As far as I know there are two styles of thread on the Convoy C8. A really old version with triangular threads and a newer one with truncated triangular threads. If there’s also a square thread version I’ll scrap the C8 head concept entirely.
As for making a whole light, if I made all of the parts S2+ compatible, the parts could be purchased individually, which some might consider a benefit. If the body were made from tube it would be out of a different alloy of copper than the rest of the parts, but no big deal. The ID of the tube would be .75” which is about .02” [.5mm] larger than the stock S2+, but also no big deal. A stock C8 has a .740” ID so it’s close.
PVD coating is insanely expensive, but black chrome is a good option, and also Cerakote. My experiences with plating companies are always mixed.
Just one guy’s opinion over here, but I’m a lot less interested if its PVD coated. I want real copper and I want to feel it with my hands, not hide it under a coating.
I’ve got a Cerakote light. Its not nearly as scratch-resistant as a good type-3 ano. And again I wouldn’t want something coated over all that beautiful copper underneath.
Nah, PVD is not an option. Black chrome is an option, and is what they put on Lamborghini rims and stuff. It looks great. Brown oxidized copper ain’t all that pretty in comparison and it makes your hands smell funny.
The rendering looks amazing! I can imagine it on a C8 body already :laughing:
I’ll try to get some macro shots of my C8 V3 when I get home so it can be determined if they’re square or truncated triangular. IIRC they are not 100% square, I have a V3 from last year and another one ordered just recently, the parts are interchangeable but the finish of the newer one is less matte.
I don’t. I describe them as triangular, trapezoidal, and square just based on their shape and being a layman when it comes to machining; I don’t recall seeing anything other than those three on flashlights.
Also, sorry for any confusion above. I always think back to my 3 year old Convoy XML C8 (presumably V1?) as having triangular threads; however, as I just checked and they are actually trapezoidal on the battery tube.
The “ThorFire C8s” both removeable pill and integrated shelf version have square threads. I believe they have yet another version of the C8, the “ThorFire C8” I don’t know anything about it apart from it having a removeable pill.
Trapezoidal threads, which have a 29° included angle for acme, 30° for metric, are easily confused with square threads so that’s understandable. Most square threads are actually the “modified square” profile which has a 5° angle per side, 10° included, like those on the Thorfire C8S.
A lot of folks call the truncated triangular threads square also which I tend to call out when I see it. Triangular threads have a 60° included angle.
I do not currently have the capability to cut square threads, but I can cut trapezoidal (acme) threads.
I’m at home, so here’s a photo of the threads on my Convoy C8. Mine’s a bit older, has the removable pill instead of the shelf. Its worth noting that parts to this light are interchangeable with a Thorfire C8s that I also have.
I’m not a machinist, but I’m pretty sure these are the trapezoidal threads you’re all talking about, yes? If its not the same threads as the latest lights then I’ll buy a new one. Not a big deal.
I think you should just go with the latest Convoy C8. The C8 is the better type of light for this cool, one of a kind head. There are so many different models out there, you have to decide on one. I have an older model, but I’ll order an new version just for this custom head… Convoy hosts are pretty inexpensive.
I could make you one during the run, sure. It would have to be bare aluminum unless there was enough interest to warrant the minimum “lot fee” that goes along with anodize which is $50+.
Yea I have that same version. I believe it was called V2 when I bought it. V1’s had a different pill, with a “cap” for the driver retainer rather than a retaining “ring,” and triangle threads that still had the “tips.” These are the differences that I’ve noticed from the photo’s I’ve seen at least. I am OK with V1 being different but I really want V3 to be the same as the V2’s.
Would it make sense to include the host in the GB? That might eliminate the problem that occurred with the A6 and it’s inconsistent machine specs. More likely to get all one size. I’m in either way as long as a link to the correct host is available. Khatod quad.
