Unfortunately by the time that was pointed out it was too late to change for this first release but it was noted and the next revision should use a larger board. It’s probably going to be a bit tricky soldering wires on this one too. Hopefully it will be so powerful out of the gate that normal humans wouldn’t think of modding it. Present company excluded for obvious reasons.
Any normal humans reading this post??? No? Nobody? Insert audio track of crickets…
Really no big deal to gain more solder joint clearance, just tape the front of the reflector up with painters tape and the the emitter hole, just center over the emitter hole closing it off completely. Then file or sand the emitter base to gain clearance…
Based on the info Simon just sent me I think you might want to hold out for the L6.
Simon says he should be able to sell the light in about one week. I am waiting for him to confirm a few details before I share them but if he did what it looks like he did this might be a real show stopper.
I know man I’m trying to stay awake so Simon can confirm a few details. I’m not trying to tease anyone I swear. Please hold on just a little bit longer. This is torture for me too!
All mod you can do after all is a dedome. This came as stock as a modded one Very nice. I did not wanted such a big light but now I found myself in this topic every hour…
Is the amp reading 5A? That is nice.
Also, a spring bypass right out of the factory is very nice too, but I won’t have any use if it isn’t done right. It should be done with atleast 20(?) awg wire.
