No sweat.
I really can’t recommend hand-soldering on these (I use a simple Youyue858D+)
And I’m still not convinced this LVP thing is really truly worth the effort we need to put into this.
I’m about to finish the 17mm board for a simple FT-driver swap plus ATtiny13A, that might be a better and easier starting point.
As far as the 15mm line goes, I’m still happy with the HQ15B v2 approach. I got them as 0.8mm board already, but the fab shifted the soldermask. So before I re-order them, I’ll take the opportunity to fine-tune them and then, in 4-6 weeks …
Mostly I’ll use any 15 mm version for presents/gaws for people that don’t use rechargables anyway. It would be nice for nimh cells though. At a minimum a low voltage signal could be done.
Yes, LVP (as cutoff) is meant for rechargeables only. It would be no good for primaries, as they are supposed to be drained fully.
If we get this to work and if we get a firmware for this (big ifs) then it should be implemented to make LVP optional.
Could you please rephrase this (language barrier here) as I’m not sure what you need. Which voltage in which condition?
And, err, boost ic, right?
Oops! Yes, with a single 1.5v cell the current supplied by the boost ic drops steadily. Where with two cells it maintains output for some time. Kind of a lazy question as I should just look it up myself from HJK’s test data. Sorry.
Hmmm, when I look at your quote I think it might be a good thing that I take the time to consolidate all the information in a new thread.
I need an OP to do so and admit that I had up to now avoided to branch out. But I have several boost driver versions now and more planned and I need a clearer arrangement.
Honestly, it’s nice to know there is still interest… keeps me going on.
If it were only for myself, I would have wrapped it up with what I already have months ago.
I’m all for those small single AA lights that all need a 15mm boost driver. I’m looking for efficiency and good output on an eneloop/alkaline if possible, but even more for a more invisible PWM and a less medieval UI. My best example of a nice and good output AA boost driver is the Olight S15 driver (but I would like clicky operation instead of e-switch), but that is probably too good to be true.
For me. I’m looking for 1.5 volts usage, 14500 is not a big deal to me.
3 or more levels with a great moonlight mode (lower the better. 0.1 lumens? Less?). If super low moonlight need 4 levels to keep the spacing reasonable.
Option for no memory or hybrid memory. Off time, short latch time.
Lvp not a big deal for me since 14500 is optional. Max mode, 300mA or more? I’m not looking for a barn burner.
Programmable is nice. Invisible pwm.
15x4mm size? I want to put it in a Tain Aura titanium AA.
Led- same signal?
Wouldn’t that just bypass the FET entirely?
It looks like on this one the FET drain is going to led- and the FET source is going to boost driver led~~. Part of my confusion stems from the use of 3 different boost sample(Fastech, nanjg110, and the 15mm 2803 driver I’m messing with). Not a knock since it forces me to actually see what I’m looking at but sometime feels like a Gordian knot on 3 pages. The example above looks like it has the Fet drain to mcpcb led~~ and Fet source to boost led- so not same signal?
I think an updated op would help including schematic, latest oshpark board(s), and maybe an example for those that might be just stacking a controller board(simple pin/pad connection list).
I have a couple of copper A1 on their way to me, it would be great to use this driver in them to get rid of the strobe in the original driver. Hope this will be available soon, thank you HarleyQuin.
I’m ordering some boards now but have no idea how easily this can be part swapped from a donor board. Probably a bit harder than a nanjg 105C. If you want to try it both the parts list and oshpark links are done. I believe it is usable with a donor mcu but not sure and to have off time switching you’d need a donor with that programmed in.
