Nothing yet - hope to get to it soon. Might go with the new 219C 320 from Richard, or maybe the new XP-G3, de-domed. Want to push it for throw though.
The one thing that is really attractive about this light is that it’s able to be used while charging.
I'm a fan of the ZeusRay's, but this A2 light is no comparison. The ZeusRay, if you actually get one like advertised, is a good deal for $8, but the A2 is equally as good a deal, or better, for $18. Can't compare the two - like comparing a Sipik SK68 to a Convoy in quality, plus all the better features with the A2 (LVP, USB charging...).
The more I look at it, the more I'm impressed with it - I agree with freeme in that it competes with much higher cost brand name lights - $17.42 now, here: dhgate.com-supfire-a2
Also right now, outstanding deal for volume purchasing: $11.75 each for min qty of 20, free DHL shipping: dhgate.com-supfire-a2-volume purchase.
It's not perfect by any means. It's too long - they could have been smarter to get it down in length, plus the modes I mentioned - not a big fan of this type of UI. But I do like it's compact pocket size in width, like other tube lights but in a zoomie.
Hope I get some time this eve to mod mine up... Might throw in a XP-L HI for now.
Tom, can you confirm if it can be used while charging? I like that feature a lot
It’s in pieces and at home right now… I can rig it up though to try it when I get home.
Nice review and teardown.
Would it be possible to add some beamshots? In both flood and throw modes.
Thanks!
Ok - rigged it up on the bench and tried it. While on the charger, the RED LED in the switch blinks, and turning the main LED on works fine, and the RED LED still blinks. So it all appears to fully work while charging.
Thanks!
Well, it's still all in pieces, but will be modding it first. Just from my own opinion, it's a pretty nice clean beam for a zoomie. Full flood is smaller than some, but kind of expected for the small lens. it focuses perfectly, showing the dot patterns of the XM-L2 surface, with a ring pattern immediately around the dye image, but again, looks smooth. You really need to black out everything under the lens and around the LED to get rid of everything.
Thanks Tom.
Anyone know what’s the different between the 2015 and 2016?
Put in a XP-L HI V3 2B last night - it's from MtnE back when they had the V3's. Focus is a little out now, but expected. I compared the flood against a modded ZeusRay and actually the A2 is about as wide, but cleaner, more a perfect round. So it's actually quite wide - think the ZeusRay is at or near the widest flood I have.
Getting more amps now, about 2.60A - was hoping for more with a resistor mod (added an R300) and 28-> 24 AWG LED wires. Bypass added to the driver spring.
Lumens: 802 @start, 772 @30 secs, throw: 25.5 kcd taken at 5m (319 meters)
Realize now the circular pattern around the zoomed out dye image is from the white LED centering piece, outside of that, not much in artifacts.
I don't see any differences in 2015 vs 2016. Think the guy on DHGate even updated the listing to 2016. Looks like the factory lumens went up, but they are exaggerated anyway.
Upgraded mine to XP-L HD on Noctigon, and 24AWG plus spring bypass when I received last week. Driver was left un-touch at the moment. Mod time is considerably longer, due to the glued wire and loose transparent button part that would interrupt the assembly.
Despite for having lesser output and narrower zoom out flood when you compare it with Zuesray, this light has slight edge in built quality and useful functions (e.g LED status, microUSB charging, darken clip, etc). A8's design resemble S30, which is one of my favorite styling for 18650.
True - little tricky getting things assembled. I left the 24 AWG wires close to the same length as the originals, but probably could be shortened. What I did was first almost fully tighten the pill top down, aligned the wire holes to where they will come from the driver, then carefully inserted the driver from below, then only had to give the pill top a 1/2 turn or so to tighten it up, so very little twisting of the wires as a result, and not much extra wire length needed. For the button assembly, just made sure it was in the fully "out" position prior to inserting the driver, so that went ok for me.
Not sure, but suspect I got nothing from the resistor mod. Interesting you saw flood was narrower than the ZuesRay, because mine appeared about dead even, but my ZeusRay was an original thick pill shelf model, and modded with an XM-L2 neutral/Noctigon. Think there's been some ZuesRay variants. The ZuesRay flood beam is not a perfect circle with mine - slightly squared off but no big deal really - only notice it on a white wall.
Even at 2.6A, I could feel the body getting hot fairly quickly. Not as much metal for heat sinking as the ZuesRay has, but I do like the thinner profile.
Does this work with flat top 18650?
Just received my SupFire A2. Some preliminary observations:
- It works with flat top 18650 (there is a spring-loaded post at each end).
- Beam Pattern is very clean for an aspheric zoomie, with a fairly wide flood. No rings in flood mode and in the transition to spot. Spot mode has a very slight ring around the image of the emitter. This ring is the image of the white centering disk around the emitter.
- Tint: Cool white. No hint of green.
- Recharging: It works, but the little rubber cover over the USB port looks quite flimsy. Much flimsier than the rubber covers over the ports on my Niteye EC-R16 and EC-R26.
- Overall Length: Definitely feels like they could have shortened it some. for instance, the tailcap adds at least a cm of unnecessary length when the only things in it are a contact plate and a covered spring with maybe half a cm of travel. Behind the cover plate is another 1 cm of light.
- Hand feel: Light feels grippy in the hand and feels like it is well built. Hand feel is pretty good though the switch feels like it would accidentally turn on in the pocket.
- Zoom mechanism: Butter smooth well lubed zoom mechanism. Maybe too well-lubed since lube can be seen when the light is cycled to spot mode. On the upside, the zoom feels great.
- waterproofness: Not waterproof. Only thing I’ve done so far is remove the bezel, but the outer bezel and lens had no o-rings.
- Modding potential: Haven’t looked into it yet. If I do, the goal would be to dramatically shorten the light, likely by replacing the driver, removing the charging mechanism, and then removing excess parts of the body and tailcap. I figure I might be able to take an inch off the light
Thanks Firelight2
Any thoughts about making the red/green led a locator light in the dark? Tom E / freeme could one of you measure the power usage of the red/green led to see how much power it’s using?
I miss the parasitic drains from the ‘find me’ blinking leds. I can’t find anywhere….
-d
Does anyone know if the red blinking light charges to green when it is done charging? And does it know to stop charging or does it trickle or restart if voltage drops?
-d
I did some resistor mod tests with the origional led. I have settled on one added R100 resistor. It now pulls 3.2Amps on high. I got the current all the way up to 3.6 but the driver shut down at the level. I don’t know what happened, but after a while it reset and started working again. So the R100 resistor is right on the edge of what the driver can handle. After, I get everything set, I will probably pot the driver.
Still not sure what led to put in it. I have some xpl hi’s but im hesitant to use one as I have some other builds worthy of the xpl. How well do dedomed xml2s work in these types of zoomies? I wonder if I dedome the stock blue tint emitter if it would turn green?
I should try resistor modding mine. Can you take a photo of the driver showing where to put the R100?
-d
It changes to green when done.
Don’t know if it stops charging at that point.
