PD68 Review: Thorfire S70 - XHP70 Monster
Exactly the same with both batteries? lol
I don´t understand, same output but Basen 4.2A and KP 5.24A.
That is with a light meter app on my phone.
I have no idea whether the app is any good though ?
Guessing the app isn”t up to much as I just got exactly the same reading using a Thorfire C8s as well ?
Are you guys really in write only mode? Check the video a couple of post before… Buck driver pulls what the led needs. If the voltage sags the amp will be higher, if voltage does not drop under load the amps will be less.
My english is very bad, can you simplify? Are you saying that although the amperage reading is less with Basen, It does not have to give less light?
I guess that is the maximum that can be measured from the lightmeter of your phone. In that case you should be test more distance from the phone.
Yes I know I will phrase my question differently.
This is my question.
2 cells, one weighs 100g, has over 4500mah, resting voltage of 4.18v. & gives a tail cap reading of 5.4A
The other cell weighs under 90g, has just over 4000mah, resting voltage of 4.15v & gives a tail cap reading of 4.2A.
Which is the better cell ?
Is it the 4.2A cell as it is giving more voltage hence the lower tail cap reading ?
The second cell is advertised by the manufacturer as an improvement on the first cell.
Yes. Check my post .
It al has to do with power (watt), amperage only isn’t saying a lot.
We can’t say for sure based on your measurements, it takes a lot more testing to know what battery is better. Though I think that the lower weight cells has a lower internal resistance so you can draw more amps while maintaining a higher voltage. That doesn’t mean it’s better, it’s just capable of delivering higher amps. While the other has a slightly higher capacity.
With the solder pad’s bridged and springs bypassed.
Efest 26650 purple 3500mah on turbo - 8amps at the tailcap.
MNKE 26650 3500mah on turbo - 6.5amps at the tailcap.
Measured with thick short wire and a Brymen multimeter.
I’ve lost interest with my smaller light’s.
Steve Martin once did a skit about being an audiophile. Starting with a little AM transistor radio and moving up to FM Stereo, you want more and more and more, soon enough you have a 10,000Watt system and have to go to the Moon for best hearing experience.
The more lumens we get, the more we want. It’s an never-ending avalanche of incoming lights. Pocket book forewarned.
There’s no doubt about that. :wink:
(N.B. a few swears)
Hi all,
does anybody know which exact type/bin of the XHP-70 is used in the Thorfire S70? I´ve heard there are different ones, N4 or P2…
Also, I´m curious if a simple spring bypass without the “solder blob” driver mod would also slightly bump the amps of this light?
I´d want a little more “juice” from my S70 but I don´t want 8 or 9 amps, I´d like the light to be still practicable, not a pure “show off” light. I don´t want to shave the LED since I really like the floody beam.
Thanks,
K.
The bin isn’t specified anywhere but it’s a cool white.
Doing both spring bypasses will increase the current a little, bridging the solder pad’s will obviously increase it much more.
I did all on mine and I’m getting:
Efest 26650 purple 3500mah on turbo – 8amps at the tailcap.
MNKE 26650 3500mah on turbo – 6.5amps at the tailcap.
So it’s not just about the bypasses and solder blob, you can actually choose the battery type to vary the amount of current that’ll be drawn.
Even with my light drawing 8amps on Turbo you obviously have low, med, high and turbo so I just switch it to medium to conserve the battery and now and then switch to Turbo and then back again to medium.
Hi, I have my s70, I want to modify adding resistance r100 same as convoy L6, does it work? Where should I put up resistance? In third free slot or on the two r92 stack? Last is stable the mod, or burn controller? This is addictive !!!
An R100 would be just fine. It will increase the output, but not as much as a direct short, so it will be more stable over the long run.
I would just stack it on top of the stock resistors.
BTW, there is a new version of this light. It’s called the S70s. It has a moonlight mode, 5 minute turbo stepdown and maybe a few more changes.
Here is a pic.
What’s the best deal on this now?
Just today I bought the newer S70s for $40.50 from a store on Aliexpress. It shows a $42.50 price along with a $2 off coupon.
Just search for S70s.
BTW, I already have a Convoy L6 and did not need this Thorfire, but the price is just too good to NOT buy it! Lol
Shit, that was the light I was referring to in my post.
Awesome deal at $40 shipped!
And I have an L6 as well and don’t need this light one bit, but I have two extra protected Keeppower 26650’s just sitting in my drawer waiting to be used, might as well add another monster light to the collection… right? lol
One for car, one for house. :slight_smile:
