Dangit! just when I though I was going to bed I had to check my email. I don’t know if I said anything but the first clear anodizing run did not come out well. Looked more like just grey. Well look what Simon just sent.
Looks pretty clear to me…
On that note. Good night all. Don’t forget to tip your waitress…I’m here all week.
JEEZ , it just gets better and BETTER!!! What started as a DREAM, BAMN out of the park!! Any other Large Factory Hot Rod Modded Torch come clear anodized hmmmm? :innocent: Amazing!
I planned right from the start to have a clear anodized version of the L6 and a few others but we needed to wait for the factory to get the clear right. As you can see, they did it. :student:
Seems a no brainer to put it on the S2+ as well. That one I want to wait for the black steel button though. My current S2+ dream light is clear anodized with the black clip and black stainless switch with that “PilotDog glow” showing through like the ones emarkd made. LOL. Spun out again. Ok back on track now…
Yeah I will probably buy as this light looks great, tint is the only negative. Not sure I will be able to resist long unless a NW/WW is in the very near future.
Already in the works buddy. And of course with the XPL-HI, black switch, black clip. at least that’s my vision for it. Hoping to work out a slightly improved driver first though. I haven’t announced that one yet as it’s too early. Dang. I just said it didn’t I?
Grab your S2 and then take the paint of using some thing none abrasive better of soaking it in water and an additive so the anodizing comes of then you whip out the rotary tool and some polish! or if Simon makes it bare it makes it easier but you will have to polish every so often….
I would like to see Simon come out with a Red Blue and Green L6? Full colors and then “Maybe” with a twist to it, Custom if you will? Like a Black bezel Green Head with a black switch and Green battery tube and Black tail cap? In Red and Black, Blue and Black or even Black and Tan too? How about mix and match to order? A totally hot rod modded custom colored torch? Wonder if anybody would be interested in something like this, I know I would!
I’d be interested in a neutral tint L6 with desert tan and black coloring, tan being the predominant color. But I’d also be just fine with all black if it had a NW emitter.
I’ve made sure Simon is very well aware of our desire for neutral emitters. He’s checking with a supplier in Hong Kong to see if he can get some. Some of the more desired Cree emitters are not as easily acquired as they should be.
On a more positive note I can you all a bit about the driver.
4 modes plus a hidden strobe. It will have mode memory. Current controlled modes. No PWM.
Mode settings are:
Low – 50mA
Med – 200mA
High – 1700mA
Turbo – 5000mA
Hidden strobe – activate by a quick double tap on the side switch.
Early tests show it may be hitting a bit higher than the “official” numbers :sunglasses:
No way I’d ever buy a light with all those mixed colors! It’d look like it was pieced together from spare parts, a garbage can light. I’m sure others will like it because it’s different, but it’s not for me.
