve also got a couple of Thorfire C8s hosts if those may work.
The other idea being discussed here seems to be a solid copper full host modeled after (or at least similar to) the Convoy S2. I’d be all over that, especially if the tailcap could be machined to accept the metal switch from a real S2.
So I guess what I’m saying is put me down for one each
We can`t understand each other one more time. Simply:
Standart thread making operation calls lathering (not milling)
Most hosts have metric thread pitch.
Metric thread have a standart shape with 60-degrees top (and same cutter shape)
TRUNCATED TRIANGULAR threads is standart 60-degrees threads with cutted tops.
A year ago I have sold few C8 V2 pills and I named them “with trapezoidal threads”. Why so? It is too hard to make such threads with standart 60-degreed thread-cutter on lathe, so it is nessecary to make/use special cutter with trapezoidal shape.
Yes there are a couple of standard pipes that fit our cells
No worries about threads in existing models
Tale the closest to fit 26550 cells
People can ask for specific lengths
Design a head like the C8 but fitting that pipe
Though a little more then I like to spent I’d buy one just for the sheer awesomeness.
Now I do not know if it would fit my Convoys and still i d be left with a perfectly fine C8 head. So even after opening this thread a couple of times to say yes incamt justify it.
As far as I know there are two styles of thread on the Convoy C8. A really old version with triangular threads and a newer one with truncated triangular threads. If there’s also a square thread version I’ll scrap the C8 head concept entirely.
As for making a whole light, if I made all of the parts S2+ compatible, the parts could be purchased individually, which some might consider a benefit. If the body were made from tube it would be out of a different alloy of copper than the rest of the parts, but no big deal. The ID of the tube would be .75” which is about .02” [.5mm] larger than the stock S2+, but also no big deal. A stock C8 has a .740” ID so it’s close.
PVD coating is insanely expensive, but black chrome is a good option, and also Cerakote. My experiences with plating companies are always mixed.
Just one guy’s opinion over here, but I’m a lot less interested if its PVD coated. I want real copper and I want to feel it with my hands, not hide it under a coating.
I’ve got a Cerakote light. Its not nearly as scratch-resistant as a good type-3 ano. And again I wouldn’t want something coated over all that beautiful copper underneath.
Nah, PVD is not an option. Black chrome is an option, and is what they put on Lamborghini rims and stuff. It looks great. Brown oxidized copper ain’t all that pretty in comparison and it makes your hands smell funny.
