Ordered all S3 bins from Mouser lately( K51, KE51, K51 and K53), they all came “improoved” ones…… definately not good for us:/
It would be great if an australian guy order some emitters from Cutter for evaluation, if they came out good we could arrange a group buy, at least the EU folks arround here, personaly i would buy at least 100 if they came one non improoved
About the S4 issue: Arrow Eurpoe has 5 bins S4 in stock( reets of 500pcs) - the problem is they dont offer samples from then, i cant even test …. one cant tell whats inside only from the part number( the production dates are 05-07 21015)
All of the XPG2s I had up till now must have either been from the origonal type or I just didn’t notice the change. However I will throw my 2 cents in. This “upgrade” was not only done to XPG2s, but also to XML2s. Or at least “a” change was made. I never had any trouble with a change in tint, however the output from a single XML2 U4 bin dropped VERY significantly about 3 months ago due to a spike in the needed VF. I tested piles of LEDs from multiple sources to try and regain some ampers, but no luck.
I probly would not have even noticed accept I test custom builds like my shorty Maglites before they go out on a regular basis. Out of all the XML2s I have used since then I have found only one that tested out the way nearly all of the ones I got off RMMs first reel last year did.
I just hope when XML3 lands we recover some of that nice low VF as most of my builds use a mosfet driver.
Did some testing today with one XP-G2 from FastTech (unknown bin) and with these three XP-G2 S2-1A’s from Kaidomain (http://www.kaidomain.com/Product/Details.S023026). Results are pretty disappointing, I was expecting much more, hoping that these leds from Kaidomain are from older batch. Testing was done with Samsung 30Q’s and Samsung 25R’s, both batteries delivered similar results. I wasn’t using any drivers, just direct drive trough 18 AWG wires. XP-G2 from FT is in my Brinyte 158 so I managed measured throw (194 kcd, 30 sec, 3,7m).
1. XP-G2 (cold tint, unknown, from FT) - Bat 4,21V, Max 3,10A, VF 3,90V
2. XP-G2 (1) (Kaidomain) - Bat 4,21V, Max 1,5A, VF 4,08V
3. XP-G2 (2) (Kaidomain) - Bat 4,21V, Max 3,76A, VF 3,82V
4. XP-G2 (3) (Kaidomain) - Bat 4,21V, Max 3,83A, VF3,80V
As you can see, results are all over the place with very high VF. For now I’ll wait for someone to test the new XP-G3 and make my decision on what to do with my Brinyte 158.
There might be a hope in Samsung 3535 high binned emitters, i just got mu hands on some of those binned at 160lm per watt, and initial tests showed their cap could be removed easy
Will check them asa i got home today
FYI, a few weeks ago I checked LG HC35C1 led (=a few years old, the newest gen. is HC35C4, impossible to obtain for me) for hot dedoming and in petrol, in both methods the dome would not come off in one piece and bits of silicon remained over the die. The phosfor was pretty solid though, it allowed scraping off remaining bits of silicon with a toothpick,but not all, tiny bits were left on the die.
Getting ready to build a new batch of lights and wish I could get my hands on some of the original XP-G2’s or something similar. If not, I might have to just use the XP-L HI.
Well by default its something like S2, havent tested it in details with the dome on, it is capable of maitaining 4.5amps ( with a single battery and a fet dd driver), dedomes pretty clean though.
unfortunately when dedomed it performance drops dramaticly, its like 40% weaker than those upgraded new S4 emitters( 145kmcds vs 100kcds in a C8 host)…excuse me, but even a dedomed XPE2 performs better
It has a potential, i am pretty sure Samsung will develope those in future but for now those aint suitable for out throwing needs
Better not, try dedomed V6 instead, it outperforms any HI by 25-30%, or even a dedomed U3
Just curious, have you noticed real-world difference in your builds? I understand that V6 should out-perform the current highest binned HI’s (V2 or V3?), but dedoming is going to reduce overall output of the V6, no?
After reading through this thread, I came away with the impression that there’s no real advantage to dedoming a XP-L (as opposed to using a XP-L HI)
Ofc i did m8 especialy considering throw, those builds are mainly used in a real world situations, mainly hunting: many of them, in lotsa different hosts
The mentioned thread is old, just a build that i made today: actualy those were 2 flashlights: both in B158host, one with XPL HI ( v2 3b)one with a dedomed V6 1A, the first gave 170k mcds( at 5.5amps), the second 215k( at 5.6amps)- the reason i made the first one with XPL HI is that fella hunter will swap the pill inside randomly with another pill( ir based) so i presumed HI in that situation would be better, he could simply damage the dedomed emitter occasionaly
Try out V6 1A from MNT or KD , they dedome pretty okay( not like V6 2D or V6 0d from FT) youll see yourself the difference, they “sing” paired with a nice fet dd driver and a 30q/vtc5 battery
