Today, I started a new triple : S30RII !
I plan to use 3 of the 10 219C that I ordered on RMM at $2/ea.
Well, today I only received my 3XP boards and 10507 optics from Intl Outdoor.
I had to drill in the center of the stock LED shelf :
The copper pill, made of three 3mm plates (saw, file, drill…)
The Noctigon had to be reduced to 18mm in diameter :
Dropped in :
Annnnd that’s all, the bezel and stock lens + u-ring will then be screwed to close it all.
The height is exactly the same as stock copper board + optic with a 9mm height pill.
Very nice. You sawed and filed the copper by hand? A modder after my own heart. There’s just something that feels good about shaping a piece of copper by hand, and having it fit perfectly.
Yes, I cut some 20mm square, drill a hole in the center, cut a rough circle with a saw and file it fine. Then I mounted it on my drill, and filed it again while turning
Nice combination of host and triple! About the board filing, check for a short between the metal core and the led-minus (I remember some less favorite hobby-moments)
I modded a hugsby ml-8. After wrapping the head and tube with rubber i was able to break the thread lock glue with a small pipe wrench and a vice. I took the stock pill and inserted a c8 pill in it to hold my driver (a dd 6v zener mod). On the top side I punched out a 20mm copper disc 2mm thick. polished both sides, added some therm grease, and slapped an XHP70 on top. Soldered it all together and whallaaaa. The factory OP reflector made for a nice tight beam with good unblotched center. If anyone is interested I can take pics and post em. I am making this post because when i did a search for such a couple weeks ago I found very little. So maybe it will be of interest to someone.
God work on the Hugsby ML-8. I know I promised pictures of it apart a while ago, sorry totally forgotten. I am currently working on adapting a smo reflector. I also had to order new o-ring for the bezel. Original was like soft plastic and did not seal properly.
Today I build my 4th C8 with XP-L HI, it’s just another C8 build, but this time I used DrJone’s magnificent H17F driver.
The H17F is beautifully designed and the programming possibilities is just mind blowing, the most amazing feature? A PID regulation that actually works, watching the output go up and down on a light meter is rather satisfying. I don’t have a data-logging light meter yet (ordered the UniT 382), but I couldn’t notice any output step during regulation, it happens very fast and smoothly. We’re talking about zebralight-level PID here…
Compared to a regular FET+1 the amps in turbo only dropped 0.16A which is really nothing for 5.3A+ on a single LED. I would confidently use this driver for any triple XP-L build, the FET is tiny, but it can handle some serious power.
I modified my ankle last Sunday into a constant source of creative interruption.
Tweaked a Convoy BD1 to 4.2A and moved the warm white emitter to a copper star. Very cool how this light is built, seeing the charging indicator light up the reflector from around the LED is cool! Nice light, well made, the charger didn’t take my Powerizer 26650 to a full state of charge though, terminating at 4.13V. I’ll try again with a newer cell.
Bumped output and changed emitters in a cheap zoomie, went with an XP-L V6 1D over the XM-L that was present, took it up a bit over 4A with the stock driver. (blinkies, blech!)
Spent some time working on an extension tube for a TR20, my ankle hates me. This morning I’ll be enlisting the aid of a more professional modder to address the situation. They call her Dr……
S70 simple driver adapter for a RMM-FETDD26mm, using (3) 30.5mm copper hydraulic washer’s (seals). S70 driver…. RMM FETDD26mm driver… Copper seals… Measurements… Splitting one of the rings fit it tight to the ID of one of the other rings,this supports the FETDD driver, liberally coat with solder paste, put all 3 together, and heat till nice and silvery. Driver retainer matches perfectly… Fits S70 driver cavity with just a tiny amount of slop… Adapter, and driver in S70 head… Driver retainer holds everything together… Ready to rock some High Amps!! Next S70 mod will be thermally potting the head, close up some of them holes and get the heat out…… Using this stuff… Pushed it thru the back of the driver cavity and then out. Let it set up a bit, then using a sharp edged tool, skimmed off close to the emitter surface, and then jus finish up how ever you want. Now just drill simple holes for leads and drill and tap for the mcpcb. My S70 is pulling 11.7 amps with the new N41B mounted on the Maxtoch, heat is now felt at the head faster, thermal transfer is way better now, this stuff works well for potting and cost alot ALOT less then Stycast!!
I built a convoy M2 with qlite 3A driver and a eagle eye X6 XPL HI host from gearbest with the mtn FET+1 driver, both with XPL HI V2 3B emitters on noctigons from intl outdoors.
The M2, at 2.9A, has 31,800cd, measured at 6.05m.
The X6, at ~5.2A, has 71,400cd, measured at 6.05m.
Lux measurements made with tondaj lx-1010b.
The X6 came with a centering ring that seems to work with the XPL HI emitter. It is circular and it rests on the 4 corners of the emitter rather than on the mcpcb. I haven’t tightened the bezel all the way down yet because I’m not sure how much pressure the reflector is putting on the centering ring and emitter. For anyone who has this host, what has been your experience with using the centering ring?
Measuring standard is 5M, taking readings from non standard distances skews the results. Just saying.
X6 centering ring SHOULD fit around the emitter, sit on the mcpcb. Sometimes overflow from the emitter reflow makes bumps or “balls” of excess solder that will hold the centering ring up. With this one, being round surrounding the square substrate, that shouldn’t be a problem. But it isn’t supposed to sit on the corners of the substrate.
Edit: The 3 newest ones I received DO have that odd new centering ring. It is cut out on the bottom to fit around the substrate but has a thin shelf on top that partially covers the corners. Beats me why they keep changing things! It appears to put pressure on the mcpcb itself, it will almost assuredly tear the phosphor/silicone off the corners if opened up repeatedly. I think if I am keeping these in this single emitter set-up I’ll trim that overlaying area or change out the centering ring altogether. They also appear to have a copper mcpcb, haven’t tested yet to see if they are DTP.
