My bad sorry! But that sounds even better cause i am clumsy with my lights i will defiantly get one or two
Me too, can’t wait to see one with the metal button.
I would like to see Simon come out with a Red Blue and Green L6? Full colors and then “Maybe” with a twist to it, Custom if you will? Like a Black bezel Green Head with a black switch and Green battery tube and Black tail cap? In Red and Black, Blue and Black or even Black and Tan too? How about mix and match to order? A totally hot rod modded custom colored torch? Wonder if anybody would be interested in something like this, I know I would!
I’d be interested in a neutral tint L6 with desert tan and black coloring, tan being the predominant color. But I’d also be just fine with all black if it had a NW emitter.
I’ve made sure Simon is very well aware of our desire for neutral emitters. He’s checking with a supplier in Hong Kong to see if he can get some. Some of the more desired Cree emitters are not as easily acquired as they should be.
On a more positive note I can you all a bit about the driver.
4 modes plus a hidden strobe. It will have mode memory. Current controlled modes. No PWM.
Mode settings are:
Low – 50mA
Med – 200mA
High – 1700mA
Turbo – 5000mA
Hidden strobe – activate by a quick double tap on the side switch.
Early tests show it may be hitting a bit higher than the “official” numbers :sunglasses:
No way I’d ever buy a light with all those mixed colors! It’d look like it was pieced together from spare parts, a garbage can light. I’m sure others will like it because it’s different, but it’s not for me.
That’d totally mess up my chi! lol
No PWM
Out-freaking-standing!!!
Another fine win!
I have quite a few XHP70 lights and with pretty much every Bin and tint, and shaved and non shaved, and I can’t think of one that I have that would or could compare to a MTG-2? To me the MTG-2 is the King of Neutral Beauty! So define Neutral White? The supposedly neutral XHP70’s out there are usually lower bin and lower out put, and in a OP reflector just seem kinda blah? That’s why I like the smooth reflector, and my emitters shaved of the higher bin, more throw and tends to warm them up a bit, but nothing close to a MTG-2? So I guess throw a MTG-2 in it??
The 96 CRI XHP-70 in my Intimidator way outperforms an MT-G2 and is just as pretty or more so. But I still highly favor my 10 or 11 MT-G2 lights and my triple 9V MT-G2 BTU Shocker is a personal favorite.
So yeah, I think the L6 with an MT-G2 would be freaking awesome! (The L2 is, so why not?)
Dale dome on right? I shaved the same one down and it’s in one of my SD75’s, in the case sitting on the shelf! I didn’t like it much out of the OP reflector, but then again the SD75 Op reflector was not half as good as the Crelant 7G10 or the S70 quality wise! But I live in the city so I need brute force to compete with all the street lights and all the ambient lighting that’s around, it never really gets dark out where I live? I have to be able to see whats in their hands not how vivid the color of the clothes look at night? Just kidding! I really need to move out to the country, meh some day!
Yeah, big difference competing with all the ambient. I need to see if it’s a grey fox looking to eat barn cats or Redd Foxx looking to steal my junk! lol
My High CRI variant is surrounded by the LUM 5-90, excellent reflector.
Edit: I don’t shave the domes on these as they’re simply not throwers to begin with. I did shave the 4 XHP-50’s I put in a D80 but that was to fit em under the Quad optic…
See that’s a big part too, a quality reflector is the heart of any light, you can change drivers and emitters to the cow’s come home, if you have a crap reflector, it’s just a waste of money! Thank God I weaseled out a couple smooth reflectors from Lumintop, before they shut it down!!
Yes, yes, yes!
I love the MT-G2, but too often, the one used in flashlights has a CRI of 70 Ra. On the Cree datasheet, I saw an MT-G2 with a CCT of 5000K and CRI of 80 Ra, but I have never seen it in a flashlight.
I was thinking last night about the option of an MT-G2 if a good NW xhp70 could not be sourced.
Can a MT-G2 be driven as hard as an xhp70?
I don’t know that I’m as interested in a MT-G2 version, but that’s because I already have an Eagletac MX25L3 that I love.
The MT-G2 can do over 16A. But it’s only making some 4300-4500 lumens up there and has started dropping in output after 12A. Djozz has charts on all that, I find them to be very accurate to what I see in an actual light.
The XHP-70, being essentially a Quad XM-L2, makes more output on lower amperage and I’ve seen it doing some 12A or more with very high output, and accompanying heat factor as well.
The MT-G2 is available in 80CRI and 90CRI variants, at a cost of lumens. Even at a measely 1.1A, lumens drop is over 300. And the CRI 90 is at 3000K, very warm.
There is a 9V MT-G2 available that can run on 3 18650’s (or 3 26650’s as the case may be) and it makes more output, around 4900 lumens up in the high range, which is getting close to the High CRI XHP-70. I think my SR-90 is making just over 5000 lumens from rested and partially used cells.
Good info, thanks.
Wow never knew that about a 12v MT-G2! What about a 12v XHP70 Dale?
How do i make a thread here? i’m not quite sure how.
9V MT-G2, they come in 6V, 9V, and 36V variations.
The 12V XHP-70 requires a specialized mcpcb that has the dies in 2S2P arrangement. It’s the same die, just wired differently on the mcpcb. The 6V XHP-70 mcpcb looks pretty much like any other star with long electrical connections on either side of the thermal pad. The 12V XHP-70 mcpcb has short sections on each side and has jumper pads in order to wire the 4 dies differently. I don’t like that one because the traces all seem very skinny, but I guess it takes lower current at higher voltage so perhaps it’s all the same?
